Aerial Spraying
Aerial Spraying
Greetings,
Living in Southern Arizona for the winter. Our property is next to agricultural land, cotton this year. The planes started spraying at 4;15 a m this morning in total darkness and now are back at it at 6:30 p m. in total darkness. I tried looking in the FAR`s for hours for spraying, like dawn to dusk, but can`t find anything.
I`ve always thought this was a VFR daylight type of operation.
Can someone please shed some light on this topic for me?
Thanks.
Thanks.
TeePeeCreeper
- Cat Driver
Re: Aerial Spraying
They spray after dark because the air is more stable and the thermals caused by the sun heating the earth are calmed down.
Also the winds generally die down after dark, chemical drift is a very serious concern when applying them from an aircraft.
By the way of all the jobs in aviation I had aerial application was by far my favourite, especially in the helicopters.
Re: Aerial Spraying
Aerial application at night in desert areas is very normal and common. It gets hot during the day, engines and wings don't perform nearly as well in the cool night. Also the spray evaporates quickly when hot and may not reach the crop as well as it should. Bees are in the hive at night, therefore spraying when they are sleeping saves millions of bee workers. Saving bees is critical to many crops. There are also many insects that crawl to the top of the plant an night and go to the bottom during day.
Re: Aerial Spraying
Cat Driver wrote:They spray after dark because the air is more stable and the thermals caused by the sun heating the earth are calmed down.
Thanks Cat. New the reasons for spraying early or late re air stability, etc but was curious whether doing it at night was legal. Rude awakening so early with a roaring, low flying PT 6 only 150 ft from the house!
Got low in Grumman Trackers (50`) and C 130`s, 5 ft doing LAPES, but nothing like these guys!!
Thank you Culver. Great info re evaporation, bees and bugs.
- Cat Driver
Re: Aerial Spraying
The height above the crop is dependent on several factors, for instance when spraying potatoes for potato blight we flew with the wheels so close to the plants we often clipped them with the wheels, the reason for being so low was to use the down wash of the wings to turn the plant leaves over and thus apply chemical to both the top and bottom of the plants.
The Boeing Stearman really had a strong downwash, and of course the helicopters were superb for downwash.
Flying at zero to maximum of two feet above the crops was day after day required real attention to what you were doing and left little room for inaccurate flying.
If there were trees or power lines beside the field the initial approach was a steep decent path roughly 45 degrees with a flare at one to two feet as close to the start of the crop as possible.
Made judging wheel landings dog nuts simple.
Re: Aerial Spraying
I read a story about night spraying , a few years ago, spraying in where else, california. If there was ever a type of flying starting to get out there towards the edge of the envelope, night spraying has to be one of them....
switchflicker
Re: Aerial Spraying
Not sure about the FARs, but probably comparable to the CARs. There is an Canadian Ops Spec for night aerial application. It requires a fairly complex operation, but if all the components are in place it shouldn't be too much of a deal to get the authorization. Too lazy right now to look up the Ops Spec number.
"I'd rather have it and not need than to need it and not have it" Capt. Augustus McCrae.
Re: Aerial Spraying
Just to add to the comments, the night spraying alleviates interactions (usually negative) with field workers.
My ex employer runs an operation in Yuma, AZ. 95% of the spraying is night.
- Amelia Earhart
- Amelia Earhart
Re: Aerial Spraying
Thank you everyone for all the great info and insight.
Fly Safe
Fly Safe
Re: Aerial Spraying
Sounds like a great job. More risk involved for sure.Cat Driver wrote:The height above the crop is dependent on several factors, for instance when spraying potatoes for potato blight we flew with the wheels so close to the plants we often clipped them with the wheels, the reason for being so low was to use the down wash of the wings to turn the plant leaves over and thus apply chemical to both the top and bottom of the plants.
Made judging wheel landings dog nuts simple.![]()
But a job where you truly hold your life in your hands and your dedication and skill are all that
keep you safe.
I daydream about a sideline aerial fertilizing and seeding business.
Hell even if I just broke even.....
Someday maybe.
- Cat Driver
Re: Aerial Spraying
The Tobacco Fields - By . .
For generations the farmers of southern Ontario have planted cared for harvested and cured tobacco in a small area on the northern shores of lake Erie. Our part in this very lucrative cash crop was aerial application of fertilizers and pesticides better known as crop dusting.
