Ski Plane Guys
Widgeon Guy
Ski Plane Guys
I found this Ski in my shop not sure where it came from or what it is off.
Does anyone recognize what it would be off. I would say a tail ski Otter?
The Federal Ski Corp.
ANN1200
Max 2500 lb.
Manufactured 11-57
Recommended 1200 lb.
ANN1200
Max 2500 lb.
Manufactured 11-57
- 0101101636a.jpg (61.15 KiB) Viewed 2349 times
- 0101101635a.jpg (149.57 KiB) Viewed 2349 times
Re: Ski Plane Guys
I really don't think that is an Otter tail ski. At least I have never seen an Otter tail ski like that open on one end. It almost looks like a nose ski of a 206. All tail ski's I've seen or used were closed on both ends.
Re: Ski Plane Guys
I don't think it's a ski for an otter either,...it seem smaller than the one I use on my 185...and the weight doesn't fit too,...2500lbs seems way to light for an otter...
Je me souviens
- northwings
Re: Ski Plane Guys
I would have to agree with Brewhouse. It definately looks like a 206 nose ski.
Nothin' beats the hobo life, stabbin' folks with my hobo knife
Re: Ski Plane Guys
I don't know what its for.....but...since it's manufactured in 11/1957 I would say its a safe bet it isn't for any of the cessna products, at least not a 206.
Give
Give
Re: Ski Plane Guys
i would guess a nose ski as well. Looks like it is meant to travel only in one direction.
Re: Ski Plane Guys
How long is it and what is the axle diameter?
That's not an actuator, it's a damper, isn't it?
That means it's a fixed protusion ski and I would think eliminates it as being a nose-ski.
It's a tail ski off something. 1200lbs is a high wt for a tail ski though..
Fairchild Husky?
Siddely Hawker might know.
Fairchild Husky?
Re: Ski Plane Guys
Maybe Piper TriPacer or Colt front ski?
The older I get the better I used to be
- Siddley Hawker
Re: Ski Plane Guys
HS I think you got it. Hard to see in this pic though.
Re: Ski Plane Guys
Cool - I love being right, and better yet, knowing who to call..
(Thanks S.H.)
Anyhow, would be great if we could confirm this. Are there better (closer) pictures out there?
One thing that I think bodes well for the Husky is the "1200 LBS".
When you look at where the tail wheel is on that airplane, you can see that there's a hell of a bunch of weight on it.
Is that a photo you took Siddeley Hawker ? Which one is it?
I was involved with CF-MAN at one point but I have a feeling it's CF-EIM in your picture.
'48
'48
- Siddley Hawker
Re: Ski Plane Guys
HS, no I didn't take that pic, it's from Austin Airways. And that's SAQ, or as the boys from Austin called it, Sad And Queer.
Re: Ski Plane Guys
Ha-ha; well at worst, my chances were about 1 in 12 or better at getting the registration right.
'48
'48
