2 Crew machines
eep...2 Green
2 Crew machines
Post by eep...2 Green »
Anyone know of a list of smaller aircraft (less than...say...50000lbs) that are considered 2 crew by TC? Looked up and down their site and came up with nothing.
spoiler
Post by spoiler »
beech 1900
The bigger king airs...350.
swept wing smaller jets.
I am sure there is a lot more, but all I could think of.
zaac
Post by zaac »
eep...2 Green
thanks zaac.
greenwich
Post by greenwich »
Nice work 'zaac'...and thanks for the 1/2-mast image '2-green'.
Hey, can someone (Borek guys) explain this:
A/C:
Embraer E110 / Embraer Banderante
Req'd. Crew:
1 VFR
2 Night
2 IFR
Tks,
G
maxofthenorth
Post by maxofthenorth »
What do you need to know... it is basically the same for the DHC-6 too!
oldtimer
Post by oldtimer »
A lot of pilots (and others) always get airplanes and the rules under which they fly mixed up. A two pilot airplane is a two pilot airplane, first and foremost, if the manufacturer says it is, period. Now, the manufacturer is bound by the certification rules which states that any airplane certified as a Transport Category Airplane ( USA FAR 25 or CARS 525) has a minimum of two pilots, or 3 pilots, or 12 pilots, whatever, depending on how the questions in the certification process are answered. That means that any airplane with a max take-off weight in excess of 12,500 lbs or a turbojet are two pilot airplanes.
In Canada, any airplane, FAR 23 Normal category - CARS 523 (Small) multi or single airplane, flown for hire and reward, must be crewed by two pilots unless an Operations Specification has been granted to allow single pilot operations. I do not know for a fact but if Embraer Bandit was never certified with an auto-pilot. If not, it must be flown by two pilots, however if Embraer or someone else obtained an STC for an autopilot, walla- single pilot.
Now things get interesting, the Beech 200 was hampered by certification limitations. Live with a Max take-off weight of 12,500 or certify as a FAR 25 airplane. Same for the Metro 2 and others. Too expensive. Lobbying the FAA, manufacturers convinced the regulators to increase the weight limit and the feds did. First as a "prototype" standard called sFAR41, and then from the lessons learned, FAR 23 CC. Commuter Category. Up to 19000 lbs and/or 19 seats, excluding crew. Hence the Beech King Air 300, Metro 3, J32 and Beech 1900C.
The Beech 1900/ J31/ SA227 are flown as a two pilot airplane because you require a flight attendant/ cabin safety person after 9 passengers and a co-pilot will work cheaper than a F.A/autopilot combo so most of those airplanes are built without an autopilot. The F.O is the autopilot - voice activated!!!!
That is why they allowed females on the space shuttle - lighter than a dishwasher!!
The Beech 350 is a single-pilot airplane but here in Canada, too many restrictions for commercial operators, so the voice activated autopilot thing. Except that most King Airs come off the factory floor with an autopilt, much like a Buick always has air conditioning.
Ed Swearingen is attempting to certify his new jet to FAR 23 CC which will put it in the single-pilot category. In the USA, the second pilot under FAR 91 or 135 does not have to be type rated so most airplanes are built with the idea that all the brains are in the left seat so the right seat pilot does not have the same flight instruments etc. The Dash 8 is usually a FAR 25 airplane operated under FAR 121 so those airplanes have almost identical cockpts, left and right.
Some Russian jets are so mechanically complex they require 2 pilots and up to 4 flight engineers.
Airbus and Boeing were able to automate so many systems and reduce the pilot workload that they were able to eliminate the fright engineer.
All depends on how the manufacturer wants to build his airplane.
Hope this answers some questions
Skipper
Post by Skipper »
Holly Crap 2 Green!!!!
That picture you have of the kid...F-in' Pricless buddy!! I'm still laughing my ass off and I've seen it ten times!!
