Google Belly tip ad
- GilletteNorth
Google Belly tip ad
You know, I really hate that ad I keep seeing... you know the one...
1 tip of a flat belly: cut down 3 lbs of your belly every week by using this 1 wierd old tip.
Seriously, instead of advertising there's a tip that cuts down 3 lbs, just FARKING SAY IT. If it's an old way of reducing weight just share it. Anyone know what the tip is?
Re: Google Belly tip ad
Shit more.
- Rank Moderator
Fly 704 and implement SMS.
The stress will make you shed at least 10 lbs, no?
Semper Fidelis
Semper Fidelis
- Rank Moderator
Simple:
Eat 'x' calories, burn 'y' calories. If x-y is positive, then gain weight; if x-y is negative, then lose weight.
IIRC 1lb=~3500cals
IIRC 1lb=~3500cals
Happiness is V1 at Thompson!
Jastapilot
Best weight reducing idea yet!Bushed wrote:IF it tastes good spit it out!
Did you not click on the ad on Avcanada?
His trick (he says) is to eat different foods (like the cavemen). A constant variety of food will cause you to lose weight....
If you eat the same food all the time your body (apparently) will start storing the food as fat.
Of course you have to buy the plan to hear the rest of the spiel.....