At the end of the twentieth century this form of farming is slowly dying due to the ever-increasing movement of the anti-smoking segment of society. Although few would argue the health risks of smoking it is interesting that our government actively supports both sides of this social problem. Several times in the past ten or so years I have rented a car and driven back to the tobacco farming area of Southern Ontario, where over forty years ago I was part of that unique group of pilots who earned their living flying the crop dusting planes.
The narrow old highways are still there, but like the tobacco farms they are slowly fading into history as newer and more modern freeways are built. The easiest way of finding tobacco country is to drive highway 3, during the nineteen forties and early fifties this winding narrow road was the main route from Windsor through the heart of tobacco country and on to the Niagara district. Soon after leaving the modern multi lane 401 to highway 3 you will begin to realize that although it was only a short drive you have drifted back a long way in time. Driving through the small villages and towns very little has changed and life seems to be as it was in the boom days of tobacco farming, when transients came from all over the continent for the harvest. They came by the hundreds to towns like Aylmer, Tillsonberg, Deli and Simcoe, these towns that were synonymous with tobacco have changed so little it is like going back in time.
Several of the airfields we flew our Cubs, Super Cubs and Stearmans out of in the fifties and early sixties are still there. Just outside of Simcoe highway 3 runs right past the airport and even before turning into the driveway to the field I can see that after all these years nothing seems to have changed. I could be in a time warp and can imagine a Stearman or Cub landing and one of my old flying friends getting out of his airplane after another morning killing tobacco horn worms, and saying come on . lets walk down to the restaurant and have breakfast. The tobacco hornworm was a perennial pest and our most important and profitable source of income. Most of my old companion's names have faded from memory as the years have passed and we went our different ways but some of them are easy to recall.
Like Lorne Beacroft a really great cropduster and Stearman pilot. Lorne and I shared many exciting adventures in our airplanes working together from the row crop farms in Southern Ontario to conifer release spraying all over Northern Ontario for the big pulp and paper companies. Little did we know then that many years later I would pick up a newspaper thousands of miles away and read about Lorne being Canadas first successful heart transplant. I wonder where he is today and what he is doing?
There are others, Tom Martindale whom I talked to just last year after over forty years, now retired having flown a long career with Trans Canada Airlines, now named Air Canada. Then there was Howard Zimmerman who went on to run his own helicopter company and still in the aerial applicating business last I heard of him. And who could forget Bud Boughner another character that just disappeared probably still out there somewhere flying for someone.
I have been back to St. Thomas, another tobacco farming town on highway 3 twice in the last several years to pick up airplanes to move for people in my ferry business. The airport has changed very little over the years. The hanger where I first learned to fly cropdusters is still there with the same smell of chemicals that no Ag. Pilot can ever forget. It is now the home of Hicks and Lawrence who were in the business in the fifties and still at it, only the airplanes have changed.
My first flying job started in that hangar, right from a brand new commercial license to the greatest flying job that any pilot could ever want. There were twenty-three of us who started the crop dusting course early that spring, in the end only three were hired and I was fortunate to have been one of them.
With the grand total of 252 hours in my log book I started my training with an old duster pilot named George Walker. Right from the start he let me know that I was either going to fly this damned thing right on its limits and be absolutely perfect in flying crop spraying patterns or the training wouldn't last long. It was fantastic not only to learn how to really fly unusual attitudes but do it right at ground level.
To become a good crop duster pilot required that you accurately fly the airplane to evenly apply the chemicals over the field being treated. We really had to be careful with our flying when applying fertilizers in early spring as any error was there for all to see as the crop started growing. This was achieved by starting on one side of the field maintaining a constant height, airspeed and track over the crop. Just prior to reaching the end of your run full power was applied, and at the last moment the spray booms were shut off and at the same time a forty-five degree climb was initiated. As soon as you were clear of obstructions a turn right or left was made using forty five to sixty degrees of bank. After approximately three seconds a very quick turn in the opposite direction was entered until a complete one hundred and eighty degree change of direction had been completed. If done properly you were now lined up exactly forty-five feet right or left of the track you had just flown down the field.
From that point a forty-five degree dive was entered and with the use of power recovery to level flight was made at the exact height above the crop and the exact airspeed required for the next run down the field in the opposite direction to your last pass. Speed was maintained from that point by reducing power.
