Cyeg Transponder codes
blue thunder
Post by blue thunder »
When did YEG start with the phone call to get a transponder code? Came through today and it was mentioned to me. What number do you call? I have searched notams and of course, I don't maybe have the most current vfr supp. :smt040 Been use to this in Calgary, but I don't get this way often. Thanks in advance guys. If the Cormorant I parked beside doesn't knock my 407 on its side, I'll need this info on departure Thursday. Yes, I know, I could call flight services but here I am at present.
The Mole
Re: Cyeg Transponder codes
Post by The Mole »
You just failed your PCC and admitted guilt in not having current information for your flight. bad pilot.
cap41
Post by cap41 »
I've called 1866 vfr code works great takes seconds. Usually call just prior to starting the engine.
robshelle
Post by robshelle »
1-888-358-7526, or you could just call FSS and file a full flight plan.
Robbie Benusic
CYEG Tower
Forestdump
Post by Forestdump »
Also, I think you are at YXD. Or there is another Cormorant beside a 407.
Cessna driver
Post by Cessna driver »
He's at xd, your whopper chopper is still upright, cormorant is gone.
blue thunder
Yes, we're at XD. Flew through EG. Thanks for the responses. We'll give EG a call when we leave.
