Ifr expired. Renewal process?
My ifr lapsed last January, anyone knows what I need to get done to renew and be ready?
Re: Ifr expired. Renewal process?
bcqc wrote:My ifr lapsed last January, anyone knows what I need to get done to renew and be ready?
2 years or 4?
2 years need to do a flight test (some sims are approved or airplane)
4 years inrat and everything else.
Just do a search. Theres lots of info on here
- Colonel Sanders
I think you're saying that your instrument ratingMy ifr lapsed last January
has been expired for more than one year, but
less than two years.
CAR 421.49 applies:
http://www.tc.gc.ca/eng/civilaviation/r ... htm#421_49
Specifically CAR 421.49(1) says you need to do
a flight test.
para (2) through (9) do not appear to apply to you.
Another really useful publication to look at is TP 9939E:
http://www.tc.gc.ca/eng/civilaviation/p ... nu-965.htm
Specifically, "Admission to Flight Test - Renewal":
http://www.tc.gc.ca/eng/civilaviation/p ... l-4886.htm
Your licence booklet will satsify (1), (2) and (3) above.In order to be admitted to a flight test required for the renewal of an Instrument Rating, the candidate will present:
1.a valid original government-issued photo identification with signature;
2.a valid Pilot Licence; and
3.proof of holding, or having held within the previous 24 months, a valid Canadian Instrument Rating.
Hey guys thanks for your answers.
So my rating was valid til January 2013 as I did my last renewal in December 2010.
Do I need to write the inrat? Or if I find work a ppc or pcc would renew the whole thing?
- cdnpilot77
No you do not need to write the inrat. Either a Instrument flight test or a PPC for IFR ops would renew. A PCC does not renew your IFR
Thanks cdnpilot77...much appreciated piece of info!!
im in the same boat ! do you have to do the instrument flight test in a plane or can get away with in the red bird or other approve sim ??cdnpilot77 wrote:No you do not need to write the inrat. Either a Instrument flight test or a PPC for IFR ops would renew. A PCC does not renew your IFR
Yes you can do it in the sim.Egres wrote:im in the same boat ! do you have to do the instrument flight test in a plane or can get away with in the red bird or other approve sim ??cdnpilot77 wrote:No you do not need to write the inrat. Either a Instrument flight test or a PPC for IFR ops would renew. A PCC does not renew your IFR
im in the same boat here too. so just to clarify
i did my last ifr ppc ride in December 2011. my ifr ppc expired after a year, but after that time if i continue to do the 6 6 and 6 my ifr would stay valid for 2 years from my ifr ride (jan 1 2014)? then after that time i have 2 years (till jan 1 2016) to renew it without having to write the inrat, then after that time i would have to rewrite the inrat before i could renew my ifr? is that correct?
- cdnpilot77
CorrectDarman wrote:im in the same boat here too. so just to clarify
However the PCC does continue your IFR in that it eliminates the requirement for the 6,6 and 6 recency requirement for the second year of your IFR validity.cdnpilot77 wrote: A PCC does not renew your IFR
so what if i did my last ifr ppc ride in December 2011. my ifr ppc expired after a year(jan 1 2013)then i dont keep up with the 6 6 and 6. then would i have to write the inrat again after 2years from my ifr ppc ride expiring (jan 1 2015) or would i be still be good till jan 1 2016?
