Citation down North of Kelowna
ChrisEvans
Re: Citation down North of Kelowna
Just for information;
N102PT Single Pilot CJ crash in 2008 - 2 fatal - owner and her son - 6 minutes after departure
http://www.ntsb.gov/_layouts/ntsb.aviat ... 0172&key=1
I wouldn't have believed that could bring a plane down, especially with 2 other AI's in the cockpit but then I watched a guy do it in his first time in sim and despite my best efforts I couldn't get him to give me control and the instructor had to freeze the sim. That's with 2 pilots and SOP's. You can talk about AI failures all you want but they are so hard to identify at first if you are not following a proper scan or if something else distracts you. Once they build it's pretty easy to see something's wrong but by then it can be too late.ChrisEvans wrote:Just for information;
Didn't see "7200" "Flightaware" data. It seemed the "-2200 fpm" was simply difference between the two last hits: the "7000" minus "4800". In that last minute though, it appears possible the AC finishes very the steep 3000'/min climb and then descent a few seconds into it (if the first ~20 secs in that last minute of data is steep climb) ... yet the last 40sec or so is a very steepening descent then ? Not impossible there to have a total altitude change between hits of 4K, including both the up&down. Just my thoughts from the data at hand, ... the evidence for "higher" speed. (One early news article quoted a source for "8000" and another suggested 'down from 4000 in 20 sec')cncpc wrote:7200 and the problems started. The 120 knot speed from FlightAware was not accurate. It was higher than that. The -2200 fpm was accurate.
Some useful information came from ATC radar data.pdw wrote:Didn't see "7200" "Flightaware" data. It seemed the "-2200 fpm" was simply difference between the two last hits: the "7000" minus "4800". In that last minute though, it appears possible the AC finishes very the steep 3000'/min climb and then descent a few seconds into it (if the first ~20 secs in that last minute of data is steep climb) ... yet the last 40sec or so is a very steepening descent then ? Not impossible there to have a total altitude change between hits of 4K, including both the up&down. Just my thoughts from the data at hand, ... the evidence for "higher" speed. (One early news article quoted a source for "8000" and another suggested 'down from 4000 in 20 sec')cncpc wrote:7200 and the problems started. The 120 knot speed from FlightAware was not accurate. It was higher than that. The -2200 fpm was accurate.
RatherBeFlying
In my case the left seat turned us inverted at 16,000' and sat there frozen while I was shouting in his ear that he was upside down and had to roll right side up until we hit the "ground".I wouldn't have believed that could bring a plane down, especially with 2 other AI's in the cockpit but then I watched a guy do it in his first time in sim and despite my best efforts I couldn't get him to give me control and the instructor had to freeze the sim. That's with 2 pilots and SOP's. You can talk about AI failures all you want but they are so hard to identify at first if you are not following a proper scan or if something else distracts you. Once they build it's pretty easy to see something's wrong but by then it can be too late.
In a real airplane you may have to grab the controls and possibly whack your buddy in the head. Given the small likelihood of recovering from a bank past 90°, a bank going past 45° is time for drastic measures.
ChrisEvans
Incidentally, the investigation by NTSB on N102PT took just over three years to complete, longest I've seen in recent history.
It's not clear that there ever was an AI failure.
The fact that the airplane was operating at night in instrument meteorological conditions and the departure was an accelerating climbing turn, along with the pilot's demonstrated complacency, created an environment conducive to spatial disorientation. Given the altitude and speed of the airplane, the pilot would have only had seconds to identify, overcome, and respond to the effects of spatial disorientation.
The Maine accident climbed on track for 38 sec and then radioed the failure ... and shortly after radioed again not knowing where to turn. So it gave the impression it's understood there was a failure of the information in very rapid forward speed in clear ice, and plane was outside in FZRA. What else can an investigation conclude about it if no proof left of a pitot system obstruction. How does the investigation differentiate from "spacial disorientation" with attitude indictor O.k. ... or disoriented from failure only ?
Because there were two other attitude indicators.pdw wrote:The Maine accident climbed on track for 38 sec and then radioed the failure ... and shortly after radioed again not knowing where to turn. So it gave the impression it's understood there was a failure of the information in very rapid forward speed in clear ice, and plane was outside in FZRA. What else can an investigation conclude about it if no proof left of a pitot system obstruction. How does the investigation differentiate from "spacial disorientation" with attitude indictor O.k. ... or disoriented from failure only ?
In total blockage?
By "failure" (in Maine report) the pilot's radio message also can imply 'not useable' (all of them), so pitot blockage may or may not be realized at that point .. if in fact was still possible. The comparison looks right; in Kelowna also in climb although still in process of the light right turning in the direction of an enroute heading.
In a lot of spatial disorientation accidents, the pilot blames the AI even though it's working fine. When the AI doesn't match up with what your body senses, a natural instinct is to think the AI is broken. The investigation didn't find any possible sources of failure for the AI.pdw wrote:In total blockage?
