Orange hammer fixes problem?
invertedattitude
Post by invertedattitude »
Just a quick Q.
Watched an AME, or I assume AME, open a panel on a mid-sized turbo-prop, tap a few things with an orange rubber hammer... and the problem, whatever it was, was fixed.... curious, what sort of things on an airplane are fixed with a few differently placed rubber hammer taps?
Spinner
Post by Spinner »
PDU on a 340?
lol
727doctor
Post by 727doctor »
You need to be very careful what kind of hammer you use, they are very sophisticated tools and sometimes they can do amazing things. You would be surprised what else they can fix!!!!
bandaid
Post by bandaid »
The Pilots :lol:
THOR
Post by THOR »
Behold the glory that is my waaaaaaay overpriced hammer.
twnotter
Post by twnotter »
Sometimes the brushes on a starter/gen stick, due to carbon build-up wet splined shafts are notorious for this, a slight tap on the starter will free up the brushes and the starter will turn over. Usually this is done just to get you home so that you can change the starter/gen.
Hope this answers your question. If you were not referring to the engine then I haven't a clue.
Post by 2024 »
you can only use that way over priced hammer if it is calibrated.
motox415
Post by motox415 »
A calibrated hammer works well on sticking bleed valves.
Flyboy_172
Post by Flyboy_172 »
I am still looking for a left handed orange hammer!! :lol:
hawkertech
Post by hawkertech »
No Problem! Same truck, just $20 more. Calibration and GST are extra, of course.
[/img]
Don't be concerned with what other people think, most of them don't do it very often anyway.
64cruzr
Post by 64cruzr »
My other tool is a chisel!!
Post by 2024 »
yup, you can buy one. it is on the truck right next to the left handed screwdriver, and the onion goggles.
kai
Post by kai »
I believe you are referring to a precision tapometer :)
blacksmokeoutofthebox
Post by blacksmokeoutofthebox »
I dont go anywhere without my 3 trusty tools, Monkey wrench, BIG MALLET, flat head screwdriver. They work for every occasion
I use a BFH on all kinds of things!
Big Fucking Hammer
gonfly'n
Post by gonfly'n »
does it have to be orange?
727doctor
Post by 727doctor »
Yep!!
If it's not orange that meens that you are to cheep to get the real thing.
Post by niss »
As I understand in order to use anything other than an Orange hammer you must check with the aircraft manufacturer. Lower quality "Grey" hammers have been known to dent and bend airplane parts.
benchmark
Post by benchmark »
twnotter wrote:Sometimes the brushes on a starter/gen stick, due to carbon build-up wet splined shafts are notorious for this, a slight tap on the starter will free up the brushes and the starter will turn over. Usually this is done just to get you home so that you can change the starter/gen.
if it's not in the engine bay it could be the brushes on the motor running the vcs....i love my orange hamma!!!
chubbee
Post by chubbee »
If it was a 1900 the buss electrical contactors (aft nacelles and battery box) have secondary "indication/annunciator" contacts that are "whimsical" if the vent holes on the relay are not sealed up in a damp environment (rtv or conformal coating). Cycling them a thousand times or givnin them the beats (with a caibrated tool such as an orange hammer) can help if a parts change is inconvenient and the primary fuctionality is serviceable (busses are powered)/indication/ annunciation fault only.
ettw
Post by ettw »
The deadblow hammer and 600 mph tape are the most under rated tools of the trade. :D
ETTW
Return to “Maintenance”
