I love the CARs.
either way yes CFIT is an issue in aviation but 3 miles would not really be considered Min VFR
I don't know what conditions you consider inappropriate but I would be quite interested to know what commercial flight experiance you have and where you gained that experiance?I'm seeing pilots using the rule change now to transit the zone when it's obvious the conditions are not appropriate.
I observe the same thing, but also with arrivals and departures. Many times ceiling was around 600ft and crew departed / arrived anyway without SVFR. How can this be possible?GilletteNorth wrote:I'm seeing pilots using the rule change now to transit the zone when it's obvious the conditions are not appropriate.
That's right but when they have departed, or before they start their "arrival phase", they must be 500ft AGL and 500ft from clouds. Therefore in order for a pilot to depart or arrive when ceiling is below 1000 ft, the ceiling MUST be higher outside the airport so when they are not in arrival or departure phase, ceiling is 1000ft or higher.GilletteNorth wrote:I should mention that the rule concerning 500ft AGL and clear of cloud does not apply to departing/arriving aircraft. You may be less than 500 ft AGL but still have the requirement to remain clear of cloud during arrival/departure.
Actually the rule concerning 500ft AGL and clear of cloud does not apply because you are in a Class E Control Zone. They can be less than 500' BUT the ceiling still has to be 1000' (VFR) to allow the 500' cloud clearance, otherwise a Special to depart/arrive IS required. If the airspace they are entering on departure from the 'zone' is Class G and they intend to remain below 2200' agl, all they need is 'clear' of cloud (plus required vis). If they intend to climb above 2200' the ceiling would have to be 2700' to allow them to be the 500' clear (below) of cloud. Don't forget that a 'transition zone' may be around the airport basing the class E at 700' agl; class G below.Jonathan wrote:That's right but when they have departed, or before they start their "arrival phase", they must be 500ft AGL and 500ft from clouds. Therefore in order for a pilot to depart or arrive when ceiling is below 1000 ft, the ceiling MUST be higher outside the airport so when they are not in arrival or departure phase, ceiling is 1000ft or higher.GilletteNorth wrote:I should mention that the rule concerning 500ft AGL and clear of cloud does not apply to departing/arriving aircraft. You may be less than 500 ft AGL but still have the requirement to remain clear of cloud during arrival/departure.
I'm not a commercial pilot. What I AM is a FSS with years of experience observing weather conditions. If you are a pilot, it's fairly obvious what conditions I'm referring to
so if I'm 100 miles north of Yellow knife at FL170 what class of airspace am I in?The only time clear of cloud applies is when the airspace & airport lay in class G which is topped at 2200' agl.
You have to ask? Class G and only because you (I assume) are nowhere near airways or airports which is what the Class E surrounds. Remember, again, we are talking about Special VFR and that means Control Zones.so if I'm 100 miles north of Yellow knife at FL170 what class of airspace am I in?
Because if they didn't S P E L L* I T * O U T people like you would think that at night its okay to enter cloud just because you can't see them. Its TCs way of saying; day or night - same rules apply BUT you need more vis at night. I think too that TAFs, METARs and GFAs apply - you should have in idea where you'll find cloud - avoid it.Just for shits and giggles can some one tell me why there are distances from cloud at night?
alright you busted me.......I know there's a pretty picture of Airspace and the different rules for vis anyone have a link to it?Now please stop trying to stir the sh*t and let those that don't get it, and want to learn, do so without dumb comments - thanks.
Sorry if I accidentally misinformed anyone. I looked in the CARs and read that section in the uncontrolled airspace rules section and should have gotten it right. I guess I got confused having read the rule and thinking the aircraft has to decend below 500 ft at some point to land. But it goes to show I was correct in thinking pilots should not be transitting the control zone to land without having 500 and 500.I should mention that the rule concerning 500ft AGL and clear of cloud does not apply to departing/arriving aircraft. You may be less than 500 ft AGL but still have the requirement to remain clear of cloud during arrival/departure.
and it starts... (AOR filed yesterday)GilletteNorth: All it will take is one or two instances of an IFR aircraft doing the approach and popping out under the cloud deck coming too close to or even colliding with a low flying VFR aircraft transitting the zone without having requested SVFR when it should have, for the decision that changed the method of applying the SVFR rule to be reversed again.
