google satilite images
ScudRunner
Cool Map link, google maps you can zoom in on almost anywhere
Try Vancouver check out the Indy Car track set up by BC place and YVR
http://maps.google.com/maps?q=jfk&ll=40 ... &t=k&hl=en
Thats preety sweet!!!
I zoomed in on on Point Pleasent Park in Halifax, and followed the Bedford highway to Sackville, then to middle Sackville, to my old house on Sprinfield Lake.
...making me miss Halifax!!!
Thanks . for giving me the ability to check out some of my old stompin grounds.
Cheers.
Cheers.
Chase lifestyle not metal.
I was looking at Calgary on this, and they've got most of the city in good resolution, but the northwest appears to have only older farther out images.
But I think the pictures were taken back when Calgary hosted the G8. If you look at the airport you can see the Japanese 747's, one at the still under construction terminal, and the other parked over by the purolator building.
Corporate Pilot
I found this one last week while looking for a Chicago area address.
The image captured a JET IN FLIGHT! It's probably impossible to determine the altitude of the Jet.
It's probably taking off from MDW (Midway) which is about 6m NE from this position; zoom out, you'll see it. As I reflect on the layout of MDW, it certainly seems like an efficient in-city airport.
Google just aquired KeyHole, that is where they have aquired the technology from.
Keyhole has a free 7-day trial of there commercial product, it is worth downloading. Very Neat.
http://www.keyhole.com
SkyKing
SkyKing
Now that's neat. Yes MDW is quite a busy airport with plenty of Southwest aircraft filling the tarmac.Corporate Pilot wrote:I found this one last week while looking for a Chicago area address.
Here's a neat little program to view pretty much all of the US aerial photography....
http://jdmcox.com/
Lots of Positioning and GIS utlilities are here...if you have a hand held GPS, you can do alot of neat things with it...esp 3d Maps...
http://www.digitalgrove.net/3DMaps.htm
Lots of free spaitial info data avail from Geodetic Survey of Canada..
http://www.geod.nrcan.gc.ca/index_e/index_e.html
Just to give you an idea of what you can make....this is a route around the outskirts of Calgary...more specifically...
UofC - Kan Loop
24th Ave NW
Crowchild Tr S
Glenmore Tr
Macleod Tr S
all the way to....22X to Deerfoot Tr N
Country Hills Blvd.
Nose Hill Dr.
Crowchild Tr S
32nd Ave N
UofC - Kan Loop
Yea..I'm a big geek.
http://jdmcox.com/
UofC - Kan Loop
24th Ave NW
Crowchild Tr S
Glenmore Tr
Macleod Tr S
Country Hills Blvd.
Nose Hill Dr.
Crowchild Tr S
32nd Ave N
UofC - Kan Loop
ScudRunner
corporate pilot
Try'd to find some of the big burn patches from last summers fires in the yukon but there not that up to date.
Anyone been able to find Area 51 didnt have anyluck.
Is it just me or does it look like that 727 is just parked in the guys backyardThe image captured a JET IN FLIGHT! It's probably impossible to determine the altitude of the Jet.
Here it is:. wrote:Anyone been able to find Area 51 didnt have anyluck.
http://maps.google.com/maps?q=groom+lak ... &t=k&hl=en
Hmm, I wonder why they don't have the hi-res imagery.
I found it here: http://www.shreddies.org/gmaps/index.php
There are some cool locations on that site.
Here's Edwards AFB with the huge compass rose in the dry lake bed. You can also see two SR-71 Blackbirds that are on one of the aprons (look roughly WSW of the compass rose).
http://maps.google.com/maps?q=CA+93524& ... &t=k&hl=en
Well, better go before they come looking, hehe j/k.
grimey wrote:You could do it fairly easily if you can find the shadow. I couldn't, though.Corporate Pilot wrote: It's probably impossible to determine the altitude of the Jet.
you're on crack. fairly easy? not only would you need to find the shadow, you'd then need to know exactly where the sun was when the picture was taken in relation to the earth... ie time of day, day of the year then yes, i suppose if you were able to easily find that out, and easily find out the exact latitude and longitude of that plane (which yes, would be a little easier then finding the position of the sun) then yes, i suppose you could get a pretty good estimate of the altitude. oh, and just to make it a little bit easier for you... the picture probably wasn't taken from directly over the aircraft (perpendicular to that location) so you'd then have to take that into account as well.
Punch it Chewy!
just curious
- Rank Moderator
- Beaver Driver
I'm not saying I would know how to do it, but I do watch allot of CSI.
If you took the length of the shodow cast by something of known hieght, and then somehow managed to find the shadow of the jet, then compared the two you would get the jets altitude.
Another way would be to compare the size of a known object to the size of the jet then you could figure out how much closer the jet is to the camera than the other object. The differenct of the two would be altitude.
But the easiest way would be to find out the date and time that the photo was taken (someone must know), then get the radar records from the FAA and see what the transponder was saying at the time.
Now all that having been said, I don't really care how high the jet is, but that is one cool site!!!!!!!
Flying a twin only doubles your chance of having an engine failure
Corporate Pilot
That wouldn't work either unless you knew the characteristics of the optics of the camera. I'm sure you've seen a telephoto lens used at a baseball game, shot from behind the pitcher. And of course you've noticed that the batter, catcher and umpire are all taller and wider than the pitcher, who is closer to the camera.Beaver Driver wrote:Another way would be to compare the size of a known object to the size of the jet then you could figure out how much closer the jet is to the camera than the other object. The differenct of the two would be altitude.
I'd go with the shadow approach, assuming you could actually find it!!
The shadows on the trees below and the plane itself show that it is relatively early in the morning ... the sun is coming from ESE and a fairly low angle. The shadows of the trees seem to be much longer than the tree would be high.
BUT ... I bet the area where you would find the aircraft shadow would be some large distance away and probably in a location covered by a different photo sequence altogether.
You'd also need to know information about the physical orientation if the camera. In this case, the image was probably taken from the ikronos or quickbird satellite which have a spatial resolution of about 1 metre....http://www.spaceimaging.com/products/ikonos/..in which case the image was probably taken with something other than an optical camera.
If there were two pictures of the aircraft, and you knew some other outside characteristics, you could calculate the elevation and the horziontal position of the satellite. Although, its quite an involved process, and there are many, many variables to consider. Read more about it...here http://www.geomatics.ucalgary.ca/%7Ehab ... rials.html
Boneyard outside of Davis Monthan AFB.
http://maps.google.com/maps?q=Tucson&ll ... &t=k&hl=en
eep...2 Green
Northern Skies
