Superior Airways / Severn Enterprise operation from the late 1960's to 1974.
When ski season ended, the aircraft that had operated away from their home base
for the winter flew back to have floats installed for the summer.
Quite a number of the aircraft operated north of their home base during the winter
and because the ice went out earlier in the south it was necessary to remove the skis
and install a set of main wheels on the axels for the flight south. The skis were then
loaded into the aircraft so everything would return to the base together.
The one ski that was not removed was the tail ski. That was used as a brake during
taxi and landing.
Attached is a photo of Beaver CF-ODD that was taken in late April 1974. The aircraft
has had a set of main wheels installed for the flight back to its home base in Thunder Bay.
The tail ski can be seen in the photo still on the aircraft.
ODD had its skis removed on the ice in the bay in Sioux Lookout and was flown over to
the Sioux airstrip. The weather was not the best to go straight to Thunder Bay but the
ice conditions were getting bad so the Beaver was taken off the ice.
In the photo ODD was making a low pass down the Sioux Lookout airstrip where it landed.
It departed for Thunder Bay the next day.
Pine trees can be seen in the coloured runway cones that marked the taxiway and the
runway in the winter. Ski season is over.
