Air Transat A330 Question
lowlevel
Post by lowlevel »
Here is a question for an A330 skipper. Flew home last week on the A330 and it seemed whenever the brakes were applied there was a metal pipe like, banging sound (quite loud) and it also seemed when they released the brakes the banging sound was present just not as loud. Can't say that I heard this noise going south (as we were sitting relatively in the same spot near the centre of the A/C). Is this normal or abnormal. In all very good trip with TS396 and 397.
june 1944
Re: Air Transat A330 Question
Post by june 1944 »
Maybe it was a little Mexican stowaway? Perhaps someone making a "run for the border"? In all honesty, I don't know, why sweat it if you made it home safely. I'm sure it was a normal operating sound as there are many noises that come from below that sound different depending on the individual aircraft tail /environmental factors/wear of parts, etc.
loopa
Post by loopa »
lowlevel wrote:Here is a question for an A330 skipper. Flew home last week on the A330 and it seemed whenever the brakes were applied there was a metal pipe like, banging sound (quite loud) and it also seemed when they released the brakes the banging sound was present just not as loud. Can't say that I heard this noise going south (as we were sitting relatively in the same spot near the centre of the A/C). Is this normal or abnormal. In all very good trip with TS396 and 397.
You're right, I had the same sound... most noticeable around Seat 28 A area rather than the other side for some reason. It almost sounds like a train applying brakes.
whiteguy
Post by whiteguy »
It is the brakes. Normal sound on the airbus.
Niodatchi
Post by Niodatchi »
Yes normal sound especially on "Heavy" airbuses. Nothing to worry about. Just realise that each main landing gear consists of a boguey with 4 wheel. And each wheel has its own brakes. So it's normal that it makes that sound when we release the brakes. Hope it reassures you, cheers, Nio :D
