Keeping white shirts white
Anyone have some tips as to how to keep white shirts white? I've been having trouble as of late with yellowing. Could be the heat we've been having where I am, maybe the type of anti-antiperspirant. Who knows.
My current solution that works OK is Oxy Clean spray. I let it soak for a few hours before washing but even that seems to not be working the way it used to. I always feel one step behind especially during summers. From what I understand it's not the sweat but the anti-antiperspirant reacting with the sweat causing marks which regular bleach never seems to be able to remove. What deoderant/anti-persperant do you use? What detergent? Any tips/tricks?
Re: Keeping white shirts white
http://www.housecleaningcentral.com/en/ ... stain.html
I've heard lemon juice works for removing the build up from antiperspirants. That link has a bunch of other suggestions to try.
Alot of bleach.
Fill up your washing machine just with white shirts.
When the water is full for the old style machines or half way thru its fill up with the new front loading type, add about 1/2 liter of bleach.
I wash my 6 shirts all at once and they come out impeccable.
Also i change a shirt once a day. Even if its a 1 leg day.
The "yellow armpit " stains come also by a overload of deodorant in the fabric.
Hope it helps
Andy
Hope it helps
Andy
Meatservo
For the 'orrible brown "ring around the collar", I've read about using "Dawn" dish liquid and a toothbrush. You need to use the brush because the brown crap is greasy oil that apparently men's sweat has in greater abundance than women's, especially in the neck area. The surfactant needs to be physically agitated hence the brush. Gross, I know. Anyway apparently it has to be "Dawn" because it breaks down grease better than other brands (that might be why they use it to clean crude oil off baby ducks and otters and stuff)
I was planning on trying this at the week-end, because my uniform shirts all have the gross collar stain.
I've tried the bleach thing before but it doesn't seem to help the collar shit, plus the washed shirts smell really bleachy afterward. I guess I should have washed them again after the bleach?
I m surprised the neck didnt come clean .
I ve had my 6 shirts for 9 months now and they look just as new as the ones i ve just recieved.
I use gani fabric softner and yes tgere s some bleach snell but mostly its just " fresh" smell.
Andy
Andy
Use a bar of Sunlight Soap with a brush - works amazing for the neck stains. Just need some good scrubbing.Meatservo wrote:For the 'orrible brown "ring around the collar", I've read about using "Dawn" dish liquid and a toothbrush. You need to use the brush because the brown crap is greasy oil that apparently men's sweat has in greater abundance than women's, especially in the neck area.
Yellow stains are from the alum in anti-perspirents so switch to deodorant only and no more yellow pit stains.
LOL I am so glad I found this thread. I've used the dish soap/ toothbrush technique but it takes A LOT of scrubbing. I just throw some bleach in when I wash them once a week and scrub the collars once a month.
FlyB
FlyB
PostmasterGeneral
I always wear an undershirt. Just a plain, white cotton fruit of the loom Walmart special under shirt. I find doing that it keeps my outer shirts cleaner longer. In fact, the cotton is much better at wicking the sweat away, so even on a hot-as-balls day, I find I'm a lot cooler than if I were just wearing the outer shirt.
Stu Pidasso
Hang to dry, avoid putting them in the drier. Most uniform shirts are not exactly high quality, ours are outright garbage. Avoiding the heat of the drier helps.
Unfortunatley I sweat like a dog and without antiperspirants I'd have a waterfall dripping form my underarm.FICU wrote:Yellow stains are from the alum in anti-perspirents so switch to deodorant only and no more yellow pit stains.
Thanks for all the tips guys, yes the neck collar is also super frustrating. I'll try a few of these ideas out and see if anything makes an improvement.
PostmasterGeneral wrote:I always wear an undershirt. Just a plain, white cotton fruit of the loom Walmart special under shirt. I find doing that it keeps my outer shirts cleaner longer. In fact, the cotton is much better at wicking the sweat away, so even on a hot-as-balls day, I find I'm a lot cooler than if I were just wearing the outer shirt.
I find it hard to do this when it's 35* and 100% humidity. In the winter I do, which I guess explains why I tend to only have the stain issues in the summer.
I used the Dawn on the collar a few months ago for the first time. It actually worked pretty well. I didn't use a toothbrush though, but if I had it probably would have been even better.
goingnowherefast
Wear an undershirt, it gets yellow instead of the fancy shirt. Also, for the love of god, please wear deodorant. Don't be that stinky pilot nobody wants to fly with!
Meatservo
There's a lot of good ideas here. I'm going to tell my wife about them and see what happens.
I sweat a lot so have figured out what works best for me.
I use Oxyclean, but when I soak it or wash it I use HOT water, not warm or luke warm, hot!
I use an undershirt. Underarmour "Charged Cotton" works pretty well as it's a sport shirt. I am 6'5" and most undershirts are not long enough. Another good undershirt is a Eddie Bauer shirt - they come in tall sizes, that one never comes untucked!
When all else fails or you spill coffee/food on your shirt I resort to bleach but generally don't have to use it often. I use Deodorant vs Antiperspirant (I used to until I read how bad it can be for you) that combined with using an undershirt the biggest problem for me is my neck line and spilling coffee on it in turbulence!
Ever seen those 'stain sticks'? I have one you can rub in just before washing or leave on for up to a week in the hamper before washing. Really helps with the collar stains.
I picked up one of those stain sticks at Home Hardware, and it works GREAT! I haven't had to use it on yellow pit stains yet (cross my fingers/knock on wood I don't get them), but it is amazing at getting pen marks off the pockets, and the grunge from around the collar.
Just wear a white turtleneck under your shirt!
SuperchargedRS
Never had a problem with shirts turning yellow form contact from my body, misc dirt or BBQ sauce or something sure, yellow secretions not so much.
What your diet like?
Meatservo
Some people just have different body chemistry, Supercharged RS. When I was in my teens and twenties, my sweat would turn white cotton shirts yellow. But it didn't affect blended fabrics. Now I'm older that doesn't happen anymore. The "ring around the collar" stains are very common for men and have to do with a waxy substance that is in male sweat. Some people have it more than others.
We think of sweat as being a cooling agent for our bodies, but evolutionarily it serves many more purposes. In our modern lives we don't like to acknowledge it but as mammals our sweat carries pheromones that are meant to transmit sexual information to females, hormones that transmit aggressiveness information to other males, chemicals that are meant to keep our fur in good condition, all kinds of disgusting shit. And that's just MALE sweat. Don't get me started on what is in our female friends' sweat. You don't want to know. And you're right, diet will play a part too. We're just pretending to be civilized. Each one of us is living inside a dirty animal and trying to make the best of it while wearing white fabrics.
I wear white Kirkland undershirts from Costco year round. Keeps your work shirt from getting stained and cheap and easy to replace
I've seen some folks put clear tape on the inside of their collars to prevent stains. Apparently it works but I've never tried it.
Tail-Chaser
I'm jumping on the undershirt band wagon. I also don't get more than one day of use per white shirt unless it's an exceptionaly easy day.
Even with the under shirt I only wear the work shirt for one day between washings because of the collar dirt/oil or whatever it is. However the undershirts do prevent the yellow armpit stains on the work shirt
