fuel weights
clarence oveur
fuel weights
Just wondering if anyone can tell me what the weight of car gas and jet fuel is. Curious so I'll know how much 45 gallon drums weigh. And is a 45 gallon drum U.S. gallons or imperial? Thanks.
just curious
- Rank Moderator
- Cat Driver
just curious
- Rank Moderator
A Canadian TSB report mentioned a 45 gallon drum being IMPERIAL gallons and being that I have not dealt with such weight and balance issues as of yet I assume this 45 gallon drum to be the norm.
Also I found this info:
Still the answer is not for sure as the quote is from "Midpac" whoever that is...
I wanted to know this answer for myself as some operators may ask it in an interview (not a fair question in my opinion if one has never worked with Jet A or any drums beforehand)
(from http://www.faqs.org/qa/qa-2617.html)For aviation fuel, which is similar to automobile fuel, the weight is 6 pounds per gallon. Jet A fuel, which is closer to kerosene, is 6.84 pounds. These weights are based on averages that will vary with temperature and additives due to weather.
just curious
- Rank Moderator
350TTSo basically the interviewer is just gauging how resourceful a person is in finding out answers beforehand if they are a 200 hour wonder.
Three fifty is quite right. Sadly, an astonishing number of people approach their job search with a minimal effort. Many companies, in fact most never see a fuel drum in their machines let alone consume them at an outpost.
Yet, for companies that see more drums than humans in their machines, it'd be a no-brainer that a wannabe would ask somebody in the know the basics of:
- How do you know what this stuff weighs?
- How does it get into the aircraft?
- How does it get into the tanks?
- How does it get stacked in those orderly piles?
- How does someone who is not roughly the same weight and shape of a fuel drum move it around?
just curious
- Rank Moderator
pray tell, what should I consider as a new name ?
By the way Just Curious, those are some of the questions I have had in my head. Now I need to find someone to answer them... maybe not on this forum but somehow I will find out. The thing is, an employer will always find questions that you don't have the answers to and trying to BS your way to a reasonable answer is not what I consider knowing your stuff and being a safe pilot.
I dream of a pilot in shining aluminum *sigh*
just curious
- Rank Moderator
So if we haul fuel in 45 or 25 Imperial gal drums why do we usually calculate avgas at 6lb/US gal? Probably a dumb question, is the answer because fuel tanks of airplanes made in the States are done in US gal while drums are made at a world wide standard imperial gallon size?
