SA also applies to walking on the ramp.....
mcrit
Post by mcrit »
Here's the situation;
We were at a small airport in North Western Ontario over the weekend. We had just finished prestart checks (so nav lights had been on for a while as had strobes) and were just about to hit the starter when the fellow in the front exclaims "Fucking Moron!". I figure that he must be talking about me and do a quick cockpit check. I catch some motion in the mirror, and there, low and behold, is Shaggy of Scooby-doo fame (or at least his doppleganger) strolling RIGHT behind the a/c with his girlfriend (they had landed and parked their Bonanza across the ramp a few minutes earlier). Moral of the story? Keep an eye on what the a/c around you are doing when you are on the ramp. Not every pilot is going to check behind him before he starts up. The other moral? Check behind you before you start up.
AMM
Re: SA also applies to walking on the ramp.....
Post by AMM »
And what aircraft was this you were about to start up?
mcrit
Post by mcrit »
A Harvard II.
Nark
Post by Nark »
Tell me about it.
Got sand blasted with the girlfriend when we were both cleaning the plane. It's not as if he didn't know we were right beside him, as we said "hello" before he walked out to his trusty steed.
Evidently airmanship isn't alive and well...
Semper Fidelis
crankedup
Post by crankedup »
I don't recall any real problem with a bit of propwash. Were you planning a full-power runup there on the ramp?
I've walked behind a plane that was idling. It was just a little breezy. It's not like it could back up over me.
Maybe I'm not aware of something here. If you're not on gravel doing a full power start up, what could happen?
-istp :smt017
linecrew
Post by linecrew »
istp wrote:I've walked behind a plane that was idling. It was just a little breezy. It's not like it could back up over me.
-istp :smt017
+1
Brewguy
Post by Brewguy »
You don't have to be on gravel to have a small stone or other small debris blasted into your face (eyes, etc). Not all pavement is swept clean on a regular basis.
That said, the prop wash from an idling a/c usually isn't all that bad. Ask any air cadet / glider pilot whose worked the 'windy end' checking the rope hook-up behind a tow plane.
I've only ever gone up to the tail end of an idling a/c about 6,000 times.
Brew
PT6-114A
Post by PT6-114A »
better that buddy walked behind than right by the propeller. As for why you care as it was not you walking behind. As for the type of A/C some one could have been standing there for and hour before it taxied away!
One of the apprentice lackeys I use to work with walked right in front of a T-33 that was running (less than an arms length from the nose) . Maybe no danger of getting sucked in, but it's the principle of the thing.
If he would have walked around the back, he probably would have had no hair, clothing, or skin left. Very important to make sure nobody is behind you when starting a jet with engines close to the ground. The idle exhaust will burn you before it will blow you out of the way. Another apprentice lackey found that out when he wanted to watch a 727 light off at night from a scissor lift 50 feet behind the aircraft. (Yeah, I worked with some real winners...) :roll:
For physically walking behind a prop plane, yeah, no big deal. I've been five feet behind a 14 foot propeller (engine leak checks) and survived. But I am trained to do it and the person upstairs knows I am there. If someone I didn't know was walking behind the plane, I would not start it either. You don't know what they are going to do. Do they have unrestrained children? Do they have a dog? Are they all there?
We must remember that many people aren't too airplane savvy, even some pilots and AMEs! :lol:
mcrit
Post by mcrit »
I'm not sure just how hot the turbine exhaust is by the time it gets to the tail (at least on start up) but I wouldn't want to find out by experimentation.
Brewguy
Post by Brewguy »
Ah, now there's a good point. We've been talking mainly about piston not turboprop. Forgot you were talking about a Harvard II.
Brew
Flybaby
Post by Flybaby »
mcrit wrote:I'm not sure just how hot the turbine exhaust is by the time it gets to the tail (at least on start up) but I wouldn't want to find out by experimentation.
PT6A-68 engine
Most likely just a warm breeze, the only way I could see you burning your self would be hugging the exhaust pipe.
linecrew
Post by linecrew »
PT6A-68 engine
Agreed...and this is from my personal experience.
FlaplessDork
Post by FlaplessDork »
Brewguy wrote:You don't have to be on gravel to have a small stone or other small debris blasted into your face (eyes, etc). Not all pavement is swept clean on a regular basis.
I'd rather get a rock in the eye than a prop in the face.
KnownIce
Post by KnownIce »
Laos Airlines SOP seems to include lining up the passengers to board the rear exit on the ramp behind running turboprops. Warm but not uncomfortable.
Colibri
Post by Colibri »
Years ago I had to remove the GPU cable from a Harvard II while it was running; no big deal. Just a really shitty blow job.
On a side note, what is it with Harvard II pilots turning their strobes on when they're on the ramp and taxiing? Not so bad during the day, but at night it definitely shows poor airmanship. We've had to get tower to ask them to shut their strobes off when taxiing behind them at night.
