Perhaps he was thinking that at touchdown, your airspeed is minimized with full flap, therefore the rudder effectiveness is diminished. (Although on a 172 there's hardly an difference in touchdown speed between 20 degrees of flap and full flap, is there?)"There's your problem, full flap reduces the rudder's effectiveness on that plane."
To full flaps or not to full flaps!
Re: To full flaps or not to full flaps!
- Beefitarian
Around 10 knots I think. Maybe this could help us figure out the relation of the flaps to the rudder.
Like I said though, I've only drove tricycles why would I use my feet until I was slamming on the brakes?ScurvyDog wrote:All this changes with the barn doors they put on single cessna's!
I've never had any problems with rudder authority with full flaps on Cessna 172s. With 40 degrees of flap you can crank in 45 degrees of bank and hold the nose straight if you push one of those 'foot rests' to fhe floor.
In a small Cessna, full flap every landing. If the wind is howling and I am coming in on a three degree (ugh), I'll put in 20 until short final and then put them all on, just so I am not revving the living daylights out of the engine to stay on slope. Otherwise, I will just come in more steeply.
- Beefitarian
Re:
When you add full flaps some of the airflow that goes to the tail is deflected (high wing), hence the effectiveness reduction in the rudder. Try doing a forward-slip without flaps and full flaps and you will notice some difference. Now when it comes to landing it will only affect if you have to use full rudder.Beefitarian wrote:"There's your problem, full flap reduces the rudder's effectiveness on that plane."
- Beefitarian
Re: Re:
I did and that is pretty much how I remember it.nightbird wrote:When you add full flaps some of the airflow that goes to the tail is deflected (high wing), hence the effectiveness reduction in the rudder. Try doing a forward-slip without flaps and full flaps and you will notice some difference. Now when it comes to landing it will only affect if you have to use full rudder.Beefitarian wrote:"There's your problem, full flap reduces the rudder's effectiveness on that plane."
keep in mind once the aircraft start to get a bit larger if you don't use full flap you run a greater risk of tail strikes... Hell we have a older 150 with the swept tail (no rear window) and if you flare too much without flaps you'll tail strike
- Beefitarian
Re:
Shhh it was MeBeefitarian wrote:I've never done it but I noticed during the walk around someone's dragging the eyebolt or whatever's on the back of lots of 172s I've flown.
- Beefitarian
I hate "one size fits all pronouncements" of the right way to do something, like "always land with full flap". The amount of flap I use is appropriate to the aircraft and the conditions. Little airplanes with big flaps, like the single Cessna's all seem to do better with less flap in strong crosswinds. Little airplanes with small flaps like Grummans do better with full flaps under all conditions. Heavier aircraft like the Pa31, work fine with full flaps, although 400 series Cessna's can be a bit easier to handle with less than full flaps, if you have a long runway. Transport catagory aircraft are landed with the flap specified in the AFM for the runway length.
Cat Driver wrote:I've never used full flap with the beav.
You have never used full flaps on a Beaver?
Do you fly one for a living?
Using full flaps in a Beaver in high winds would be poor judgment making for sure, but the airplane was designed and approved for the flap range available, therefore it is safe to use full flap if needed.Try using full flap in high winds with a STOL wing and you will think harder the next time you pump them all the way down.
From the DHC-2 AFM:
"Full Flap is only required for emergency landing in very restricted areas".
Then:
Minimum run landings may be necessary under EXDRAORDINARY circumstances.
"pilots familiar with the aircraft and experienced in short landing technique may perform minimum run landings by using full flap & reducing airspeed on the final approach to 65-68mph & maintaining that speed to the point of flare out"
+1 on one size doesn't fit all.
- Cat Driver
I am not sure what you mean by :From the DHC-2 AFM:
Then:
" +1 on one size doesn't fit all. "
The AFM clearly outlines the operating limitations therefore a pilot must be proficient in full flap landings...correct?
In other words a proficient pilot is one who can operate the airplane throughout it's complete flight envelope when and if needed.
I agree 100% Cat.Cat Driver wrote:I am not sure what you mean by :From the DHC-2 AFM:
Then:
I thought the question was about a PA31. It's really cool how the threads on Avcanada degrade to an arguement about flaps on a beaver!
O.K. enough with the beav and back to the Ho people.
Sigh.Cat Driver wrote: I am not sure what you mean by :
I quoted the AFM to bring to your attention that a full flap landing with the DHC2 is not something normally carried out while approaching to land. Should one have experience, and be comfortable with a full flap landing? Of course! Without question.
Would I elect to use full flap on the -2 for every landing? Hell no. Too aggressive of a pitch down attitude, descent rate, and finally coupled with (most important IMHO) the time its going to take for me to raise those barn doors to takeoff setting on a balked approach / overshoot scenario. In the end, I'm guessing because of these reasons and many more, DHC decided to have a "landing flap" setting (one notch before full flapper).
Hence "one size doesn't fit all".
When it comes to full flap discussions, I'm surprised no one has mentioned the C150 with it's 40 flap and the later C152 with 30 flap.
Many years ago, on the odd rare occasion, I would demonstrate 60 degrees of flaps on a buck fifty. Yes, 60, no typo. Fly a circuit but don't descend on final. Maintain 500 feet until the runway numbers disappear under the nose.
Apply 40 flap, nose down, and push open both doors all the way. Seriously. Cessnas do one thing well, and that's descend. Each door might be roughly equivalent to another 10 degrees of flaps. Or not. I dunno. Anyways, with 40 flap and both doors pushed open, you can pretty well hold a vertical downline above the runway numbers and the speed won't climb much with all that junk hung out in the breeze. As you enter the flare, close both doors and land.
I think it's safe to mention, now that he's retired, that a Transport Canada Inspector taught me about 60 degrees of flaps on a buck fifty, all those decades ago
This video has absolutely nothing to do with flaps or even aviation for that matter, but I kind of like the acoustic guitar playing at the beginning.
The same 150 I was talking about earlier that will almost have you strike the tail if you don't use flaps was one of the early ones equipped with 40 flap... That setting is for the most part too much flap for day to day flying, if I remember correctly it was about 2100rpm to maintain 500fpm decent and 65-70kts
I heard when flying the Wright Flyer, all landings are done flap less. Any one know what flaps to use the Spruce Goose?
