Aerovee in a Luscombe 8a
I was thinking of replacing my tired old Continental A65 for something with a few more horses and some of them new-fangled electric luxuries like a starter. One of the options I am considering is the Aerovee engine.
Has anyone done this before? Any regrets?
Shawn
Shawn
Re: Aerovee in a Luscombe 8a
http://rgl.faa.gov/Regulatory_and_Guida ... enDocument
Just go with an 0-200
Sorry, I should have clarified that my Luscombe is flying with an owner-maintenance C of A so STC's aren't necessary.
Assuming you're in Canada: Owner maintenance is not a permit to make major airframe or powerplant changes. It is intended to allow owners to maintain their aircraft to the original type certificate in a more economical fashion. It's not like you can't find replacement parts for a Continental engine.Luscombe wrote:Sorry, I should have clarified that my Luscombe is flying with an owner-maintenance C of A so STC's aren't necessary.
Which bit of which CAR says that?Owner maintenance is not a permit to make major airframe or powerplant changes.
From COPA's owner maintenance category interpretation...
"Under the O-M Category, Aircraft Pilot/Owners are Eligible To:
maintain an airplane
refurbish all or part of an airplane
overhaul all or part of an airplane
install certified and uncertified parts
install or replace any instruments or avionics
modify an airplane
rebuild an airplane that is out of service
sign the maintenance release."
More info...
http://www.copanational.org/AircraftInCaOwnerMaint.cfm
On to the subject, I researched the Aero-vee a while back and talked to some guys that have them. Most issues revolve around cooling, specifically the heads tend to burn valves. Most guys I know will rebuild them every 500 hours or so, but many make it to 1000 hrs if well maintained. Beauty is that they are super easy and cheap to rebuild. All parts for a rebuild are only a couple of hundred bucks last time I checked. You buy it in kit form and put it together yourself. I think they go for about $7k and since you will put it together yourself, rebuilds are no brainers. The instructions for the build are really, really good and I haven't heard of any issues with putting one together. They do take some fiddling to get them running just right, then you will be looking at mounts, and a bunch of other conversion accessories..
I'm not sure what the parts would cost to put an A65 back together, but I'm sure it's quite a bit more but if you want a really solid engine I'd probably stay with the 65 myself it's a proven, very reliable engine.
modify an airplane
More info...
Okay, i'll backpedal a bit here... I had a longer response started before but had to cut it short as I had to leave my computer to get to dinner. I should have said that it's "...not *simply* a permit..."photofly wrote:Which bit of which CAR says that?Owner maintenance is not a permit to make major airframe or powerplant changes.
I was an RAA director for a few years around the time the O-M category was being developed, and had many discussions both within the RAA and with Transport reps regarding the O-M category. TC was willing to find a way to let owners of antique aircraft maintain their own planes, because the manufacturers didn't exist for a lot of these planes anymore... Nobody was making parts. Those people who did hold the paperwork necessary to make certified parts, were gouging the market to cover their costs.
And in reality, it seemed silly that we allow any tom, dick, or harry to buy a flying amateur-built aircraft and then do his/her own maintenance on it. Why couldn't the same be true for "simpler" certified, antique, aircraft?
However, one thing they constantly parroted was that they didn't want this to be a license to make major modifications. They didn't want people building new wings for their airplanes (as in completely different designs, not just rebuilding the existing wing), or taking out lycomings and putting in Corvette engines. That wasn't the point of the category. They wanted to give people who were having a hard time finding economical maintenance, a way to do it themselves.
I've spent an hour searching the regs for any paperwork that says what you can, and cannot, do. I've come to the conclusion that such a clear, concise explanation either doesn't exist, or is so well buried in obfuscation that no sane person would ever find it. It's been extremely frustrating, because the regs by and large don't say much at all about what you can do to any O-M aircraft. The closest i've found is a gazette entry that talks about the O-M category. It does mention "modifying", but does not go into a lot of detail. It does say that modifications to structure, engine, airworthiness would all need to be approved by Transport Canada.
In the case of the Aero-Vee in the Luscombe, to get that approval, you'll need to show why it's safe to make the change... So you'll need a report (that I believe you could prepare yourself) that shows that you believe the new engine has a proven record, that you believe it's weight won't affect the C-of-G in any untoward way, that the fuel system is capable of supplying enough fuel fast enough to feed the engine, etc. Transport will review the report and can either approve or deny the change. If approved they will re-issue your paperwork showing the new engine, and someone will come out to inspect the installation.
