Oh please don't tell me how to do my job! Do you have any 702 real world experience? Why do I get the feeling that I am talking to a student pilot?I don't know if I have a point to specify
what you described is just basic skills known as cockpit organization and evaluated during the PPL flight test.
I believe that if you would consider a GPS as a relief in a 125NM radius from your base in a tin can, unless you fly in extreme SVFR or IFR-wich is marginal in a tin can-, I'm afraid you should go back to school.
in other words, I would agree with you considering the GPS a relief in a King Air or bigger at a 5 digit altitude and in VFR (using the WAC charts), otherwise in IFR you don't need a GPS either.
copy ?
The cub is a lot tighter then your average ppl cessna & it's not as easier as you think when your banking 60+ degrees to take pictures. With no side slots, it's not as simple as putting papers on the dash. The only place I can put stuff is under my legs.
Take a look inside, not much room is there?
Now, I am not talking about replacing the papers for the GPS. That's crazy talk!
But the Garmin 196 is the kind of tool that can make life easier & that you cannot deny!
Anyways...this is going nowhere!
