OPP PC12
olddirtyloud
Re: OPP PC12
I'm assuming it's almost entirely on call work, or maybe a few days notice for some flights. Even though they only say 1500 hours, this sounds like a cushy job that would get mucho resumes, sending the hours required to be hired way up...
Forest Gump
Re: OPP PC12
70-80k, (this is regardless of seat) is a respectable wage, particularly for a PC-12. I have been assure that one will make more then the posted wage. If you want to be paid as a constable, go apply to the OPP for an Officer position. That being said, entry level OPP don't even make this kind of cash.
http://www.opp.ca/ecms/index.php?id=98
- YYZSaabGuy
Re: OPP PC12
On the upside, your job as a pilot generally won't require that you carry a sidearm and wear a vest because you may have to face or use lethal force on a moment's notice, pull bodies out of wrecks/lakes/buildings/dumpsters, attend autopsies to preserve the evidentiary chain of custody, or manage the ongoing stress of dealing with people at their absolute worst day after day, frequently with lots of second-guessing and little appreciation (other than a paycheque) to show for it.too bad it pays less than what a constable makes...
So there's that.
Changes in Latitudes
Re: OPP PC12
Very well said.YYZSaabGuy wrote:On the upside, your job as a pilot generally won't require that you carry a sidearm and wear a vest because you may have to face or use lethal force on a moment's notice, pull bodies out of wrecks/lakes/buildings/dumpsters, attend autopsies to preserve the evidentiary chain of custody, or manage the ongoing stress of dealing with people at their absolute worst day after day, frequently with lots of second-guessing and little appreciation (other than a paycheque) to show for it.too bad it pays less than what a constable makes...
So there's that.
- cdnpilot77
Re: OPP PC12
So there's that.
Agree as well, however the OPD pilots I saw always had a sidearm and usually a vest too I think. But (BIG but) they were OPP officers first and pilots second. So a direct pilot hire would be unlikely to carry the heat, but maybe they would get firearms training because of the pax they transport?
Re: OPP PC12
Could it be less people are using proper phraseology in terms of call signs because they are an Anachronism. A tool of a bygone era where radios, speakers and microphones were of poor quality so as to require the need to clearly identify oneself. Whereas the clarity on radio communications today is not an issue... For the most part, (HF comms. can be difficult at times)
Now that's not to say I agree with poor radio phraseology. There is a certain pride of professionalism from speaking clearly and concisely on the radio which becomes even more important while operating in foreign countries.
- schnitzel2k3
Re: OPP PC12
IF anyone happens to get called for this on here, please post some details. Certainly curious about the position.
- oldncold
Re: OPP PC12
standard hr practice posted internally first then extermal .probably have candidate but some of the best variety flying anywhere. great group of people in the air division
olddirtyloud
Re: OPP PC12
Does your comment mean they already have someone for the position from inside?
PostmasterGeneral
Re: OPP PC12
From what I learned in school these people are French Canadian not Frenchies. Try again without the rude references
Re: OPP PC12
I have removed all the off topic comments and ask that you keep your comments to the topic at hand.
