Updated logo and 767 preview
tehkr
Re: Updated logo and 767 preview
Post by tehkr »
leftoftrack wrote:Alberta goverment use to pull the dash 8 onto a ramp lifting the nose and lowering the tail to fit it in, any chance of that?
Do you have a link to this? Made me chuckle and I wana share it with a friend!
Lowjack
Post by Lowjack »
Another step in the process to the first true WS flight happening, aircraft now has the temporary N-number reg removed and it is showing C-FOGJ.
aerobod
Post by aerobod »
tehkr wrote:
aerobod wrote:
ckl wrote:Bad corrosion?
No hint of it in the program updates I receive, nor with my conversations with Tech Ops management. Not sure where or how this rumour started.
lol probably same way the feel off the stand rumour started. Any idea on internet speed or power outlets in economy class?
Internet speed will be up to about 7Mbps shared for the aircraft, depending on where in the world and which satellite is used in that zone. 2017 or so satellite bandwidth will increase by about 10x. Economy on the 767 has 5V USB at each seat, Plus has 110V at each seat. Unfortunately it will likely be early next year before the Internet and streaming video system is switched on, as certification is still underway, a different STC is needed for the 767 compared with those already obtained for the 737s.
Longtimer
Post by Longtimer »
Lowjack wrote:Another step in the process to the first true WS flight happening, aircraft now has the temporary N-number reg removed and it is showing C-FOGJ.
Transport Canada now has the information posted.
Any idea when we will see it doing commercial flights?
Mark: C-FOGJ
Common Name: Boeing Model Name: 767-338
Serial No.: 25274
Basis for Eligibility for Registration: CAR Standard 507.02, 507.03 - Type Certificate - A137
Category: Aeroplane Engine: 2, Turbo Fan
Max Take-Off Weight: 172365 kg
24 Bit Address: Bin=110000000010010110011110, Octal=60022636, Hex=C0259E
Regional Office: Winnipeg Year Imported: 2015
Base of Operations: Calgary, Alberta, CANADA
Manufacturer Information
Manufacturer: The Boeing Company
Country of Manufacture: U.S.A. Year of Manufacture: 1991
Registration Information
Type of Registration: Commercial
Owner Registered Since: 2015-10-13
Latest Certificate of Registration Issued: 2015-10-13
Registered Owner Information
Care of: Attn: Quality Assurance Department
Address: 21 Aerial Place NE
City: Calgary Postal Code: T2E 8X7
Province/Territory/State: Alberta Country: CANADA
Region: Prairie and Northern
Mail Recipient: Yes
thenoflyzone
Post by thenoflyzone »
MTOW only 172,365 kg, as i suspected, much lower than on AC's newest 767s (186,880 kg).
These birds will have a hard time on any Alberta-China runs.
Even AC's oldest 767, C-FCAB, built in 1988, has a 181,439 kg MTOW.
According to the Boeing ACAP document for the 767, seems like 172,365 kg was the initial weight variant on the 763ER. So most likely QF ordered these lighter birds as they probably didn't need any additional lift back in the day.
Different weight variants:
172,365 kg (WS)
175,540 kg
181,437 kg (AC's oldest 767)
184,612 kg
186,880 kg (AC's newest 767)
Based on the payload/range charts, anything greater than 5000 nm (still air) is a no go for this WS bird. YVR-LGW is 4126 nm. Although the westbound leg could easily reach 4600-4700 nm still air distance factoring in the headwinds.
aerobod
Post by aerobod »
thenoflyzone wrote:MTOW only 172,365 kg, as i suspected, much lower than on AC's newest 767s (186,880 kg).
172,365 kg (WS)
175,540 kg
184,612 kg
One thing that has to be factored in to the range is that the original QF 767-338ER wasn't fitted with winglets. Boeing claims the WS winglet retrofit will increase range by over 5% for a given MTOW.
plhought
Post by plhought »
...also one of few non-FADEC 767's in the world....
Meh, it's a great airplane to start widebody work with though. I'm sure lots of people were scratching their heads when WJ was rockin' ol' -200's around when Air Canader was flying around nice new 319s.
CAL
Post by CAL »
its amazing the red tape a company has to go through to get an airplane flying.....
nysa
Post by nysa »
Air Canada has the government in their pocket, they are making this difficult hoping that WestJet will not increase their international widebody expansion and threaten Air Canada's most lucrative market. They don't want WestJet acquiring these 767's that cost a fraction of the new shiny 787 that Air Canada has on order especially with jet fuel staying cheap for longer. This corrupt government and its agencies together with the crony judges always protected Air Canada and made decisions favoring the company that were anti competitive or against its workers for eg. Aveos, lockouts, gulf carriers, arbitration, etc, its all rigged.
canuckwings
Post by canuckwings »
Hi guys! A bit of a newbie here but I see that WS received it's registration for the first 767 as C-FOGJ...
