Viking DHC -6-400 project to Wichita?
planemikey
Is the Viking DHC 6 -400 assembly plants moving to Wichita is true or not . Anyone know ?
Re: Viking DHC -6-400 project to Wichita?
In July, 2013, Triumph Aerospace Systems of Wichita won a contract to supply fuselage assembly units for Viking's Twin Otter Series 400 aircraft.
http://www.kansascommerce.com/CivicAlerts.aspx?aid=876
https://www.facebook.com/media/set/?set ... 262&type=3
NOT true.
I heard a few of the cells are leaving Calgary for Witchita..Finally assembly will still be done in Calgary
leftoftrack
Everything else.. Some AVIONICS calibration will be performed out of CYYC, depending..
Old news! YCC workers were informed in feb last year that the cabin was going to be made in Wichita. As far as I know, the cockpit & wings are made in Victoria, fight controls Campbell river, tail boom I think is done by Found aircraft. vertical and horizontal stabs, I am not sure where they are made. Start to finish assembly is done in YYC and paint in Victoria.
inspector002
the rear fuse empenage is built at Fleet Canada
as is the verticle fin and the horizontal stab
We also build the bonded wing skins and the other bonded parts (non composite)
We also do the stringers used in the aircraft structure
We supply Victoria ,Calgary (including Field) and Triumph
