Saskpower guys left overnight in the bush
Barkaie
Post by Barkaie »
Meatservo
Re: Saskpower guys left overnight in the bush
Post by Meatservo »
Didn't kill them. I thought these workers were required to be ready for this to happen. A silly mistake, but hardly cause for a "mental anguish" lawsuit or PTSD claim.
Beefitarian
Post by Beefitarian »
Those guys trust Meteorologists way more than I do. What if it was a storm that left them stranded? Or the helicopter went down and had an ELT failure.
Post by North Shore »
Oops! I suspect that once the initial shock and indignation has worn off, then the episode will be worth several laughs, and will be re-told several times..
DanWEC
Post by DanWEC »
I was with TWA as this was happening. While the pilot ultimately bears the responsibility (Poor guy, it was his first flight after line indoc!) They neglected to mention that the Saskpower crew wasn't answering their radio, and when we sent a second heli out on hour later, the crew was hunkered somewhere in the bush over a half km away from the open spot they were to be retrieved. 45 minutes of recon before dark yielded nothing. How the crew didn't realize the heli going overhead 10 times was for them, I'm not sure, but this was definitely an example of how most errors, when there is already a set procedure in place, will only result from a cascade of systemic failures- not just one mistake. There were several factors, on both sides, that lead to the error. Luckily the weather was good, and nobody was worse for wear from it.
Beefitarian
With TWA? If I ever need help looking for work I'm hiring you Dan.
The Mole
Post by The Mole »
Good to know saskpower has no safety procedures in place for crews in bush.
The Hammer
Post by The Hammer »
They are government, they don't follow/use rules, they just make em.
Dumb dee dumb dumb.