Question: Is the C- designation only granted once a plane completes ETOPS? Basically does this mean the 767s are for sure certified and good to go for Hawaii this winter?
Or can a plane be granted its C- mark without yet completing ETOPS?
Thanks!!!!
Longtimer
Post by Longtimer »
What you call the C mark has absolutely nothing to do with ETOPS.
CARs 202.03
Aircraft marks are comprised of the nationality mark and the registration mark. The nationality of a Canadian aircraft is currently identified with the letter C. The four letters following the nationality mark are known as the registration mark. The first of those four letters is either F or G and, in the case of ultra-light or advanced ultra-light aeroplanes, the letter I. The nationality and registration mark are separated by a hyphen.
Aircraft registered prior to January 1, 1974 were identified with the Nationality mark CF, followed by three letters for the registration mark. Aircraft manufactured prior to January 1, 1957, are known as "vintage aircraft" and may always retain a CF nationality mark if the owner so desires.
True North
Post by True North »
nysa wrote:Air Canada has the government in their pocket, they are making this difficult hoping that WestJet will not increase their international widebody expansion and threaten Air Canada's most lucrative market. They don't want WestJet acquiring these 767's that cost a fraction of the new shiny 787 that Air Canada has on order especially with jet fuel staying cheap for longer. This corrupt government and its agencies together with the crony judges always protected Air Canada and made decisions favoring the company that were anti competitive or against its workers for eg. Aveos, lockouts, gulf carriers, arbitration, etc, its all rigged.
:lol: :prayer:
Thanks for that. I haven't laughed that hard in a long, long time. Actually spewed beer on my keyboard.
According my sources, just the opposite is true. They tell me Transport Canada has been extremely helpful and cooperative. The issues are all paperwork related, complicated by the fact the fact that there are no bilateral agreements between TC and CASA.
Troubleshot
Post by Troubleshot »
Basically once WJ Tech Ops got ahold of it they found over 100 snags, which doesn't surprise me. They won't put it into ops till its good and ready. I'm sure it will be a good machine after they have been running it for a few weeks. My experience tells me the first few weeks will be troublesome and they'll probably have AME's going with the machine till they can trust it.
canuckwings
Longtimer wrote:What you call the C mark has absolutely nothing to do with ETOPS.
CARs 202.03
Got it, thanks :)
Troubleshot
CARs 202.03
Got it, thanks :)
most times you'll see marks similar to these photos for ETOPS certified planes.
privateer
Post by privateer »
Yawn..
So any real news when this thing is going flying?
Longtimer
Post by Longtimer »
If news is bad then watch for a very quiet announcement late on a Friday.
I suspect since it has yet to rack up any operating hours the ETOPS certification will not be granted until sometime in Jan(Y>A>G)
Longtimer
Post by Longtimer »
flight tracker now showing some action today for the aircraft:
When you go to the site, click on the small aircraft symbol at the bottom right.
http://www.flightradar24.com/data/airpl ... j/#7b92fbb
The video shows what could be "swinging the compass".... or is that too old fashioned?
evilgravy
Post by evilgravy »
looks like today might be the day! WS 8977 YYC-YYZ 1510 ETD
https://flightaware.com/live/flight/WJA8977
dazednconfused
Post by dazednconfused »
taxiing out right now
leftoftrack
Post by leftoftrack »
Are QF pilots doing the line Indoc or boeing supplied?
aerobod
Post by aerobod »
leftoftrack wrote:Are QF pilots doing the line Indoc or boeing supplied?
Boeing supplied pilots for the next 2 weeks or so.
aerobod
Post by aerobod »
The first widebody revenue flight for WS is now on it's way!:
https://flightaware.com/live/flight/CFO ... /CYYZ/CYYC
Longtimer
Post by Longtimer »
aerobod wrote:The first widebody revenue flight for WS is now on it's way!:
And only 1/2hr shown behind sked. :) Not too bad for a first of.
Looks like they used warp7 and made up the time. Would not want to be late for the photo op. :D
whiteguy
Post by whiteguy »
QF doesn't really have anything to do with the aircraft anymore....
Return to “WestJet”
