If this was your office what would you be flying?
boxcar
Post by boxcar »
Took this on Friay any idea what aircraft?
Its not having what you want. It's wanting what you've got.
Re: If this was your office what would you be flying?
Airbus A380?
grey_cap
Post by grey_cap »
Hurricane or Spitfire?
Something British I think.
fanspeed
Post by fanspeed »
Looks kinda like a Spitfire?
Ref Plus 10
Location: Wherever the winds may take me...and the paycheque
Post by Ref Plus 10 »
Muahaha Cat is wrong! That there's the new Boeing 787 Dreamliner.
oldtimer
Post by oldtimer »
It is the space shuttle Atlantis
small penguin
Post by small penguin »
Dont you folks see the big red button? This photo is clearly that of a B2 cockpit :roll:
boxcar
Post by boxcar »
You are getting warm it is British, I guess the glass cockpit is throwing you off ;>)
For a little more help see additional shot below.
And interestingly enough one of the pilots who will fly it was a member of the international team that completed the Operational Evaluation of the A380 and became one of the first pilots to qualify on what is now the world’s largest passenger jet not that it will help you much.
auto4
Post by auto4 »
harvard....
angry inch
Post by angry inch »
Looks like a Hawker Hurricane.
boxcar
Post by boxcar »
Only one flyable in North America.
just curious
Post by just curious »
Altimeter, airspeed, oil guages and yoke all suggest a spitfire. The angular cut on the bottom right part of the panel suggest a later mark, as does the compass mirror. Reflector gunsight is missing.
A Mark IX perhaps?
boxcar
Post by boxcar »
This shot gives a lot of clues.
gun mount.JPG (58.28 KiB) Viewed 1602 times
just curious
It has the leather footstraps like the mark IX
just curious
Fairey Swordfish?
C-GGGQ
Post by C-GGGQ »
well its a biplane with a rear gunner, I'm gonna go with swordfish as well
boxcar
Post by boxcar »
You got it! I thought someone would spot Bob Spence's name in the cockpit. This shows Bob and Chris Hadfield, now in the Vintage Wings Hangar undergoing engine rebuild.
l_reason
Post by l_reason »
I made an emergency landing at Spence's field a few years ago due to structural failure. After he towed my plane off his runway we went in the hangar to see that stunning aircraft. It is a work of art!
unknowingly upsidedown
Post by unknowingly upsidedown »
Is there a reason why the...looks like the RPM gauge, is on such a cant? is it to get '0' right at the bottom?
boxcar
Post by boxcar »
I suspect you are right on the RPM gauge anyone know for sure?
This shot is of the torpedo operators panel which is located below the pilots panel. You can just see the circullar seat . He would actually be lying on his stomach beneath the pilots seat looking through an open hatch in the floor. A small windscreen swings down to protect him from the wind.
Suddenly those Air Canada economy seats don't look so bad!
Lower panel.JPG (72.17 KiB) Viewed 1602 times
ktcanuck
Post by ktcanuck »
I seem to recall there was a time that engine instruments were rotated such that a "normal" indication had the needle vertical thus easier to spot anomolous operation during the instrument scan...maybe?
Hedley
Post by Hedley »
That fire extinguisher on the right side of the
cockpit is a bit troublesome ... note how it
has been mounted so that the release flips
down, which can easily be accidentally done
by anyone climbing into or out of the cockpit.
Maybe it's just me, but I really don't like
loose stuff rolling/flying around in the
cockpit. People can get killed that way. I
know a guy who's radio slid out under
negative G. It smashed him in the face
on the way out and punched a hole in the
canopy :oops:
just curious
Okay, I'm old. :oops:
Captain_Canuck
Post by Captain_Canuck »
On the subject of British airplanes. Some years ago, my father built a replica Spitfire and I thought I would post some pictures here for you all to see. It is powered by a 3.8L Ford V6 out of an SHO with a 2:1 reduction drive that he machined and engineered The structure (wings, spars, fuselage, tail) are all built from wood. Everything on this aircraft was made to exact spec as per the original. Through a family contact at Duxford, he was able to obtain an original Spitfire maintenance manual and replicated almost every part he could. There are even a few original spitfire instruments in the panel. This airplane was made at home in the family garage and at the time was my fathers 10th airplane he either rebuilt or built from scratch. Enjoy!
It seems I will have to post the pics in 2 posts!
spit driveway 2.jpg (56.08 KiB) Viewed 1066 times
spit cocpit 2.jpg (60.4 KiB) Viewed 1066 times
spit cockpit.jpg (51.19 KiB) Viewed 1065 times
Captain_Canuck
spit over the inlet.jpg (44.56 KiB) Viewed 1068 times
spit-drive way.jpg (52.66 KiB) Viewed 1065 times
A few more pics here
