If approach mins are 375 and 1.5 vis on Rnav. Using 800 and 2 or 300 and 1 whichever is greater. The 300 and 1 gives 700 and 2.5 so do you use 800 and 2 or 800 and 2.5 as alternate mins.
Alternate mins
Re: Alternate mins
The RNAV approach mins are 375 and vis 1.5..
Alternate mins for non precision is 800-2 or 300-1 above HAA/HAT whichever is greater
So 300-1 gives 700 and 2.5 meaning the vis is higher then standard but ceiling isn't and it says to use 800-2 or 300-1 whichever is greater so would the final product be 800 and 2.5 using a mix of the two?
