Adlair job posting.
Adlair job posting.
In their job posting, they state that they do three week rotations to Canadian "cities". Just wondering which city/cities?
Thanks!
Thanks!
'effin hippie
Re: Adlair job posting.
I would expect Canadian Cities means just that.
Probably anywhere you can make flight connections to CYCB in 2 days.
Can't be easy convincing experienced drivers to spend half their life in Cam Bay.
This could be a pretty good job though. Adlair has a decent rep as a company and CG would be a pleasure to have as a CP.
ef
ef
Not a bad salary either....too bad you would spend a chunk of it getting home....
I thought the ad was making the assumption that they would pay for the airline flights to and fro
Not a bad deal if that is the case. Anyone know what sort of time they want other than an ATPL?
'effin hippie
These days, how 'bout a pulse. Vision would be a plus too...
I would say the more PIC, KA, PT6, gravel, and Arctic time the better. Contact them: you have the time you have and they need a driver, if it's a match, pack your parka.
ef
ef
i dont think they take you all the way home....do you know what it cost to go from Cambridge Bay to Halifax?
you know what it costs to have no crew when a medivac call comes in from the arctic.
50'minimums
They will rotate anywhere a/c, jazz, WJ, Cdn north or First air flies
So when they say 3 week rotations, does that mean 3 weeks in and 3 weeks out?
TT 2400, PIC 2030, ME 1420 (MPIC 1350), TURBINE 80
yup 3 in 3 out, unless they are short of crew you will be asked to stay longer. they pay for all your flights, housing, and food well at work. its a good job and the money is pretty damn good for medevac and working half the year. also with CG taking over as CP things should only be getting better. you won't find a better bunch of guys to work with.
It all sounds very good. I'm sure there's a lot of "on call" down time, but what sort of flying hours annually would a pilot in this job aquire in an average year.
What happened to the last driver?......these guys dont have much turnover at that salary.....
not a bad gig.....
not a bad gig.....
Buried in the permafrost, remeber you don't have to out run the bear just your co-pilot.
I'd say you get about 800-900 hours a year. FO's don't rotate. Pretty much on call 24-7.
