Someone else has seen it (NAV/RAD) on a FMC????
Boeing 737NG simulator seeking pilot...
alphatango
Re: Boeing 737NG simulator seeking pilot...
Thank you Four1oh...
alphatango
Thank you Frog...
Then it seems that N1 limit is the only option...
Thank you for your help,
Al
Al
alphatango
An other question...
This is about A/T engage and disengage.
On each throttle handle there is a A/T engage and a A/T disengage...
So my interrogation is... If I engage the A/T on one handle only, will it engage A/T on both handles or only on the handle I engaged?
Also, when on A/T, if I disconnect A/T only on one handle, will it disconnect one or both throttle handles????
I hope this is not a stupid question.
I imagine it will interract on both handles but I have no way to insure except to ask here...
Thank you,
Al
Thank you,
Al
- throttles3-DC.jpg (103.16 KiB) Viewed 4956 times
Intentional Left Bank
Either one of the A/T engage (or G/A) buttons engage BOTH thrust levers. Similarly, pressing one of the A/T disconnect buttons disengages BOTH. A good question and we're enjoying the photos.
alphatango
Hi Intentional Left Bank,
How are you?
Thank you for your answer... This is what I expected to be but was not sure. Then I could reproduce the same...
BTW, I am still waiting for your visit...
Until now I received only one real 737 pilot... Very difficult for me to find because I leave in Quebec, witch is not the best place to find 737 pilots.... But still confident!
The photo above is from a real cockpit...
The next one is mine...
How are you?
- Throttles terminés 011-dc.jpg (142.82 KiB) Viewed 4938 times
The reason there's 2 of each button is because of depending on which pilot if flying, the throttles are configured so that either pilot(left or right hand) will be able to disengage the autothrottles with their thumb, or engage with an index finger comfortably.
Drinking outside the box.
alphatango
What a good reason...
Thank you for your explanation Four1oh
Jastapilot
I just want to make sure you understand the button you are calling the A/T engage button. As I understand it, it doesn't engage the autothrottles, it engages the TO/GA mode. The autothrottles are engaged by flipping the A/T switch on the MCP panel. Hope that helps.
alphatango
Jastapilot,
What a surprise! I thought both was the same action...!
Then I think I know what A/T is precisely... But could you explain in details what does TO/GA different from A/T?
Alain
Alain
alphatango
System annunciator panels
An other question to make the system working as closed as real one...
This is about "RECALL".
Let say that I have a Warning Caution light illuminated telling me that I have a FUEL problem. If I push on the Warning Caution button it will turn off the "FUEL" annuncement on the "System annunciator panels".
So, before fixing the problem if I push the "RECALL" button, will it illuminate ALL indications on the "System annunciator panels" while pushing on the "RECALL" button to finaly let only the "FUEL" light "ON" or will it illuminate ONLY the "FUEL" ligth while pushing on the RECALL button and once released?
This is not something very very important, but as we are making the programmation, why not do that as close as possible!
Thank you,
Al
Thank you,
Al
- System annunciator panels.jpg (113.62 KiB) Viewed 4674 times
Jastapilot
correct, but don't call it a 'warning caution', it's the 'master caution'.alphatango wrote:System annunciator panels
Every time you press the RECALL button, it's a light test. All lights on that and the other pilots 'Recall' panel will light up. Any existing fault will remain illuminated after you take your finger off the button. This is why we press RECALL as part of the landing checklist. That way you'll know right away if there's a fault you didn't know about, and you don't want to be landing if there's a fault you haven't dealt with.alphatango wrote:So, before fixing the problem if I push the "RECALL" button, will it illuminate ALL indications on the "System annunciator panels" while pushing on the "RECALL" button to finaly let only the "FUEL" light "ON" or will it illuminate ONLY the "FUEL" ligth while pushing on the RECALL button and once released?
alphatango
Jastapilot,
Thank you very much to have take the time to answer my question once more...