Aircraft1 IFR-inbound for runway XX. Numerous VFR aircraft waiting for SVFR to enter and exit the control zone. Aircraft2 (vfr) first reported 20 E inbound, an airport advisory was passed including the IFR traffic and the ceiling at 500 feet (visibility was 8 miles). Aircraft2 proceeded inbound for landing runway XX without requesting SVFR and joined a 4 nm final with Aircraft1 procedure turn inbound. Aircraft1 stated he would have to miss because he didn't have traffic in sight. Aircraft1 broke out of cloud at the VOR and advised he had traffic in sight and would cancel IFR and circle for runway XX. Traffic information was passed and updated frequently between the Aircraft1 and Aircraft2. Aircraft1 landed safely runway XX. The pilot for Aircraft1 expressed concern at the presence of Aircraft2 in IMC weather.
There was one out this way a few weeks ago with an IFR and a float driver - claimed he wasn't in cloud but that's where they 'found' him. (Uncontrolled airspace)GilletteNorth wrote:and it starts... (AOR filed yesterday)GilletteNorth: All it will take is one or two instances of an IFR aircraft doing the approach and popping out under the cloud deck coming too close to or even colliding with a low flying VFR aircraft transitting the zone without having requested SVFR when it should have, for the decision that changed the method of applying the SVFR rule to be reversed again.
&ceiling at 500 feet (visibility was 8 miles)
Sorry, but he wasn't VFR either and can't/shouldn't cancel the IFR, unless he too requested - and got - the Special.Aircraft1 broke out of cloud at the VOR and advised he had traffic in sight and would cancel IFR and circle for runway
That doesn't seem right to me!GilletteNorth wrote:Aircraft1 IFR-inbound for runway XX. Numerous VFR aircraft waiting for SVFR to enter and exit the control zone. Aircraft2 (vfr) first reported 20 E inbound, an airport advisory was passed including the IFR traffic and the ceiling at 500 feet (visibility was 8 miles). Aircraft2 proceeded inbound for landing runway XX without requesting SVFR and joined a 4 nm final with Aircraft1 procedure turn inbound. Aircraft1 stated he would have to miss because he didn't have traffic in sight. Aircraft1 broke out of cloud at the VOR and advised he had traffic in sight and would cancel IFR and circle for runway XX. Traffic information was passed and updated frequently between the Aircraft1 and Aircraft2. Aircraft1 landed safely runway XX. The pilot for Aircraft1 expressed concern at the presence of Aircraft2 in IMC weather.
Interesting. I suppose you could argue that point but then everyone could say the same thing; 'I was in the valley not over the hill'. I would think that TC's legal would say some thing more like this:faszkalap wrote:Here's a situation where you can maintain VFR with a reported vis greater than 3SM and ceiling lower than 1000ftAGL. Station elevation is 350ftASL. Ceiling is reported as 800ftAGL. An aircraft is transitting along the shoreline at 500ftASL but within the control zone. That puts him at 500ft above ground/water and 650ft below cloud. Sounds like VFR to me.
That means weather less then the required visibility and distance from cloud for VFR in controlled or uncontrolled airspace is IMC. Which in itself means that you don't have to be physically 'in cloud' to be legally found to be 'in cloud'.CARs 101 - - Interpretation: "IMC" or "instrument meteorological conditions" - means meteorological conditions less than the minima specified in Division VI of Subpart 2 of Part VI for visual meteorological conditions, expressed in terms of visibility and distance from cloud;
Mother F.... jk... Mandatory Frequency.... the "Controller"W0XOF wrote:What's an MF operator......................
