Equipment Bid
Re: Equipment Bid
Flightaware.com will get you that info with a little bit of effort.
Re: Equipment Bid
You can download the timetable - it tells you all the routes, how often and with what aircraft type. Although it doesn't tell which base's pilots operate the flight - you can get a rough idea...cpt.sam wrote:Is there a source, anywhere, to indicate which routes are served by which a/c and base?
thx
http://www.aircanada.com/en/travelinfo/ ... imetables/
Re: Equipment Bid
Just out of curiosity, when is the next equipment bid scheduled to come out for AC?
Also, does anyone know whether the crew reductions from the E175 are already included in crew calculations or does that change on the go as Sky Regional takes an aircraft?
Thanks for any information and insight.
MB
MB
Re: Equipment Bid
It's due out in about 2 weeks. The positions for the 15 E175 reductions haven't been completely accounted for yet. There were just over 600 EMJ positions at the start of 2012, there were about 550 on the last bid, when the E175's are all removed there should be around 450.MB22 wrote:Just out of curiosity, when is the next equipment bid scheduled to come out for AC?
MB
