cessna 340 or piper navajo
hey folks thanks for looking. just curious on what the difference betwen the two aircrafts is. what would be a better plane to charter. looking to purchase an aircraft and have an option between the two. and what be the going rate for either or. ok thats it thanks!!!!!!!
Conquest Driver
- Jaques Strappe
The Cessna 340 is pressurized, the Navajo is not.
The Cessna 340 is a bit delicate, the Navajo is not.
Very few Cessna 340's in the charter market.
Lots of Navajo's.
The Navajo will haul more people farther than a Cessna 340.
The Cessna 340 will give what few peple it can carry a more comfortable ride in summer turbulence or in the mountains because it can fly higher without having to wear oxygen masks.
The Cessna 340 was very basically a pressurized Cessna 310. A lot smaller airplane than a Navajo. It is like comparing a mini van to a dually diesel bus. Depends what you want to do with the airplane.
Do not have a clue what each cost to own or operate.
Lots of Navajo's.
midwingcrisis
Just study the performance specs for each airplane you are considering and pick the one best suited to your needs and your wallet.
Like they said, the 340 and 414 for that matter have almost no useful load. You should be comparing a 402 to the Navajo, but even still the piper has more useful load, can hold more ice, and can take more of a beating.
That said the cessna product has more range and goes 10-20 kts faster.
If you want to go high and fast, with you and one passenger, go 340. If you want to take 2000 lbs of pop and potato chips into a 2000' strip or take 10 pax, go navajo.
Wixel Pimp
Come on co-joe that is stretching things a bit. While the Navajo is a good aircraft you will not get a fully loaded Chieftain out of 2000 ft. In the Chieftain the max passenger seating is 9, 7 for the baby Navajo and that is very cozy arrangement.co-joe wrote:Like they said, the 340 and 414 for that matter have almost no useful load. You should be comparing a 402 to the Navajo, but even still the piper has more useful load, can hold more ice, and can take more of a beating.
The 414A with the VG increase gross weight carries a respectable load.
Email me at cigayi@yahoo.ca if you are interested in a C421 that's going on sale for a comperable price to either a C340 or a Navajo. Was used in charter and now corporate. Has VG kit for gross weight increase. Can carry a good load a reasonable distance and is pressurized.