Your help from you all here is very helpfull and is the only way very often to know the real working of a so complex machine... and wonderfull also
Al
Al
- 737NG.jpg (157.17 KiB) Viewed 4645 times
Jastapilot
you're welcome! It's easy help, and I hope to some day see your sim! We'll see how she barrel rolls!
alphatango
scorpioflyer
Alain
I am not a B737 pilot, I fly B1900 and have flown Saab 340. I have also many flying hours as a Flight Engineer on DC8, 747, and L1011's. I operate daily from Montreal to Quebec City, and I am here all day from morning until about 6 in the afternoon. I have picked up an interest in home built simulators, and am presently doing research for a possible project having already added your site to my list of favorites as a future reference. Today I was in the AvCanada forums and started to read the posts in your thread and what a nice surprise to see a link to your site that I had already in my list. I think what you have accomplished deserves high praise indeed.
I cannot help you in terms of the flying characteristics of the 737, and to simulate as real as possible the systems of the 737. As a matter of fact I have more to learn from you, than you from me but I would be grateful if you would allow me the opportunity to visit and fly your sim and perhaps I can help you with any questions that you might still have in terms of flying in general.
Thank You
Antonio
Thank You
Antonio
alphatango
Hi Antonio,
And welcome in the world of "Cockpit builders"
Thank you then for your interest. It would be very interesting to be abble to fly together and I think we could learn for each other you and me. The problem would be transport. I explain... I leave at about 45 minutes from the airport. So if you can move by yourself there is no problem at all. But if I should go to take you there and return it means a 3 hours trip...
I think the main difficulty is there. But as I said, if you can move by yourself we could certainly arrange some sim sessions...
Just PM me if you want to make some arrangment.
Thank you,
Al
Thank you,
Al
scorpioflyer
Alain
I will send a msg to the email address on your website
Antonio
Antonio
alphatango
alphatango
Hello to all,
I am back after a long period of time.
Although I have not worked very much on the simulator this summer, I still made many improvements, which today is about 80% functional. Among the recent changes there are two FMC's which one is fully functional. In addition, very soon I will have three screens for external view then making landings and takeoffs more realistic and enjoyable.
For the moment only the real radios are missing, that should be added later next winter. Currently they are functional by software on a touch screen, which is still pleasant because there is no need of using mouse..
Then I am back with my search for a real 737 pilot or on any other commercial aircraft, which would be interrested in coming flying the simulator with me. For me the main interest is to learn the real techniques of flight, checklists, procedures etc.
So those who have already contacted me, if the interest is still present let me know, I am now available. For new interrested pilots, just tell me your interest by email or private message here on this forum.
Many thanks,
Alain
Many thanks,
Alain
DAVE THE RAVE
Just a side note about the steering. Rudder pedals give 7 degrees, while the tiller can steer up to 78 degrees.
alphatango
Hi everyone,
Thank you for that precision Dave!
I said I would keep you informed about the developments of my sim and on my site, so here it is...
Everything is in the home page. Like always, few text and many pictures ... a picture is worth 1000 words!
I had some problems during this update, then it is not complete ...
I have not been able to add more detailed pictures, just small ones, but it is a matter of time.
Also the link to the photos of the FMC does not work. It will be fixed soon.
But there are still a lot of news on my site which makes the visit worthwhile ... at least I hope!
So good visit!!
So good visit!!
- MIP_OH_SEAT_FMC 028-S_001.jpg (478.82 KiB) Viewed 4199 times
Incredible work! Amazing!
alphatango
Hello Four1oh...
Thank you
I am approaching CYUL right now in a very low visibility...
a lot of work to do here... I am alone without any FO
Thank you
alphatango
Hello to all...
Some news...
I recently removed and sell those throttle I previously built to replace them with real one I found and rebuilt. Actually I am at the end step of the programmation for these great new throttles.
And I have a new question for you!
I need to know what happens if the AutoPilot is "On" and if the pilot activates the trim up or trim down button on the yoke. Normally if the A/P is on the trim wheel is controled by the A/P system. But, if someone activates the trim up or down button, does it turn the A/P in the "OFF" position, or something in the system desactivates those trim buttons so that even if you activate these buttons it wont move the trim ajustment??
Thank you for your great help...
Alain
Some news...
Alain
