And what about the people who survived the accident? A functioning ELT may have saved my husband's life as much as airworthy floats, active flight following or a call from a witness.
Widow, I think we may be closer in agreement than you think even if it’s just subliminally.
You used the word “saved” when you spoke of ELTs. Nobody needs their life “saved” unless they are in some sort of peril or serious threat of losing their life. ELTs save people once they are in peril because the airplane crashed. They don’t prevent accidents.
Having an ELT however doesn’t make the airplane safer.
So let’s review the chain of events as my “twisted” mind sees them so we can split this issue into the “safety” events and the “SAR” events.
Based on what I have learned about the accident, in my opinion the possible factors that prevented continued flight MAY have included;
1) Engine failure or decrease in performance.
2) Loss of control due to pilot incapacitation or spatial disorientation (Not uncommon when flying in cloud with a failure of instruments or lack of IFR experience)
The factors that MAY have contributed to difficulty in landing the aircraft safely;
1) Oil on the windscreen (poor visibility)
2) Glassy water conditions during landing
3) Weather (Fog/Mist/Cloud) (Flight in IMC or “marginal” weather)
(Notice I said nothing about the engine. I think most will agree that without complicating factors, its not tough to deadstick a float equipped Beaver on the water.)
The factors that MAY have complicated the recovery operation and the search (lives not airplane);
1) Delay in flight following action due to equipment limitations.
2) Lack of an extended ELT signal or ability to receive it due to equipment limitations.
3) Delay in witness reporting (Many “heard” the airplane but none “saw” it - possibly because of poor weather)
4) Extensive damage to airplane (due to impact forces and/or poor maintenance) causing it to sink rapidly.
5) Lack of personal floatation devices on 4 of 5 persons on board.
Recommended changes that may prevent further similar accidents;
1) Educate west coast operators about the risks associated with flying single engine VFR airplanes in IMC (its already against the law) or “marginal” weather. If its not right to do it Saskatoon, why should it be common practice on the west coast?
2) Look at changes that can be made (to this 50 year old proven design) that would prevent engine failures.
3) Put more emphasis on training floatplane pilots to deal with engine failures.
4) Review the maintenance procedures used by operator and operators of similar equipment to identify issues and correct them if required.
Recommended changes that may improve search and rescue;
1) Improved “satellite” or similar continuous flight following systems.
2) Improved ELT systems
Now we have to ask ourselves if it we need to implement all of the recommendations or if concentrate on the prevention of accidents or on the recovery of accident victims.
I would put most of my money on preventing accidents. That’s not to say that the flight following and ELT recommendations should be abandoned, but they won’t do a thing to prevent accidents in the first place. Personally, I don’t think there is any value added to looking at the engine beyond in support of litigation against the operator. It's been around a loooonnng time.
Without an ELT, how long would it have been until Rowdy was found? Or would it have been too late for him too?
Widow, I don’t recall saying ELTs shouldn’t be on airplanes. When the requirement was introduced, ELTs revolutionized the job of finding accidents sites. In Rowdy’s case it worked as advertised and we’re all glad it did. It doesn’t negate the fact that it didn’t make the airplane any safer. I don't know the details of his accident but I bet he would trade his ELT for a gizmo that could have helped him avoid the accident in the first place.
As I've said here before, I'm sure I'm coming across as insensitive but I'm just trying to help you focus and put things in proper context.
In the end, its just advice and opinion and you of course are free to take it or not.