Another aspect to this that came apparent to me only recently after discussions with COPA... The reason O-M aircraft can't fly into the US, is because the US considers them to be a greater risk because they are not maintained by qualified personnel (ie., an AME). This is of course in direct conflict with allowing Canadian Amateur-built aircraft into the US, as a growing number are owned and maintained by non-builders. The FAA is apparently very concerned about that state of affairs, but is turning a blind eye to it only as long as Canada doesn't push for any change to the O-M prohibition.
Some US FSDO's issued one-time permits for O-M aircraft to enter the US, but the FAA has since directed them to rescind any such permits and not issue any more... So if anyone makes the move to O-M, they're landlocked in Canada.
Wrong !!AirFrame wrote:Assuming you're in Canada: Owner maintenance is not a permit to make major airframe or powerplant changes. It is intended to allow owners to maintain their aircraft to the original type certificate in a more economical fashion. It's not like you can't find replacement parts for a Continental engine.Luscombe wrote:Sorry, I should have clarified that my Luscombe is flying with an owner-maintenance C of A so STC's aren't necessary.
I know several owners who went to O/M specifically so that they could re-engine their aircraft and c/out structural mods.
In each this was allowed with no issues .
The O/M category, like the Rec Pilot Permit, was developed with very good intentions but was not thought thru very well.
There are some areas that require improvement for sure.
It may have been allowed, but it's not what TC had intended when this program started, and they are concerned about the number of people using O-M to make these mods. Hopefully, it will prove out in the long run that these mods are safe, and there won't be any issues. But it won't take many accidents in modified O-M aircraft before the program gets shut down.
To clarify I have seen several owners go to O/M to re-engine their aircraft with both egnines of larger horse pwr that were not originally intended for the airframe and also install altogether different engines.
The original intention of O/M is one thing but it seems to be used as an outlet for owners to pretty much mod their aircraft in the same way as Amateur Builts but without having to build 51%.
That arguement was used originally with Amateur Built and the Rec Permit also.AirFrame wrote:It may have been allowed, but it's not what TC had intended when this program started, and they are concerned about the number of people using O-M to make these mods. Hopefully, it will prove out in the long run that these mods are safe, and there won't be any issues. But it won't take many accidents in modified O-M aircraft before the program gets shut down.
Time has showing that in both cases there was no issue.
O/M has been around long enough that it has proven its worth .
We have seen no more issue than any other category.
As for T/C intentions. Some of these mod I speak of were done within the first year of the O/M program
so T/C set the mark right from the start.
Explain to me how modifying an O/M ex certified aircraft is really any different to modifying in an Amateur Built Aircaft.
There isnt really. Both are done by the owner who assumes responsibility for the work performed
Transport knows that they set the bar too low when they wrote the regs. People in talks with Transport now tell me that they're really not happy with how the O-M program turned out, but aren't really sure how best to proceed. As you say, so far, it's been fine. So they've taken a "wait and see" approach, and for now decided to let it run its course and see what happens. I hope you're right that in the long run it continues to be no more dangerous than any other category.As for T/C intentions. Some of these mod I speak of were done within the first year of the O/M program so T/C set the mark right from the start.
On the surface, it may appear that there isn't much difference. But the reality is different. Look at what changes people want to make to their O-M aircraft vs. what people do to A-B aircraft.Explain to me how modifying an O/M ex certified aircraft is really any different to modifying in an Amateur Built Aircraft.
There isn't really. Both are done by the owner who assumes responsibility for the work performed
Most A-B aircraft flying today are quite new, compared to the planes going into O-M. Typically, significant modifications on an A-B aren't needed after the plane is finished and flying... In general, all owners do is maintenance of existing systems and structures. People add speed fairings, wheelpants, new paint, new avionics, but these are largely cosmetic changes. You don't generally see engine upgrades, but when you do it's generally the case where the airframe was designed for a larger engine initially but the builder only put a smaller engine in for cost reasons.
The O-M category has people putting 450-500HP Corvette engines in Seabees. Cessna 150 wings on Champs. 150HP engines in Luscombes. Can't do any of that in the Certified category, but hey, there's this O-M category that has an unintended loophole...
There were good reasons for the O-M category, but unfortunately they made the regs too loose at the start and people ran with it. Private owners *should* be allowed to maintain aircraft the same way A-B owners do. They *should* be allowed to replace a panel full of steam gauges with a modern, uncertified, EFIS display. They *should* be allowed to find ways to fabricate alternative, even improved, replacement parts when hard- or impossible-to-find parts fail. But it shouldn't be a license to head into full-on experimental mode.
In the case of the O-M Luscombe that started this thread, an Aero-Vee would be an acceptable change... If the owner can show TC "acceptable data" that convinces them that the change will be acceptable structurally and aerodynamically. What TC considers "acceptable" may be an interesting discussion, but it should probably be discussed with Transport Canada directly, because they'll be the ones making the decision.
