An-2 plane
An-2 plane
An-2 plane, I invite to visit
a site http://www.an2plane.ru
section " About plane An-2 ".
http://www.an2plane.ru/an2/an2.htm
Photos of plane An-2, coin, mark, envelopes with the image of plane An-2, etc.
Were interested by plane An-2, I invite to visit
English language, I invite to visit
a site "www.mespeakpretty.com"
section "I Speaka Da Eenglush"
Photos of speaking english persons, monies, lettur thingz, etc with the english.
There ya go, jetblast. Hope that helped.
Sh*t. Now I feel like one of those Nigerian 419 scammers. Or at least my grammar is about as good.
- CaptainHaddock
Blue Side Down
An-2. Thank you
Good afternoon.
Thank you for having found time to visit this
informational resource, devoted to the industrious airplane.
I present my aplogies, that has not specified, that the resource http://www.an2pane.ru is Russian-speaking
My site is not commercial. The given theme - my hobby.
In future I will try to make the english-speaking part of this section.
Thanks all for good responses and wishes.
To fly by on An-2
If you had a desire to fly by plane An-2, but you didn’t have an opportunity to join the aeroclub or to get in property An-2, now you can establish a simulator of plane An-2 on your computer.
To ftp the program for installation of a simulator of plane An-2 you can on the web-address: http://www.an2plane.ru in section "About plane An-2" in subitem "Simulator of flight". There is placed the model of plane An-2 on the wheel chassis, with the instrument panel, a 3D-cabin with working devices, with a sound and the genuine instruction on airworthiness of plane An-2.
Good to you of impressions!
- Shiny Side Up
The answer to a question
The answer to a question.
For use of model An-2
1. First it is necessary install program Microsoft Flight Simulator 2004.
2. Instal model An-2.
The table of characteristics of some of the plane An-2
The table of characteristics of some updatings of the plane An-2.
http://www.an2plane.ru/an2/modifyc/modtable.htm
Jungle Jim
Bob Marsh in our RAA chapter was one of the guys that flew the one at Buttonville over from the UK. It was quite a flight for two private, VFR pilots. They did get lots of IFR experience real quick on the way over. They arrived at Gander and ended up taking a commercial flight to Ontario because they didn't have the ratings, equipment, etc and TC didn't like it when they offered to fly it back to the UK if landing at Gander was going to be such a problem. Apparently it used 20 gallons of oil on each leg that was poured in from inside the cockpit. Also the home made fuel pump had to be repaired with a shoe lace to seal a shaft on the last leg.
Sounded like a real adventure.
- low n over
shitdisturber
- Location: If it's Monday it's got to be somewhere shitty
linecrew
shitdisturber
10-th European meeting of planes An-2
Poland, Jelenia Gora. From August, 10 till August, 13th, 2006
http://www.an2plane.ru/an2/meeting.htm
Everything is now fixed for this week-end
Register sheet form
Register sheet form
There is one operating out of Stewiacke, Nova Scotia...Sky Diving operation... that is until recently I believe... I guess there are some issues with TC and Canadian certification... I believe it was operating under a loophole (for lack of a better term) with its origininal foreign registration.
For Those Who Like it.... Like it A Lot!!!
Yep, amazing airplanes. I've heard that in the original POH in the emergency procedures section, the prescribed response for vfr pilots that fly unexpectedly into IMC was to simply close the throttle and pull back on the yoke until the front slats popped out. Then the whole plane would decend at parachute-like speeds until it bumped into the ground.
Isn't that "Cinnamon Girl"? I know the guy that flew it across the Atlantic Ocean ... quite a trip. AFAIK it's still Polish registered, and flown by Polish-licensed pilots, and Polish-licenced mechanics. I'm told the Polish aviation authorities don't mind.Nova Scotia...Sky Diving operation
They tried to C-register it, but Transport would only let them register it as an experimental, and would limit the number of people on board to 2 (!) which would quite intentionally kill it's ability to haul jumpers.
I'm told it has something to do with protecting domestic aircraft industry - they don't want inexpensive ex-iron-curtain aircraft in Canada.
Avia-Retro. English version
The interesting information. Avia-Retro
http://www.an2plane.ru/en/an2/an2.htm
[/img]
