Headset choices
Headset choices
Any suggestions on which one for the Dash?
I think I read the 25 is ANR totalling a 30dB reduction combined with passive. Is the 45 ANR as well?
Sennheiser HME C45-KA
Sennheiser HME C25-KA
Telex Airman 750
Telex Airman 750
I'll save you the trouble...as a newhire, you can't order the 25, only the 45. It's light, and the noise cancelling works pretty well, but it's not the most comfortable headset on a long day (due to the fact that the earpieces are plastic plates covered with a thin layer of foam). You can pick up cushioned earpieces in the crew room...they make the headset more comfortable, but the noise cancelling doesn't work nearly as well (in fact, it doesn't make it any quieter...just different noise).
Hope that helps...for what it's worth, at least the price is right!
Swerved.
Swerved.
In a world full of people, only some want to fly. Isn't that crazy?
The 45 is designed for use in jet aircraft. The design of this particular headset is intended to reduce "windscreen noise" so that you do not have to crank up the volume of the radio. It is in my opinion a totally useless type of headset for the Dash. The 25 is better suited and it is a joke that the company does not see to it that the 25 is offered to the Dash pilots.
Your choice if on the dash is to either use your own or the 45 and put your name on a wait list for a 25.
planedriver
Re: headset
yup, flew with a guy a little while ago that was wearing david clarks in the RJ . The dash guys wear them all the time as wellplanedriver wrote:Do normal BOSE or Clarks work on the 8 / RJ?
I love my Bose.
- Jaques Strappe
- Cool Rythms!
I've got a pair of Telex headsets, which I've had from the time I was on the 727. They're small, light and I find them pretty good even on the Dash 8. Sometiimes, I don't even realize I have them on.
"When the power of love overcomes the love for power, only then will this world know peace"
- Jimi Hendrix
- Jimi Hendrix
Steve Baker
