Trucks for the arctic
Its time to sell the old VW GTI and get a truck. I'm headed to yellowknife and was wondering if anyone had suggestions of a good tough cold weather reliable truck brand or model... I've heard the Toyota 4x4 are rust buckets. As i've been operating a small car i have limited knowledge in this area!
donnybrook
Re: Trucks for the arctic
my vote is the toyota tacoma. a bit biased because i own one, though! it's 8 years old, and has been through safety certification in at least 4 provinces since i bought it, and all i've had to change were light bulbs... the older (1980s) toyotas had problems with the box rusting out, but that has been solved quite some time ago.....not to mention that you'll see quite a few tacos driving around yellowknife, so i'm not alone in my opinion...!
Liquid Charlie
Don't worry nothing rusts out in YK
-- but the fuel will be close to $2/L soon -- a command start is nice for up there -- but get it installed in the south -- twice the price in YK --
ACTPA
ACTPA
Can't go wrong with Toyota for sure. The Tacoma is fine but if you got a few extra bucks consider a mid 90s 4RUNNER. Coverd back for security, extra space for dog/friends/hockey gear and place to sleep when you are between Yellowknife and Edmonton. Get a trailer and you have all the room you need. Mines got 275k and never missed a beat.
FYI YellowSkin is not the Artic.
Yes its cold and a Toyta is a good bet.
'effin hippie
Jeez.
The ol GTI will be fine. Throw in a block heater and make sure the belts are new and you will be able to get between your 'manufactured home', the hangar and the 'Range without any trouble. Aaand you will have an extra several grand to spend on booze. Which you will probly need.
ef
ef
Liquid Charlie
got a point --
ACTPA
ACTPA
just curious
- Rank Moderator
Effin' and the guy from the orange bank are right: "Save your money!"
Ecept if you could swap your VW for a diesel rabbit, and take out any of the over 2 year old jet fuel that helos won't use, and fill your car forever.
float ball
Think of Yellowknife like any other city just a bit colder. Paved streets, Canadian Tire, Walmart, definitely not the "arctic". Throw a block heater and a battery blanket in whatever you are driving and head north. Like the guys already said, command start and block heaters are double the price in YK so if you need them get them installed down south.
donnybrook
i'm sure you'd have absolutly no trouble with just keeping the GTI...but if you want a cool(in my opinion) toyota truck that would burn the old jet fuel you could look for a "hilux". turbo-diesel, right hand drive...
Bush League
http://arctictrucks.com/?PageID=1310
Everything else is just pretending...
Oh, and you don't need money for booze. Just make your own.
http://www.stilldrinkin.com/turbobootleg.htm
Knock off the hippie shit, strap on a helmet, and start shooting.
I used my Jeep Liberty there. The poor bugger survived the drive up (from YVR) to YK, to YVR, to YXY...
A. It needed some winterization... (oil) and so on.
B. I could still start it without a block heater in -35, I did that for weeks on end... No one knows how but she started.
She is still running... I have abused that truck beyond all belief... and she still goes...
I also knew enough people up there that drove anything, all types of CARS....
Wolfie
(PS she's good on gas)
Wolfie
Used truck prices are comming down now because of fuel prices so you should be able to find some good deals. 5k will get you a decent truck for sure.TrickyPig wrote:Its time to sell the old VW GTI and get a truck.
Toyota's good.... but is there a dealer nearby up there? Might be safer to go with what is common in those parts. likely chev.
I'd also go with a standard transmission... They can be pull started which is a handy thing in the north. Block heater's a must, 4x4 is not but useful if your doing some travelling up there.
I also have a GTI, a 1987 w/1.8 8v. It doesn't mind the cold at all as long as you change to a lighter grade of oil before winter like 5w30.
Matt.
- oldncold
hey if ya want to try something new and all wheel drive take a look at the sx4 from suzuki great on that expensive fuel and with a press of a button
presto all wheel drive not off road( bush blasting ) but good enough to get out of a 100 ft drive so ya wont late for work/ and good on ice too.
got a cd xm and all the bells and whistles for less than 22grand. new and good warranty. just go to andget a set of nordic winter tires and your set for several yrs of good motoring /ya I bought one so a bit biased but the wallet liked it and saves me a lot of money in gas vs a truck. has room for my big dog too /best of luck in yzf
- Cat Driver
I also have a new Suzuki SX4 and it is hands down the best all around vehicle I have ever owned.
You can choose from front wheel drive, automatic computer controlled four wheel drive or if needed you can lock all four wheels....but only on slippery surfaces.
It has all the extras such as climate control and a good sound system, four wheel ABS disk brakes etc. I choose the full seven year warranty so all I have to do is drop it at the dealer and take their courtesy car....even the oil is paid for.
And as a plus it handles like a rally car....great little machine!!
I'd agree with a few of the other posters; keep the VW if it is running good and it will be fine. Make sure and winterize it though, block heater and battery blanket at a minimum. If you have a bit of time throw an oil pan heater on it too. Command start would be great too, but if you are on a budget, I'd skip it and buy a coffee maker to keep a cup full of hot java in your hand when you walk out to start it in -30 or -45:) It doesn't get a whole lot colder than that on average here (as long as you don't count windchill) and the block heater is the big thing.
PP
PP
Some people are like slinkies: Not much good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Tip for anyone driving in the winter. Switch your oil over to synthetic for the winter. Using supreme gas(even if it is pricey) if you can get it will also help it start at low low temps. Also buy a PURE winter tire. I use blizzaks on my car..awesome.
Explain how supreme gas would help a car start better in the cold.Lost Lake wrote:Tip for anyone driving in the winter. Switch your oil over to synthetic for the winter. Using supreme gas(even if it is pricey) if you can get it will also help it start at low low temps. Also buy a PURE winter tire. I use blizzaks on my car..awesome.
This is a total guess, but the only reason why I can see regular gas causing cold start issues would be because of the ethanol content? I believe pure ethanol can lead to cold running issues. All the pumps i've been to lately say may contain up to 15% ethanol in reg gas. Who knows...
I would suggest using a pump that gets alot of business?
Less chance of water??
Also, if your building insists on cycling the power when it's -40 or colder, take precautions (starting every 6-8 hours).
