Re: Pic from a swamper
Thanks for that Bob - TNE looks pretty sharp.
Re SKY above though, aren't those Whips' it's on in Fiji?
The one pictured is not SKY. That is DQ-GWW SKY became DQ-GEE
Bob
Bob
Gotcha.beaverbob wrote:The one pictured is not SKY. That is DQ-GWW SKY became DQ-DEE
Bob
DQ-GEE Serial 1358
- 1358_DQ-GEE_Snorre_Nadi_17072006_565.jpg (290.95 KiB) Viewed 4880 times
- Rudder Bug
- Prairie Chicken
I guess more dual is required as I've had no joy with either suggestion.
Suggestions, or photobucket?
The pics in Photo Galleray are on my hard drive, and they're ones I imported from my Nikon. From Photo Gallery, I tried copy & paste between the img brackets, and get nothing.Are the ones in your Windows Photo Gallery on line or just saved on your hard drive? Did you upload them?
You can paste on here any photo or graphic that has a URL (http://www.whatsoever.jpg) Just right click on the photo and Copy, then right click to Paste them here, between the "Img" and "/Img" tags provided above.
That didn't work either. It starts to copy a file, runs for a bit, and then quits. Leaves me with nothing, just as before starting. I'm thinking the problem is the size of my files? They tend to be pretty big ... 2 + mb.Or if your forum 'User Control Panel' (forum top right) is set up you can just go to the bottom of the post entry - place where you write your entries - and select "Filename", "Browse", then "Add File" right from your computer.
Prairie Chicken
- Rudder Bug
Prairie Chicken
Go Photobucket, it's relatively easy and feel free if any question.
Good luck!
Good luck!
Hows this dock
Somewhere in the QC Islands
- Northcoast Air Beaver 1987-88.jpg (430.65 KiB) Viewed 4535 times
You're right...problem is the file size, to big. Reduce them in file size and dimensions and try it again it'll workQuote:
Or if your forum 'User Control Panel' (forum top right) is set up you can just go to the bottom of the post entry - place where you write your entries - and select "Filename", "Browse", then "Add File" right from your computer. End Quote.
Hey Beaverbob, NCAS? Can't read the name on the side but sure looks like GQA. Was that the one that was winched out of the water at Port Simpson? I have a photo in my logbook (not me!) but my old log is elsewhere. Rare sunny day. Love low tide and the dreaded dock pilings...
Xbank, Yes Northcoast in 1987 and the plane is FGQF. I think the dock is at Skidigate. I don't know which one was winched out of the water.The quality of the picture is due to scanning a dusty slide.
Bob Bates
Bob Bates
Bob If I remember correctly almost all of North Coasts planes have been winched out of the water at some time or other. Beechnut
Okay, dumb question, how is the best way to attach pics?
Click "post reply"
Scroll down to "upload attachment"
Click "choose"
Find picture on your hard drive from the screen that pops up.
Double click picture or picture file.
click "add file"
scroll back up and click "submit"
Note: Picture file will not upload if not a jpeg or is too big of a jpeg.
Click "choose"
click "add file"
- !cid_2206064654000005@web37913_mail_mud_yahoo.jpg (45.31 KiB) Viewed 4018 times
One more thing about posting pictures.
Scroll all the way to the bottom of any forum page and see the list of everything you can and cannot do.
It must say: "You Can post attachments in this forum"
Hope this is all clear enough.
Bob
Bob
Have you ever seen glassy water like this in Butte befor.
Not oftain.
I posted the wrong one and can't seem to remove it. The correct one has the dust mostly removed.
BB
Not oftain.
BB
- A beautifull reflection 1.jpg (560.99 KiB) Viewed 4002 times
I'm sure some will recognize this plane.
- 03-05-2005 5-50-43 PM_0069.JPG (391.76 KiB) Viewed 3999 times
hey Fabulous Phil, is that you? If not sorry.. VQD flew resort work last summer in Mb.. Saw Phil with her in Thompson last June....
Fly Safe
Fly Safe
cpd
A couple more.
- 30-04-2005 8-50-28 AM_0067.JPG (214.09 KiB) Viewed 3889 times
- 30-04-2005 5-26-31 PM_0068.JPG (429.6 KiB) Viewed 3890 times
- 19-07-2005 6-48-56 AM_0133.JPG (339.59 KiB) Viewed 3888 times
- Rank Moderator
I recognize the Sabourin Colours, but not that flippin' big beak!
- Siddley Hawker
That's the last Otter built by deH. Fecteau bought it off the production line.
A couple of pics from a cheap camera.
- DSCN2253_resize.JPG (36.16 KiB) Viewed 3640 times
- DSCN2042_resize.JPG (38.44 KiB) Viewed 3638 times
- DSCN1855_resize.JPG (45.46 KiB) Viewed 3633 times
Whatchew doing up above that 10/10ths puffy?
