Air Canada Interview
SQ
Post by SQ »
buss wrote:I applied nothing.
Last class of 21 only 3 with jet time GO FIGURE.
with how many hours in general ?
buss
Post by buss »
3000 - 10000+
calls after interview depend on point system <2weeks to >7months
South Of 60
Post by South Of 60 »
Employer called two weeks after the interview. I waited 7 weeks to the day for the call for the Medical. I know the feeling sitting around waiting! Good luck!!!
YVR Dude
Post by YVR Dude »
thanks for the reply...yeah, aware of the point system...and of course, never really knowing how one did, the wait can go on forever.. :?
Oh well, luck to all!
2low
Post by 2low »
pika
Post by pika »
555 multi pic looks like the multi is what you need!!
Ten times your precious multi time and I should be proud to be your Fo...
bic
Post by bic »
Hey 2low, i had an AC interview recently and they told me that it was $40000 for starting...now i am confuse....anybody else have heard that....
yycflyguy
Post by yycflyguy »
$40k is closer to the mark. It was $37.9k and then we got our big 1.5% raise. The company cannot arbitrarily change the salary structure... even for new hires.
LEMD
Post by LEMD »
I think it's 39K? But around 40 at any rate.
lvl chg
T&C
Post by lvl chg »
Hi guys, fairly new to the site, been reading a lot though. Maybe someone recently hired or interviewed can help here......what method is used for a new hire in determining his entry position and base, i.e EMB F/O, B777RP, etc....? Is it prior experience, company requirement at the time....? And which position is preferred by most? Thanks all...
Rockie
Re: T&C
Post by Rockie »
lvl chg wrote:Hi guys, fairly new to the site, been reading a lot though. Maybe someone recently hired or interviewed can help here......what method is used for a new hire in determining his entry position and base, i.e EMB F/O, B777RP, etc....? Is it prior experience, company requirement at the time....? And which position is preferred by most? Thanks all...
All new hires go into a paygroup position of EMJ FO or RP on the 340/767/777. Some have gone into FO on the 320 because they were so short but I don't know if that's still going on. The available positions and bases are selected by the new hires in order of seniority once it has been assigned via lottery (literally pulling names out of a hat). I would have to say RP jobs are not the most popular because most people want to actually get their hands on a jet. Prior experience has absolutely nothing to do with it as a rule.
tonysoprano
Post by tonysoprano »
...don't listen to toolow. He's fucked.
lvl chg
Post by lvl chg »
Thanks for the response Rockie, thinking of applying soon....
Rockie
Post by Rockie »
lvl chg wrote:Thanks for the response Rockie, thinking of applying soon....
Good luck. You won't regret it.
2low
Post by 2low »
Oh yes you will!
Rockie
Post by Rockie »
Oh yes you will!
Please don't mistake this for defending AC's newhire salary, which I certainly don't, but your earlier post about it being 31K is flat wrong and indicates your level of knowledge of Air Canada. So I'm curious what you base your assertion that lvl chg will regret going to AC on?
tonysoprano
He's not at AC. Heck, he's not even at Jazz. He's a WJ troll. IOW fucking brainless. Even worse when he gets home from the assembly line and opens the fridge. He drinks alone.
2low
Post by 2low »
Bede
Post by Bede »
Sorry, but can someone fill me in on the animosity between Tony and 2Low?
Sage
Post by Sage »
Lover's spat. Ha! :wink: Sorry...had to.
Scope. Not just a mouthwash.
gonefishin'
Post by gonefishin' »
2low, you gonna be at the lake soon? I got something for you....
tonysoprano
Bede wrote:Sorry, but can someone fill me in on the animosity between Tony and 2Low?
Bede.
Might I suggest you have a look at toolows' past threads. It's a no brainer (no pun intended). If you work for Jazz or AC, he's out to make a fool out of you. The moderators don't seem to mind him, so I guess anything goes here.
short bus
Re: Air Canada Interview
Post by short bus »
I waited 13 years for that??
thejetlaglog
Post by thejetlaglog »
:lol:
Return to “Air Canada”
