How many FSS?
wxman
How many FSS?
Post by wxman »
Would it take to staff a 24hr FSS.
How many fewer would it take if a CWO also on site?
bigfssguy
Post by bigfssguy »
as little as 4 people for a 24 hour operation and that i'm aware of there is no such thing as a CWO onsite at an FSS. If there are FSS there we are all certified weather observors. Never heard of it, but not to say there isn't anything out there?
FSS: puting the Service back in Flight Services....
lilfssister
Post by lilfssister »
4 sounds like a low number big guy? I would think 5 or maybe 6, but I could be wrong? WIth an Arctic work week probably 5.
I agree though, that there would not be much point in having a CWO if you had a 24 FSS. Why incur the expense of a CWO when there's certified wx observers there 24 hrs?
wxman
FSS + CWO
Post by wxman »
not the norm but it does happen.
Case in point is YYB that has both CWO and FSS.
Just hopin for our staff.
bij
Re: FSS + CWO
Post by bij »
wxman wrote:not the norm but it does happen.
Are you working in a place that has a tower possibly becoming FSS, as in YSB?
bigfssguy
Post by bigfssguy »
Rankin runs on an arctic work week with 4 people, here in Churchill we have 5 people on a semi arctic work week. In a normal southern station if i had to guess i would say 6 people roughly for 24hrs single stand.
North Bay had a CWO becasue it would be really tough to do wx obs from a few hundred feet underground. Now that the FSS has migrated to the surface and into the new building i wouldn't be surprised to see them pick up the wx obs. but then again goverment doesn;t take change well so i could see Enviomnet keeping the CWO. Who knows though.
bigfssguy
Post by bigfssguy »
pokaroo
Post by pokaroo »
YYB FSS is in a cab they always have been. The Arctic guys were in the hole. They do not run a 24 operation and that could be why they have a CWO.
sigmet77
Post by sigmet77 »
There is a CWO because of the location of the met compound. "Southern" FSS need 5+1 if the run single stand. YYB should be one of few FSS that has a CWO and they will probably disappear over time.
thatdaveguy
Post by thatdaveguy »
Also, no FIC's AFAIK do their own weather observation.
Standard staffing for single stand: 5 operations, 1 supervisor.
lilfssister
I can think of one FIC that does wx obs.
bigfssguy
Post by bigfssguy »
Yes Lifss, Winnipeg FIC does there own wx observing.
lilfssister
Well, then there's more than one. :D
NJ
Post by NJ »
YZF as it is now does WX
lilfssister
pokaroo wrote:YYB FSS is in a cab they always have been. The Arctic guys were in the hole. They do not run a 24 operation and that could be why they have a CWO.
YYB had a control tower til March 1999.
pokaroo
Post by pokaroo »
Yes there was. Has there ever been a North Bay FSS (CYYB airport) providing AAS not in the cab?
G.N. Thompson
Post by G.N. Thompson »
Out of curiousity, when FSS only, what duties/priorities come before wx obs? Wx spcls?
GNT
sigmet77
Post by sigmet77 »
Aren't you FSS?
pokaroo
Post by pokaroo »
Untill recently the arctic radio guys were down in the hole with NORAD. The actual YYB airport FSS were up in the cab
G.N. Thompson
Sigmet,
Negative. I think a lot of frustration would be avoided if everyone understood the plan.
GNT
thatdaveguy
G.N. Thompson wrote:Out of curiousity, when FSS only, what duties/priorities come before wx obs? Wx spcls?
GNT
everything does.
G.N. Thompson
Dave,
Is that just your take on it, or has your manager actually decreed wx as your lowest priority? If that's affirm, let me guess that neither of you have shot an approch in IMC?
GNT
grimey
Post by grimey »
G.N. Thompson wrote:Dave,
GNT
Depending on the equipment available, all of the information that goes into a METAR/SPECI may be immediately available to the FSS in the cab, especially if they have a laser ceilometer. So just because we didn't have time to put a special out, doesn't mean we can't give the current visibility, ceiling, RVR, and recent pireps to a pilot. If it's nasty IMC, I try to give pilots as current a picture as possible, regardless of whether it has actually gone out as a special or not. But official wx obs are considered to be pretty low priority. That doesn't mean the info won't be relayed to any pilots operating in the area, or that it will be delayed for an extreme amount of time before being entered into the system, though.
G.N. Thompson
Dave, Grimey,
So from the perspective of people in dispatch or the flyer checking your wx from 400 miles away, exactly what gets a lower priority than wx spcls officially?
GNT
lilfssister
Digging in the "when did I last read that part of MANOPS?" memory bank, order of priority is :?: :
Emergency
Inflight
Preflight
Other
Wx obs fall into the inflight category (with the caveats as described by grimey, as to when the conditions may be entered into the system and passed on to the farther away inflight or the preflight crowd by other FSS, ATC, or dispatch/self brief)
