A321 hail damage and emergency landing, wow...
That would have sucked. Glad to see all ended well.
http://www.flightglobal.com/Articles/20 ... unter.html
squawk 7600
Last time I checked, 4 FA would be fine for 199 passengers, isn't it? Correct me if I'm wrong, but the minimum is 1 per 50?
I also do know that each country can have their own regulations, but if for example, there's a conflict in regulations, between an aircraft registered in country X flying over country Y, if country Y has more restrictive regs, then the Y regs should be followed, and if the X regs are more restrictive, then X regs should be followed. I other words, follow both countries' regs and in case of conflict, go with the most restrictive one.
DNB
DNB
Schlew, Why jump all over the flightcrew? Wx. Radar is a very poor tool to detect hail! Most of the time it can't be detected. A Transat L-1011 encountered a hail laden CB a few years ago leaving southern France which rendered the aircraft scrap in Lyons. Check out some pic's on airliners.net if you want. The flightcrew reported no Wx. abnormalities and nothing was detected on radar. My 2 cents.
Pierre Maguire should have his larnyx ripped out! IDIOT!
I was pretty sure that hail could be found more than 150nm from an actual CB that produces the signature 'anvil' top.Schlem wrote:Good job flying through a hail storm? Hail is associated with CB's so what were they doing that close and or in a CB in the first place?
Wx radar not working?
- cedar tree
Thank you TFE731, I hate critics.TFE731 wrote:I was pretty sure that hail could be found more than 150nm from an actual CB that produces the signature 'anvil' top.Schlem wrote:Good job flying through a hail storm? Hail is associated with CB's so what were they doing that close and or in a CB in the first place?
Intellivision made me a pilot.
Dunno about 150nm but ... it pays to know what the upper (ie tropopause) winds are doing (ie look at the anvil).hail could be found more than 150nm from an actual CB
It is possible (but not common) for hail to shoot out the TOP of a CB, and be carried downwind many miles by a very strong tropopause wind.
It ain't gonna go far upwind, though.
Hedley wrote:Dunno about 150nm but ... it pays to know what the upper (ie tropopause) winds are doing (ie look at the anvil).hail could be found more than 150nm from an actual CB
Quoted from The National Center for Atmospheric Research:
"Viewed from the air, we can see that hail falls along paths known as hail swaths. These can be quite small -- a hectare or so (a few acres) in area -- or quite large, 16 kilometres (10 miles) wide by 160 kilometres (100 miles) long....."
Just sharing information.