Where do you see the right turn? In Flightaware?pdw wrote:The comparison looks right; in Kelowna also in climb although still in process of the light right turning in the direction of an enroute heading.
ASN has the flightaware link for the flight.
The first 3 radar hits on there are for two minutes of flight: 360deg, 12deg and 33deg (for 4000', 7000' and 4800' respectively). For the fourth hit at the end of the 3rd minute of data, which shows already off radar, is "estimated" for "74deg". At that point of the flight it does appear (from this data) the AC was approx at the halfway point thru a gradual turning required to get onto an intended easterly heading laid out in the flightaware estimates.
Ok. Flight Aware. Those aren't all the radar hits that took place between 7200 and 4800. The loss of control was at 7200 after a steady climb at 160 knots with everything normal and the beginnings of a slight right turn onto course for Menbo, I assume. The 33 degree heading was the last heading. It wasn't the only heading on the way down from 7200.pdw wrote:ASN has the flightaware link for the flight.
If the assumption is that the climb to 7200 was on autopilot, then what subsequently happened to the autopilot? It doesn't get spatially disoriented.
In a 604 single pilot Citation, do you need a functioning autopilot?
Can't imagine the autopilot not "functioning" upon departure in this aircraft.
Then if it was, it stopped functioning.pdw wrote:Can't imagine the autopilot not "functioning" upon departure in this aircraft.
There's ones without pitch axis. In earlier discussion was surprised no-one mentioned sticky snow, as there's mention 5ft snow fell somewhere in the mountians at the time ...
The Maine accident had freezing precip (including sticky snow / coarse texture). In rereading the report, sure enough, no mention of static source-intake blockage of any kind except "parked outside in FZRA". That is saying (in report) it was spacial disorientation and verifying it was 'with perfectly functioning instruments'. If the static source is iced shut ... can say instruments are fine ... OK.
Then let's refrase: How would destroyed instruments save evidence to indicate to investigators their static source was iced or not,... seeing that any ice-blockage melts away if the crash site gets above freezing before investigative teams get there.
The impact of the indicator on the instrument face may leave a legible mark,thus giving a clue to what it was indicating when the aircraft impacted the ground.
Daryl
Daryl
The airplane climbed on track to 7200 feet and control was lost after a small turn to the right. It was never doing 120 knots after control was lost. That is a misinterpretation from the rough Flight Aware points.
It impacted at very high speed, vertically.
Any Citation pilots with an informed view on whether this climb would have been on autopilot or hand flying?
And the effect on the autopilot of pitot-static icing?
Likely spatial disorientation likely due lack of proficiency and recency.
http://www.cbc.ca/news/canada/calgary/t ... -1.4635541
Billy the Goat
I like how fatigue is never considered to be a factor. As though a 17 hour split duty day is not tiring. I guess because it’s legal means he must have been well rested.
Diadem
He had ten hours in a hotel. That's not a split duty day, that's a full reset.Billy the Goat wrote: ↑Thu Apr 26, 2018 6:58 pm I like how fatigue is never considered to be a factor. As though a 17 hour split duty day is not tiring. I guess because it’s legal means he must have been well rested.
Billy the Goat
Sure. Doesn’t mean he got 8 hours of sleep, or was even rested at all, does it? Can you go to bed at 9AM and sleep all day? I can’t.Diadem wrote: ↑Thu Apr 26, 2018 7:15 pmHe had ten hours in a hotel. That's not a split duty day, that's a full reset.Billy the Goat wrote: ↑Thu Apr 26, 2018 6:58 pm I like how fatigue is never considered to be a factor. As though a 17 hour split duty day is not tiring. I guess because it’s legal means he must have been well rested.
Schooner69A
An hour flight from Calgary to Kelowna, spend the day in the hotel, and then an hour flight back? Tiring? Not half.
Did fifteen years of similar flying. Single pilot in a turbo Commander 1000 and two-up in Citation and Hawker 700.
The C500 is a great entry level jet, however, given this pilot's age and experience level, it's possible that he was overwhelmed. Or, there were medical factors. We'll never know.
I think that the TSB is hopergroping on it's findings... However, that's their privilege.
Sad for all concerned.
Yeah, as someone who’s done over a dozen legs extending to a 17 hour duty day, spending a day sitting in a hotel room, sleeping, or otherwise relaxing is not a recipe for fatigue. It’s well above min rest and split/rolling duty days too. A medevac crew should be so lucky.
Nope. Single pilot, low experience, not recent, old jet with old avionics. Couldn’t even track inbound to a beacon on one of the simplest departures there is.
This would not have happened with two experienced and current pilots flying a modern jet. Had this been a charter or fractional, they likely would have had a fresh plane and crew for the return trip, and it probably would have cost less, too.
RIP
RIP
