Any help would be appreciated because there is a few beers riding on it, and it isn't really something that gets done in Australia
Float Plane take-off from land
max1090for2
Hi, i'm an Australian float pilot, and a few of my work mates and I have been dicussing taking off in a straight float plane from a grass strip, and we couldn't agree as to what happens with directional control? Does it maintain the diection that you start because it creates a groove to run in or does it swing to the left? if so how effective is the rudder?
Hey,
Um, you might get a better response from a more experienced float pilot.....but anytime i have heard of this being done, the plane is launched from a trolly that is towed behind a vehicle. I don't see a float plane sliding along grass fast enough to get off......then again maybe it can be done....
The grass has to be wet but not to the point of making the ground muddy. People have landed on wet grass ok, not sure about taking off but I'm sure it can be done. Speed would be the issue. Try flapless to start, get max speed then pull on full flap (if max is borderline TO speed) using careful pitch control, accelerate in ground effect, drop flaps slowly one notch at a time, continue.
Prior to any of this carefully scout the take off area for debris; rocks, pebbles, sticks etc and scout an area larger than you think is required. Also best cared out in early morning when temps are cooler.
(Info only, not intended as an endorsement or instruction)
I think you would be far better doing a dolly take-off. Many different ways to do this but here is an example..
http://www.alexisparkinn.com/water_aviation_video.htm
Never tried it myself, but it looks quite doable..
plane_nuts
max1090for2
I've done the dolly thing a few times, works pretty slick, once you line up on the runway there is usually a locking pin to keep the forward swivelling wheels centered, which works most of the time, had to abort once when it wasn't staying centered, only took out 2 runway lights.
Once you have speed, away you go leaving the dolly behind, hopefully not taking out too many more lights.
As for the wet grass take offs, I have no idea how feasable it is, you would want to ensure a very carefully inspected area before trying it. Personally I have not heard of doing it this way, but doesn't mean it doesn't happen.
Depends on what kinda plane. Super cub on wet grass works great. Havent had the balls to try the stoneboat yet and don't plan on it. 185 dont work to bad either. Just make sure you keep your beak into the wind and remember speed is your friend you don't want to let that thing touch after you get yer flyin
The dolly didnt have bakes on it until one of the managers took a customer onto the runway to watch a takeoff, they drove out in a brand new car. the beaver took off and the cart ran right into the carBoss Hawg wrote:When they delivered float Beavers from the factory at Downsview I'm pretty sure they used dollys. It wasn't towed by a truck though IIRC, the plane sat on it like an amphib but the dolly stayed on the ground after takeoff.
the cart got brakes installed
- Dust Devil
- Dust Devil
Here is a taylorcraft landing on the grass next to the runway
http://www.youtube.com/watch?v=62HKnM_1_wM
A company I worked for a ways back would land our single Otters on the grass next to 22 in Ottawa...I guess the only thing you had to remember was to keep some power on once you stopped or it would fall hard back on the tails of the floats and that meant I spent more time in the float compartments dumping rivets.
I guess that gives anyone who knows me a time line....its been a LONG time since I could fit into ANY compartment on a set of Otter floats let alone the back one!
ETTW
ETTW
3. I still hate simulators
Idriveplane
Over the Horn
I've landed on dry grass no prob. just glassy it on and keep the controls full back once you touch down to keep from flipping over, but no sooner or risk stalling it on. the whole process is rather quick and over before you know it if you've got any float exp. it should be easy as for takin off only seen it done on dolly's or trailers never from grass, if you do use a dolly make sure you got good insuranse and the airport operator is kosher with it, if the brakes fail that sucker is going somewere fast
in the spring we use a trailer for that reason.
cessnafloatflyer
Our salt water C-180 was stripped, etched and alodyned last month in Chilliwack with a landing on grass and I took off last week from the cart on Edos. Not a big deal, but a pull to the left until the RPMs got up to about 2200. No brakes on that one and as i pulled up hard at 70 kts a watched the cart go off the runway, onto the grass and wondered about the runway lights.
The AMO had the insurance...
Stay safe...
Stay safe...
Ronner:Dust Devil wrote:http://www.youtube.com/watch?v=SYd8_4ZSGLQ
Same aircraft. You can tell by the registration. As in there isn't one! There is a mark on the bottom of the right float though.
Actually, the very first Beaver take-off from Downsview was done on floats without a dolly. The dolly wasn't ready yet so they built two troughs (I can't remember how long) and filled them with lard. Lots and lots of lard. The Beav just sat on the two troughs and slid along on the lard. (The whole story is in the De Havilland Canada book.)
