Yes, Yes I have.Colonel Sanders wrote: Ever heard of a Sabre? Ever seen a second seat in one?
Carry on.
Especially since the last one they made was scrapped in '56. Really too bad, the things you could do with a two seat sabre... I guess one just has to settle for a two seat MiG-15. Wierd to think the Sovs were more forward thinking. Maybe they had a time machine and knew people were going to be wanting to fly these things sixty years after they were made.Colonel Sanders wrote:Small detail ... of which the RCAF had precisely ZERO.
NA tried to sell the two-seat Sabre worldwide, but it
was too little, too late. TTM lesson. Only a couple
were ever made. I doubt there is anyone here that
has ever seen one in person.
I am disappointed that you are implying thatYou do not need a gazilion hours to be safe, effective and competent at something
Are you talking about you posting a video of yourself every second post?Colonel Sanders wrote:Sigh. Genitalia and elitism again. Like a broken record.
Pop quiz time: why was there never an initial "small tail"simulator/procedures trainer sessions
Thanks. My guess is a lot of young men had the time of their life in the F 86 era RCAF.Schooner69A wrote:"...before they let him strap on a F 86 ?"
BPF: in addition to the usual ground school subjects, there were approximately seven simulator/procedures trainer sessions then a blind-fold cockpit touch test before you were thrown out of the nest. After hours, students would go down to their hangar, find an aircraft, and run through various procedures, both routine and emergency. One of my classmates was running through the "Engine Failure After Take-off Drill" which read in part "Drop Tanks - Release" which would get rid of some 800 pounds of fuel. This was accomplished by pushing a button on the instrument panel that was situated in a protective little red "silo" and covered with paper. My friend realized that on take-off his harness would be locked and he wondered if he would be able to reach the button. So... (You know where this is going, don't you?) So... He locked his harness and then reached for the "Drop Tanks" button. His finger punctured the paper and depressed the button. The aircraft was instantly relieved of 800 pounds of fuel and tanks leaving my friend sitting in a slowly widening pool of JP4. The alarm was raised and the next morning, we had a new rule: no students allowed in the hangars after hours.
On the day of the first trip, an instructor crouched on the wing and watched you as you started the engine. You were naturally a bit apprehensive and slow (not wanting to make any mistakes and blow an engine) In the summertime, this was not a problem; however, in the winter, many a slow-moving student has had his hands batted out of the way as the instructor leaned into the cockpit, placed the battery switch on, selected the start switch to "Start", got the engine cranking, (switch then to "Run"), reached over and threw the throttle around the "horn" at the appropriate percent, slapped you on the shoulder, shouted "Have a great trip", jumped off the wing and headed for the warmth of the hangar.
In those days, nobody stayed around to do "Finger Checks" and all that; as soon as you indicated "Diconnect APU", the tech did just that and headed for the next start. There were not many checks to accomplish: speed brakes in, flaps to take-off, check controls in normal and alternate hydraulics, set trims, close the canopy, temps and pressures. Many a student has hesitated short of the runway thinking that there must be more to do and has had the tower break into his reverie: "You ready to go?". And off you would go on the first trip of a three or four year assignment on one of the finest aircraft ever built.
John
He did not imply this. He pointed out that a solid foundation might be even more important than many many hours. That doesn't mean many hours isn't important. We all know that Yeager and Hoover always said they were good because they were the ones that flew the most.Colonel Sanders wrote:I am disappointed that you are implying thatYou do not need a gazilion hours to be safe, effective and competent at something
being minimally qualified is going to keep you
alive when something goes wrong in form.
Hypothetically: In a decade or two, that hideous aircraft becomes the most efficient ground attack and A-A fighter of it's time. LET'S PRETEND this scenario becomes real, will you be able to admit you've been talking out of you a$$ all that time when it comes to the F35?Colonel Sanders wrote:And they are due to be replaced with
a tiny number of hideously expensive aircraft which
will not allow pilots to fly enough to develop proficiency.
You've got to admit he's been controlling himself for the last couple of posts.AuxBatOn wrote:Are you talking about you posting a video of yourself every second post?Colonel Sanders wrote:Sigh. Genitalia and elitism again. Like a broken record.
I feel your pain. I was expelled from my first high school,Getting kicked out of high school
Yup. See Tex Johnston's biography. The problem was sotail, and the lack thereof