You're alright 8)
switchflicker
Post by switchflicker »
Good description Oldtimer
Here's my two cents
The Banderante Type Certificate stipulates 1 pilot VFR and 2 for night or IFR. Passenger count not considered. This is unusual.
The Metro/Merlin family Type Certificate says minimum crew 1 pilot unless 2 required by operating rule. The operating rule in Canada would be CAR 702, 703 or 704. These regulations say among other things that if the passenger count is greater than 9 the crew composition must include another pilot or a cabin attendant. Like Oldtimer says a Co-Joe is cheaper than a Bun Gunner. The operating rule also says that if the flight is to be IFR with passengers, the minimum crew is to be 2, unless authorized by way of an Operating Specificition (sp). This is where the Bandit differs. Bandit says IFR (no pax stipulation)
By the way Oldtimer, never heard of the First O as a voice activated auto-pilot. Very good. I always thought F/O was abreviation for Flap Operator
"I'd rather have it and not need than to need it and not have it" Capt. Augustus McCrae.
eep...2 Green
Thanks Skipper...
I_Drive_Planes
Post by I_Drive_Planes »
Just out of curiosity, if you were to own and operate an aircraft listed by TC as 2 crew privately, could you fly it single crew? If not, is it possible to add some equipment (i.e. autopilot etc.) and have its category changed?
It is one of my lottery winning pipedreams to buy a DeHavilland Caribou and fly about the countryside, however much to my chagrin, I see it is listed as 2 crew by TC.
Skipper
Post by Skipper »
Hey Planes
It's my understanding that if you own a two crew aircraft but don't use it in a commercial operation, you can do whatever you freakin' want. Even if you are a commercial operator and you are just moving the plane about "non-revenue" I know there is some leniency there as far as the normal requirements are concerned. However, Transport being as fickle as they are, will probably give you a sideways look and a slap on the ass if they see you doing it too much. Of course that depends on their mood at the time...Bunch of manics.
There it is again 2 green! Thanks for keeping me entertained!
J31
Post by J31 »
I_Drive_Planes wrote:Just out of curiosity, if you were to own and operate an aircraft listed by TC as 2 crew privately, could you fly it single crew? If not, is it possible to add some equipment (i.e. autopilot etc.) and have its category changed?
If it says 2 crew then legally 2 type rated pilots are required to operate the aircraft regardless of how you are running it…….private or commercial.
As for the Caribou if you want to carry your buddies then a operating certificate is required be it CAR’s 604 or one of the CAR’s 700’s.
I_Drive_Planes
J31 wrote: If it says 2 crew then legally 2 type rated pilots are required to operate the aircraft regardless of how you are running it…….private or commercial.
Now that completely screws things up, Thanks for the responses guys.
Skipper
Post by Skipper »
Damnit!
I'm pretty sure you can fly the dang thing around by yourself if you're a private operator, nut then again, I've never owned a Caribou. Animal or machine...I hear they smell
The Old Fogducker
Post by The Old Fogducker »
Skipper:
If the guys that designed and built the airplane say it needs two pilots, it needs two pilots regardless of whether it is flown in commercial or private service.
That was an excellent description of the situation by Oldtimer. It should almost be made into a "sticky" at the top of the page, as the question is asked frequently.
Time for me to return to ducking the fog for awhile! Oh .... I think I see a cannine now!
Regards,
Fog
Skipper
Post by Skipper »
I think we're both right
I know something like the EMB-110 is a two crew bird as both pilots do a PPC on it, and at least require and ATPL/IATRA to crew it, however, the Captain can take the thing solo if it's day VFR and nine or less (less than nine? gotta love the CARS!) That's in a commercial operation, so I would imagine the same goes for private
therubberjungle
Post by therubberjungle »
As far as I know the Bandit was never certified for single pilot IFR operation in Canada. An F/O is way more useful and ultimately cheaper than maintaining old autopilots, or so it was explained to me.
One pilot is okay for day VFR provided there are not more than nine pax.
therubberjungle
Nuts,
I could have read oldtimer's post, it would have saved me some typing :)
