Twin down at Courtenay Airpark
Light twin off the end of the runway into the bushes, no one hurt.
- Shiny Side Up
Re: Twin down at Courtenay Airpark
I think I got it
- front.jpg (126.4 KiB) Viewed 5746 times
one more
- side.jpg (92.22 KiB) Viewed 5745 times
- Shiny Side Up
Airplane's home is in CYRP, registered to "Touch n' Go Aviation" according to the registry database.
Seems a bit short of a runway to be landing a 310 on...I guess they were stopping there to save 10c on avgas. Anyway, glad nobody was hurt - could have been worse.
Can't see the second prop, but if it's as intact as the first prop, then neither engine was running when it stopped... Either that or it stopped against something and the props never touched ground. TWO overhauls would be expensive.
The joke's already there....Shiny Side Up wrote:Airplane's home is in CYRP, registered to "Touch n' Go Aviation" according to the registry database.
170 to xray
Maybe it sold and that's the new owner off the end.
Change the ad to say "Bush pilots look here!"
crazy_aviator
- Redneck_pilot86
Judging by all the leaves and crud on the aircraft in the pic of the left engine, it was running when it went into the brush...AirFrame wrote:Can't see the second prop, but if it's as intact as the first prop, then neither engine was running when it stopped... Either that or it stopped against something and the props never touched ground. TWO overhauls would be expensive.
Ouch. Both props and engines pretty low time. Double Ouch actually.
1800 feet of wet asphalt in a C310R? Hmmm...a bit of a challenge.CpnCrunch wrote:Seems a bit short of a runway to be landing a 310 on...I guess they were stopping there to save 10c on avgas. Anyway, glad nobody was hurt - could have been worse.
Is that one of Seneca's old 310s from the 80s?
The registry shows it as being imported in 2009.HighT5 wrote:Is that one of Seneca's old 310s from the 80s?
godsrcrazy
Manufactured in 1979 according to the registry.
But that'll buff right out.170 to xray wrote:http://www.controller.com/listingsdetai ... 265349.htm
May have to adjust the price.
All their planes had KW_ registrations I believe because Ken Wilson sold them the planes.godsrcrazy wrote:HighT5 wrote:Is that one of Seneca's old 310s from the 80s?
Not a big deal, just curious.
- Colonel Sanders
With1800 feet of wet asphalt in a C310R?
1) VG's (essential, at least for me) and
2) no obstacles on approach and
3) light weight
I'd try it
Biggest possible obstacle on approach at Courtenay is a tall person on the walking path that runs across the end of the runway. Or maybe the waist-high fence beside him, that starts about a foot below runway grade. You can make a rather flat approach.Colonel Sanders wrote:2) no obstacles on approach and
The owner and I looked at taking the company Cessna 340 into this airport. We decided against it as getting in was doable but the departure was too tight.
