FART on an infrared camera
flyincanuck
Post by flyincanuck »
grimey
Post by grimey »
someone has an ice-cold ass.
sprucemonkey
Post by sprucemonkey »
Looks like an '88 Civic in Richmond. :P Heat shows up white on infrared cameras right?
bandaid
Post by bandaid »
He was really leaning forward for that last fart, looks to me like he could have shyte hisself.
Apollo
Post by Apollo »
too bad it's completely fake :P
pikerz
Post by pikerz »
it's definatly fake.. its just like someone shoved a smoke machine up his ass or something like that.. heat shows up as red and white and what not.. not black smoke
Post by niss »
You guys may think it was fake but I think the ppl puking blood shortly after would disagree.
megaton montage
Post by megaton montage »
if you are using an infrared camera you can select either white or black being hot, depending which one gives you the better contrast for what you are trying to see.
grimey
Post by grimey »
megaton montage wrote:if you are using an infrared camera you can select either white or black being hot, depending which one gives you the better contrast for what you are trying to see.
The camera is set to white-hot, look at the people. It's a can of hairspray, or something similar.
w squared
Post by w squared »
Grimey is right. An IR camera would show a real fart at the same temperature as the body. Regardless of what the camera is set to (black=hot or white=hot), there is obviously a temperature difference between the fart and the ass.
Skipper
Post by Skipper »
could it not still show up darker than everything else because it's actually warmer than skin temperature? On the outside we're not that warm, but what comes out is obviously inside temp. That's what I'm thinking.
"Willing suspension of disbelief"
It's amazing the in-depth thought and skepticism on a fart that you have gone to
w squared
Post by w squared »
Skipper wrote:could it not still show up darker than everything else because it's actually warmer than skin temperature? On the outside we're not that warm, but what comes out is obviously inside temp. That's what I'm thinking.
Except that in this case, the camera is set to white=hot (look at his arm). Given that fact, it's obvious that what's being released is colder than the surrounding air...which is consistent with the cooling due to decompression of a gas being expelled from a pressurized container.