To finish the course and be one of the three finally hired was really hard to believe. To be paid to do this was beyond belief. When the season began we were each assigned an airplane, a crash helmet, a tent and sleeping bag and sent off to set up what was to be our summer home on some farmers field. Mine was near Langdon just a few miles from lake Erie.
Last year I tried without success to find the field where my Cub and I spent a lot of that first summer. Time and change linked with my memory of its location being from flying into it rather than driving to it worked against me and I was unable to find it. Remembering it however is easy, how could one forget crawling out of my tent just before sunrise to mix the chemicals? Then pump it into the spray tank and hand start the cub. Then to be in the air just as it was getting light enough to see safely and get in as many acres as possible before the wind came up and shut down our flying until evening. Then with luck the wind would go down enough to allow us to resume work before darkness would shut us down for the day. The company had a very good method for assuring we would spray the correct field.
Each new job was given to us by the salesman who after selling the farmer drew a map for the pilots with the location of the farm and each building and its color plus all the different crops were written on the map drawn to scale. As well as the buildings all trees, fences and power lines were drawn to scale. It was very easy for us to find and positively identify our field to be sprayed and I can not remember us making any errors in that regard.
Sadly there were to many flying errors made and during the first three years that I crop-dusted eight pilots died in this very demanding type of flying in our area. Most of the accidents were due to stalling in turns or hitting power lines, fences or trees.
One new pilot who had only been with us for two weeks died while doing a low level stall turn and spinning in, he was just to low to recover from the loss of control. He had been on his way back from a spraying mission when he decided to put on an airshow at the farm of his girlfriend of the moment. This particular accident was to be the last for a long time as those of us who were flying for the different companies in that area had by that time figured out what the limits were that we could not go beyond.
Even though there were a lot of accidents in the early years they at least gave the industry the motivation to keep improving on flying safety, which made a great difference in the frequency of pilot error accidents. Agricultural flying has improved in other areas as well especially in the use of toxic chemicals.
In 1961 Rachel Carson wrote a book called "The silent spring. " This book was the beginning of public awareness to the danger of the wide area spraying of chemicals especially the use of D.D.T. to control Mosquitoes and black flies.
For years all over the world we had been using this chemical not really aware that it had a very long-term residual life. When Rachels book pointed out that D.D.T. had began to build up in the food chain in nature, she also showed that as a result many of the birds and other species were in danger of being wiped out due to D.D.T. Her book became a best seller and we in the aerial application business were worried that it would drastically affect our business, and it did.
The government agency in Ontario that regulated pesticides and their use called a series of meetings with the industry. From these meetings new laws were passed requiring us to attend Guelph agricultural college and receive a diploma in toxicology and entomology. I attended these classes and in the spring of 1962 passed the exams and received Pest Control License Class 3 - Aerial Applicator.
My license number was 001. Now if nothing else I can say that I may not have been the best but I was the first. Without doubt the knowledge and understanding of the relationship of these chemicals to the environment more than made up for all the work that went into getting the license. From that point on the industry went to great length to find and use chemicals less toxic to our animal life and also to humans.
It would be easy to just keep right on writing about aerial application and all the exciting and sometimes boring experiences we had, however I will sum it all up with the observation that crop dusting was not only my first flying job it was without doubt the best. I flew seven seasons' crop dusting and I often think of someday giving it another go, at least for a short time.
Re: Aerial Spraying
Thanks ., great stories.
FYI: DDT can still legally be manufactured in the U.S., but it can only be sold to, or used by, foreign countries.
- Rank Moderator
Re: Aerial Spraying
How do they actually do it, though? Night vision goggles? floodlights at the end of each swath? Or is it more of a twilight thing, where there is a discernible horizon?
Happiness is V1 at Thompson!
Re: Aerial Spraying
Dark. No twilight. Very powerful lighting. And, a plethora of local knowledge.
https://www.youtube.com/watch?v=10BYCPrxgsM
- Amelia Earhart
- Amelia Earhart
garareporter
Re: Aerial Spraying
Who wrote this?
Cat Driver wrote: ↑Mon Nov 14, 2016 1:26 pm The Tobacco Fields - By . .
Re: Aerial Spraying
PM me and I can tell you if you want. I don't think he would mind
