Twin down at Courtenay Airpark
Re: Twin down at Courtenay Airpark
1800 feet is tight for a 310R. I used to do it at Brampton, but I think I had less safety margin than I knew at the time. I got away with it, but that does not make it a good idea...
- Colonel Sanders
What's that old saying .... "A skilled pilot canthe departure was too tight
land an airplane somewhere that it can never
be taken off from again"
My buddy Carlos landed a B737 on a levee
outside of New Orleans (double flameout)
and they had to truck it out - but Southwest
is still flying it after all these years!
See TACA 110. Incredible that no one was
hurt. Not even the airplane, really.
Or just destroy the photos and deny it ever happened ....Dash-Ate wrote:But that'll buff right out.170 to xray wrote:http://www.controller.com/listingsdetai ... 265349.htm
May have to adjust the price.
CADORS 2013P1373
http://wwwapps.tc.gc.ca/Saf-Sec-Sur/2/c ... d2013P1373
"At 1815Z, a 2210545 Ontario Inc. Cessna T310R (C-GKWC) from Victoria, BC (CYYJ) to Courtenay Airpark, BC (CAH3) advised CYKA FIC that he slid off the right hand side of runway 13 (near the end of the runway) at CAH3. No reported injuries or damage to the aircraft."
I thought they changed an engine on that one and flew it out using test pilots. (according to what I remember from that episode of Mayday)Colonel Sanders wrote:What's that old saying .... "A skilled pilot canthe departure was too tight
be taken off from again"![]()
Colonel Sanders wrote:With1800 feet of wet asphalt in a C310R?
1) VG's (essential, at least for me) and
2) no obstacles on approach and
3) light weight
I'd try it
Easy.
AJV wrote:I thought they changed an engine on that one and flew it out using test pilots. (according to what I remember from that episode of Mayday)Colonel Sanders wrote:What's that old saying .... "A skilled pilot canthe departure was too tight
They did fly it out. A good lesson on avoiding flying through very heavy precipitation. Even if it usually works, why not give extra clearance to it. Even just heavy ice crystals have been flaming out engines. Best to avoid when possible.
- Colonel Sanders
http://en.wikipedia.org/wiki/TACA_Fligh ... mendations
NTSB investigators determined that the aircraft had inadvertently flown into a level 4 thunderstorm and that water ingestion had caused both engines to flame out despite their being certified as meeting Federal Aviation Administration (FAA) standards for water ingestion.
In order to avoid similar problems in the future, CFMI modified the CFM56 engine by adding a sensor to force the combustor to continuously ignite under heavy rain and/or hail conditions. Other modifications were made to the engine nose cone and the spacing of the fan blades in order to better deflect hail away from the engine core. Also, additional bleed doors were added to drain more water from the engine.
Brown Bear
Big Pistons Forever wrote:The owner and I looked at taking the company Cessna 340 into this airport. We decided against it as getting in was doable but the departure was too tight.
A 340 is not a 310. 1800 feet works for me in a 310....I'd pass it up in 340 though.
Correct. He was going between two red cells. How close together...we don't know of course, but most level 4 thunderstorms show up quite well on radar and should be given good clearance. Otherwise you might get heavy rain and hail inadvertently. At a minimum....pax won't like it due to turbulence and F/A's could be injured. Bad things happen close to heavy thunderstorms. Turbulence, hail, severe icing, lightning, windshear, heavy precipitation and now even ice crystal icing. Big ones in the tropics may not be nearly as bad as ones in places known for intense CB's such as America. The problem is...usually it is OK when you pass near them. Then every once in a while you get a surprise. No shortage of hail related incidents. Transat wrote off a Tristar due to hail. Best to be a chicken and stay far away.Colonel Sanders wrote:http://en.wikipedia.org/wiki/TACA_Fligh ... mendations
I remember hearing about a couple of guys that went between a couple of red cells that were not all that far apart. While not all details are known, the turbulence was bad enough that they lost oil pressure in one engine and had to shut it down.
The FAA spelled it out thunderstorm risks more than 30 years ago.
http://www.faa.gov/documentLibrary/medi ... 00-24B.pdf
Turbine engines have a limit on the amount of water they can ingest. Updrafts are present in many thunderstorms, particularly those in the developing stages. If the updraft velocity in the thunderstorm approaches or exceeds the terminal velocity of the falling raindrops, very high concentrations of water may occur. It is possible that these concentrations can be in excess of the quantity of water turbine engines are designed to ingest. Therefore, severe thunderstorms may contain areas of high water concentration which could result in flameout and/or structural failure of one or more engines.
Remember that while hail always gives a radar echo, it may fall several miles from the nearest visible cloud and hazardous turbulence may extend to as much as 20 miles from the echo edge. Avoid intense or extreme level echoes by at least 20 miles; that is, such echoes should be separated by at least 40 miles before you fly between them. With weaker ethos you can reduce the distance by which you avoid them.
Certainly showed excellent handling skills like the guys in Gimli and the Azores. I wouldn't want to try it.
- Colonel Sanders
Not too many pilots, after a double-flameout, canexcellent handling skills
glide a Boeing to a landing so gentle that not only
is no one hurt - the aircraft is virtually undamaged.
Even the vaunted Sully (twice Carlos's age at the
time) didn't do quite that well.
Keep in mind that Carlos, in the left seat, was only
29 years old at the time - with only one eye, and
10,000TT. He's a superb stick - we do Central
America airshows together. What he says about
how young airline pilots today are trained, and their
skills and attitudes, is not printable here. Apparently
the fuzzy-cheeked youngsters in the right seat are
shocked when he makes them hand-fly. On raw data!
Yep, awesome job. But, so us GA guys are supposed to "don't (ever) turn off the autopilot", or get castigated if we do. We will likely crash and burn.
Sounds like the best way to keep our skills up is be following the pretty pink line on 2 miles of glass while pushing buttons like a video game, yep.
Let me explain. When one engages the autopilot at 400 agl on every flight on every flight, turns on XM radio, and leave both on for the entire flight, the tendancy is to shut the brain off and become a passenger, watching the video screen like a TV.
Do this every time and hand flying, terrain reading, map reading, and emergency skills atrophy so much, one would be in serious trouble with any glass or autopilot malfunction. Let alone evening knowing where one is within 20 miles without the glass.
A T310R and a C340 have the same wing and engine, although the 340 is a bit heavier. My thinking on the T310R and the 340 are the same.Brown Bear wrote:Big Pistons Forever wrote:The owner and I looked at taking the company Cessna 340 into this airport. We decided against it as getting in was doable but the departure was too tight.
Now if we were talking about the cherry C310C that I used to fly,and it was a light load, it would be a different discussion.
Dh8Classic
"A superior pilot uses his superior judgement to avoid entering situations requiring him to demonstrate his superior skill"
Successful thunderstorm avoidance depends a lot on judgement. We have seen several jet glider pilots with superior skill.
