707 kt groundspeed
- Redneck_pilot86
groundpilot
- Panama Jack
costermonger
Have you ever ridden an F-18? Unless it's single seat, clean(no tanks, FLIR etc) burners on, cold and diving you're not hitting mach 1.8JigglyBus wrote:Groundpilot,
You say that your top groundspeed is Mach 1.2 in your CF18.
A CF18 has a max true airspeed of Mach 1.7 - 1.8.
So, either you were on burners with a 250 knot head wind,
OR
You're a bs'er.
Ok, fair enough, I'll admit when I'm wrong.
I guess they probably are peacetime limitted. I obviously know very little about military flying, however, once you've past mach1, what is the difference peacetime wise between 1.2 and 1.6??
Also, on a side note. Everyone here is talking about high ground speeds, and you say Mach1.2. Is that really a ground speed?
Oh, the Cheez....
http://www.geocities.com/hjamieson_ca/cf18.html
http://www.airforce.forces.gc.ca/equip/ ... net5_e.asp
http://www.blueangels.org/Sitemap/FAQ.htm
http://www.fas.org/man/dod-101/sys/ac/f-18.htm
http://www.danshistory.com/fa18.html
http://www.nationmaster.com/encyclopedia/F/A_18-Hornet
http://www.boeing.com/defense-space/ military/fa18/fa18_4back.htm
All state the F/A-18 capable of mach 1.7-1.8 or greater, at level flight.
I do not fly the F/A-18, but I can read.
gonefishin'
YYC the place to be
NorthernDuck
twotterdriver
Groundspeed
I have seen 400 kts on the king Air 350 one day from HQM to MHR at FL310.
Best though was 212 kts in a Twotter (and this was on Whell/Skis) going to Pelly Bay. Of course, coming home was at about 95 kts....
I guess that I'm the designated bs caller on this thread, so I'll continue.
216kts in a Caravan... easy
239kts in a Seneca... possible at high altitude
230kts in a DiamondStar AT 1000'?? BS. Vno in a Da40 is 129, that would require a 100kt wind at 1000', if that actually happenned, the real accomplishment would be the landing, not the GS.
162kts on a Yahama R1. Really? Website I saw states max speed at 280kph, or 152kts. Even if you had it tricked out, what the F are you doing at 300kph on public roads?
Let me know where you live, so I can stay off the highway.
- Jaques Strappe
Federally
jigglybus,
easy, fine.
possible, fine.
What does Vno of 129 have to do with 230, and what does 1000' have to do with it...you can be at a higher alt and any speed under 250 kts under 10,000 in the Zone. And 230 GS isn't a great achievement as its not true....like SR71 said. Oh and for landing being the real accomplishment---try chopping the power and turning into the wind, funny how things slow down.
As for the 280kph, I was only telling you what the speedo reads.....sure there is some error as its a digital readout. As for what I was doing at that speed on public roads? Trying to keep up to a Busa on the 401 at 5am.
easy, fine.
possible, fine.
