The issue wasn't with people flying Nordo. The issue is with people flying with a radio, but deciding not to use it for some reason.eh3fifty wrote:Because you're flying in your Cub and it doesn't have a radio.
Explain like I'm 5 - Mandatory Frequency
Re: Explain like I'm 5 - Mandatory Frequency
As one of the friendly neighbourhood FSS you'll be speaking to in Muskoka, it's not that different than at an airport without a ground frequency. Instead of broadcasting to traffic, direct your calls to Timmins Radio.
As we do have to do a lot of multitasking, we apreciate a heads up call with your four letter identifier, your type, and if you have the AWOS. That gives us a chance to generate a strip for you and reduces the requests for repeats. Once we respond, tell us your position/altitude, your last point of departure or destination, and your estimate. We'll give you runway and traffic information, as well as any other pertinent info like pireps and applicable notams. Tell us your intended runway and how you plan to join the circut(or depature intentions). Make all your mandatory calls as usual. If there's conflicting traffic, we'll give you updates and sort out any issues.
If you're unsure of anything, don't hesitate to ask. We're here to help and make sure everyone is safe.
Looking forward to talking to you Niss, fly safe.
W&P
W&P
You'd be surprised how many people *aren't* paying attention.photofly wrote:For Muskoka, there's a nice person in a room at Timmins. You call them up and they tell you which runway everyone is using, then ask you which runway you want to use. You tell them you want to use the same runway as everyone else, so then they tell everyone else which runway you're going to use, in case they missed it. Then when you're joining the circuit, you'll call and say where you are, and bless me if they don't tell everyone else where you are, in case they missed it. Whenever anyone else says where they are they'll make sure they tell you where the other person is too, in case you missed it.
"this is how you smile to someone you don't like too much; this is how you smile to someone you don't like at all; this is how you smile to someone you like completely; this is how you set a table for tea." ~ Jamaica Kincaid, "Girl"
They're effectively NORDO then. If you have an issue with people not being on the radio then you should complain to TC via CAIRS and let them know that you believe it's a safety concern and that airplanes should be required to have a radio and to use it like they are at an MF.AirFrame wrote:The issue wasn't with people flying Nordo. The issue is with people flying with a radio, but deciding not to use it for some reason.eh3fifty wrote:Because you're flying in your Cub and it doesn't have a radio.
Maybe having someone not talk on the radio is a reminder to you that you need to always be looking out for other traffic at an ATF. Everyone knows you don't require a radio at an ATF...
“No one can realize how substantial the air is, until he feels its supporting power beneath him. It inspires confidence at once.”
-Otto Lilienthal
-Otto Lilienthal
Not at all. There are NORDO aircraft and they should be allowed to fly too. But why does someone *with* a radio choose not to use it?eh3fifty wrote:They're effectively NORDO then. If you have an issue with people not being on the radio then you should complain to TC via CAIRS and let them know that you believe it's a safety concern and that airplanes should be required to have a radio and to use it like they are at an MF.
True. But everyone *with* a radio *should* use it, as per the AIM.Maybe having someone not talk on the radio is a reminder to you that you need to always be looking out for other traffic at an ATF. Everyone knows you don't require a radio at an ATF...
Because they're not legally required to do so.But why does someone *with* a radio choose not to use it?
Maybe they're old crusty bastards that are tired of all this unnecessary radio BS and will only use it when they have to. They were taught to look outside when they fly and technology and rules have advanced much more than they like.
Whatever the reason, the simple fact is that you, flying your airplane into an ATF, need to realize that other aircraft could be operating NORDO in the area and YOU need to lookout for them.
Getting pissed is going to do nothing. Like I said before, if this is an issue for you then submit a CAIRS report and try to get TC to mandate radios and radio calls for every airplane in Canada.
That being said, I agree that they should be using the radio if they have it. It's poor airmanship not to do so.
-Otto Lilienthal
-Otto Lilienthal
