King Air B200 Current Limiter Question
Can someone tell me why you would lose your #2 Avionics when your right current limiter is blown and both generators are on.
Replace the current limiter and #2 Avionics work again.
stopsquawk
My understanding is that:
a) if something is designed to handle 325 Amps you should never try to replace it without maintenance first finding out why it blew?
and more importantly
b) I don't think you can actually replace it in flight. 50A could kill you instantly. 325 would turn you into a piece of charcoal.
From the schematic in my 200 manual the avionics number 2 bus is not dual fed. Remember diodes between the right gen bus and the 4 dual fed buses prevent reverse current, so no CL, no #2 avionics.
Make sense?
Make sense?
- Scuba_Steve
harveymushman
Yeah my bad. All the current limiter problems arise when one gen is off line. As long as both are on and charging then a blown CL won't cause a problem.Scuba_Steve wrote:umm if both gen's are online I don't see how you would lose it. I don't have my schematics handy, but if you were to loose the right gen with the limiter being blown then you'd loose a few things.
Ya...I knew someone who did that in the air....quite the lightshow when the ratchet grounded out....got the pilot a company suspension and then a TC one. Absolutly the dumbest thing I have ever heard someone doing in an airplane.co-joe wrote:My understanding is that:
Make sense?
BTW...if there was enough voltage to push 325 amps thru your body you would be charcoal but at 28v its unlikely you could push more that a few milliamps...across the heart it would kill you but other than that you're OK.
ETTW
3. I still hate simulators
Just looking at the Simuflite manual. Couple of things. Are you talking about the 325 amp isolation limiter (also called a current limiter) or the 40Amp current limiter on the #2 Avionics Bus? If it is the 325 Amp isolation limiter I have no Idea why the #2 Avionics Bus wouldn't receive power. Simuflite states "The right Generator Bus feeds the DC Avionics bus No. 2 through a 40A current limiter and a 30A CB." So, if the 40A current limiter fails then #2 Avionics wouldn't receive power the way I read it.
Apache
Apache
- KISS_MY_TCAS
I would pay good money to see someone attempt that. Now THAT is dedication....ettw wrote:
- Scuba_Steve
I don't have the diagram in front of me but if what you are saying is correct then the #2 avionics bus would not function in the event of a right gen failure and a right Current limiter failure. That is if its on the right bus and not a duel fed bus. I'll try to remember to look it up tommrow when I'm flying to swift current sask (wee!)Apache64_ wrote:Just looking at the Simuflite manual. Couple of things. Are you talking about the 325 amp isolation limiter (also called a current limiter) or the 40Amp current limiter on the #2 Avionics Bus? If it is the 325 Amp isolation limiter I have no Idea why the #2 Avionics Bus wouldn't receive power. Simuflite states "The right Generator Bus feeds the DC Avionics bus No. 2 through a 40A current limiter and a 30A CB." So, if the 40A current limiter fails then #2 Avionics wouldn't receive power the way I read it.
Apache