Right from the start of O/M , people intended to use it to modify their extisting aircraft.
I can recall a major pwr upgrade to an aircraft very early on in the first year that was sanctioned by T/C
The O/M category has been around at least 10 yrs(?) (in it's loose form.)
How long is a "wait and see " period ?
I think it has proved itself at this point there have been no extraordinary issues or incidents in O/M compared to
any other categories.
Agree 100%, TC is a nightmare to deal with at the best of times and can you imagine if they repeal the O-M category? Do you think they will just let you grind off the stamps you hammered into your plane and let you go back to certified just because they repealed it?? HA!!! If you follow their current rules for re-certification of an O-M plane, they will make you strip the plane down to nothing for inspection!!! They won't care what the cost is, even though it's their ^&*( up! Probably cheaper to scrap it in most cases. Don't give the bastards any ideas! I don't know the stats, but on a per plane basis I bet the O-M category doesn't have any more cases of accidents (equipment related) than the amateur class.fleet16b wrote:Right from the start of O/M , people intended to use it to modify their extisting aircraft.
I agree that private owners of certified planes should be allowed to do MUCH more with their airplanes than currently allowed. Even though AME's (and I know I use to be one) would like you to think so, your little Cessna or piper is NOT that complicated of a machine! I'm not saying rebuilding a motor mind you, but average maintenance and even part of the annual should be able to be done by the owner IMHO.
Well, usually you wait until the data you've collected is "statistically significant". I don't know one way or another how the data runs right now. Who would know if the slightly older airplane that crashed a few weeks ago was O-M? The news just said "Cessna".fleet16b wrote:How long is a "wait and see" period? I think it has proved itself at this point there have been no extraordinary issues or incidents in O/M compared to any other categories.
Does anyone have any data on how many O-M aircraft there are, relative to A-B or Certified?
Well Airframe
If you are looking at news reports as stats then what can I say? Maybe you should dig a little deeper
Try reading the Incident Reports as released by T/C
Those reports state the type of aircraft/ category involved.
There are no significant O/M issues and I have been reading them for over twenty years.
IMHO , the O/M category and the Rec Permit are two of the more realistic programs
that T/C has implemented in years. Time has proven them both to be safe programs.
That would be difficult... Discussions regarding the concept of an O-M category started in 1993, but the O-M category only became law in 2002. And T/C doesn't release incident reports. The TSB does.fleet16b wrote:There are no significant O/M issues and I have been reading them for over twenty years.
Try reading the Incident Reports as released by T/C.
Good idea! Here's the breakdown of Privately owned O-M aircraft, by year, since the first appearance of an O-M aircraft in Transport Canada's historical records... 11 years ago. Numbers were taken from May of each year, as May 2002 is the first year an O-M aircraft showed in the records. I've included the Total number of Privately owned aircraft for perspective. The last column is the percentage of the total private aircraft fleet.fleet16b wrote:If you are looking at news reports as stats then what can I say? Maybe you should dig a little deeper
Code: Select all
Year O-M Total O-M %
2002 150 22060 0.68%
2003 206 22360 0.92%
2004 255 22803 1.12%
2005 320 23329 1.37%
2006 365 24014 1.52%
2007 401 24620 1.63%
2008 433 25412 1.70%
2009 466 26068 1.79%
2010 496 26645 1.86%
2011 530 27285 1.94%
2012 559 27991 2.00%
Code: Select all
16032 Normal
799 Restricted
3913 Amateur Built
5496 Basic Ultra-light
1156 Advanced Ultra-light
36 Experimental
559 Owner Maintained
27991 Totals
Don't know if you've decided on a new engine for the Luscombe yet but to the best of my knowledge nobody has successfully run a VW of any sort in that class of airplane (certified 30's two-seater). I would have thought in all the years people COULD have done it, you would have heard of it by now if successful.
Why mess with a good thing? Overhaul the A65 and keep the weight of a battery on the ground, where it belongs.
LnS.
LnS.
Thanks for the info guys, I really didn't think I was going to create all that much discussion on the OM category. I suppose when the time comes to overhaul, I might just go for the C85 instead. It'll give me electrics, increased horsepower (albeit it marginally). I know this will require a new firewall which is available from Univair in the states to accommodate the generator in the back of the engine.
I would imagine this would be easier in the long run.
Hey Luscombe,
Curious about where your at with the idea of a new engine for your Luscombe. I do not own a Luscombe but do fancy one quite a bit & have come quite close to pulling the trigger on acquiring one. The engine I often contemplate as being an ideal engine for the Luscombe in the owner maintenance category is a 912is Rotax.
If you go to the compare button is shows the fuel economy difference between comparable engines.
http://www.flyrotax.com/enginesImpressu ... ption.aspx
