fanblade, thanks.
The devil is always in the detail and right now I have no accurate idea what performance figures Bombardier are likely come up with. The aircraft has yet to fly and has yet to be certified so I'm taking some numeric liberties, like others, for sure. Without details I'm only guessing, I know that.
That said, their C series website published 4950 feet and I'd read some time ago London City is expanding to accommodate the C unlike YTZ. Again, without the detail, my first assumption was if LCYs 4948 foot long runway was adequate then YTZs numbers aren't likely to be far off.
I thought the island was around 5000 feet already, so I looked it up. Oops.
4100 feet probably is a stretch on my part. (I don't know what their final numbers will be. Maybe 4100 will work for this aircraft)
Other numbers from their fact sheet:
MTOW 58,967 kg
MLW 50,802 kg
Takeoff run at MTOW 4800 ft
Landing field length at MLW 4449 ft
For Urban Ops:
MTOW 53,060 kg
MLW 49,895 kg
Takeoff run at MTOW 1219 ft
Landing field length at MLW 1341 ft
I misread misread that article a couple of months. I now stand corrected.
Both airports
will need a runway extension to accommodate the C series.
But on the order of a 6 or 7000 foot runway?
In my opinion, that's a bit much. (I don't know what their final performance numbers will be. Maybe 5000 feet will be sufficient)
If it gets extended to accommodate A318s and B737-600s (this aeroplanes closer competition) then you're probably right. These two aircraft are much heavier than C with less capable engines.
We'll see how it performs over the next year.
cheers
Gino
