AirFrame wrote:So why do GA VFR pilots get denied (on the VFR frequency), then minutes later a commercial flight (which may or may not be VFR, but they're on the VFR frequency and flying a similar route) gets accepted? And there's *nothing* else on the frequency for the duration of the crossing (theirs or mine)?
The folks at NavCanada don't deny service for the sake of it. As I wrote in a previous post, "Restricted Class C" does not mean "Closed Class C" some flights both commercial and private are pre-coordinated. If you listen to the frequency long enough you will hear the commercial carriers such as Helijet and Harbour Air be forced down. Ask any one of their pilots.
Big Pistons Forever wrote:So if you were working terminal and things are busy and you here this as your initial call
"UMMMM Vancouver terminal UmMMM I mean Victoria terminal Cessna 172 UMMMMM Charlie Golf Alpha Bravo Charlie is UMMMMMMMM, UMMMMMMMM close to UMMMMMMMMM I think its Stuart Island UMMMMM and I want to go to Abbotsford at ummm I think I want to climb to 4500 UMMMMM oh no wait that is wrong direction UMMMMM better make it 5500 ummmmm click."
Would you really want to go out of your way to make the request happen ?
But
If everyone said
"Terminal 172 GABC"
you will get "Sqawk ident, say intentions"
push the ident button and reply with
"level 2500 request 5500 direct East point direct Abbotsford, ABC"
You are more likely to get
"Radar identified Climb 5500 cleared as requested"
I have plenty of beefs with NavCanada but the South Island and Lower Mainland is very busy airspace and so if you want to fly in it I don't think it is unreasonable that you don't use up the airwaves with cringe worthy calls. You want to be treated well then treat ATC with the same consideration
I don't think it is about preferential treatment but given the 2 calls that you allude to above. The pilot in the first call is demonstrating that he has the potential of being very unfamiliar with radio procedures and the airspace and could require a lot of attention which is much better spent separating all the other aircraft in the airspace. The pilot of the second aircraft is demonstrating an ability to communicate in a clear concise manner, will follow instructions and won't be tying up the frequency.
AirFrame wrote:True! But in the first case, you'll never on this earth hear YVR Terminal *offer* you that alternative... You have to know to ask for it. In the second case, that might work too, but personally i'm not happy wasting my gas money. Unlike a commercial flight, I don't have a revenue stream to pay for it.
Terminal can be surprisingly accommodating but it takes a little bit of give and take on both sides. While I feel for your gas money (I understand as I am a user of the airspace as well) It may also be advisable to check the NOTAMS prior to the flight. If there is a restriction there is a possibility that you may not get option A and you should be prepared with option B. Vancouver will often offer a second option but the onus is on the pilot to have a backup plan just like the controllers always have a plan B and C.
Another thing that goes a long way is clear concise communication and an understanding of the airspace.
1. "Terminal this is CGABC 4 north of Nanaimo at 2500 requesting 4500 to Gower if able"
vs.
2. "Terminal this is CGABC at 2500 climbing to 4500 we will be proceeding via Gower and Point Atkinson"
Option 1 demonstrates that you have done your preflight and are aware of the possible restriction and will be flexible in working with ATC
Option 2 demonstrates a lack of planning and a sense of entitlement to use the airspace and a general sense of expecting traffic to move around you.
Consider which check in would get more consideration as far as entering the restricted class C.
Last but not least,
The controllers don't like the restrictions any more than the pilots. With that said, it is at the discretion of the controller working at any particular point to allow or disallow VFR aircraft from entering the Class C. The traffic picture changes every few minutes so if you are denied on one leg of your trip there is a good chance you will be given a clearance on the return trip. It is nothing personal it is just how the system works and necessary to ensure a safe and efficient operation.
YJ & VR Terminal are required to provide service to allow aircraft to safely cross the straight. The only caveat is that it may not be on the most efficient route and may be subject to minor delays. It is all part of flying both privately and commercially. Budget accordingly.
