US radio call
rotorspeed
US radio call
I'm asking in case I fly to the US. In initial call to station or ground in fx Cessna 172 do they just announce aircraft type such as Cessna only or do they say 172 as well
- Redneck_pilot86
Re: US radio call
I rarely hear "cessna 172", what they tend to use is "skyhawk" or whatever the name of the type is. Most controllers I've talked to near the border are used to Canadians saying "Cessna 172", and it also gives them a bit of an idea that the ident coming is not an N registration and lets them know to pay attention. Be prepared for clearances such as "number 2 to the skyhawk in the downwind" or similar.rotorspeed wrote:I'm asking in case I fly to the US. In initial call to station or ground in fx Cessna 172 do they just announce aircraft type such as Cessna only or do they say 172 as well
rotorspeed
Canadian Skyhawk
Re: US radio call
The correct radio call if flying your 172 in the USA is "XXX Centre, Canadian Skyhawk C-GXYZ".
linecrew
Re: US radio call
Taken from another thread about radio calls, this is handy:
Re: US radio call
Reference?Canadian Skyhawk wrote:The correct radio call if flying your 172 in the USA is "XXX Centre, Canadian Skyhawk C-GXYZ".
Canadian Skyhawk
Re: US radio call
Reference: FAA Order JO7110.65W effective Dec.10, 2015, section 2-4-20 b.1.
"Civil. State the aircraft type or the manufacturer’s
name followed by the letters/numbers of the
aircraft registration, or state the letters or digits of the
aircraft registration or call sign.
EXAMPLE−
“Stationair F−L−R−B.”
“C−F−L−R−B.” "
While it is not necessary to state "Canadian" as the prefix, it has been my experience that is accepted practice in the field. It also immediately cuts through any confusion on the controller's part, confusion which is proportional to one's distance south from the 45th parallel (or 49th for Westerners).
EXAMPLE−
“C−F−L−R−B.” "
Re: US radio call
So what do you say if you're in a Cessna 150/152? I've heard Cessna 172 lots in the States and there doesn't seem to be any confusion. Certainly you do hear Skyhawk more, but either would work just fine.
One big difference is you won't be cleared left or right downwind, they will say "Make left traffic". Uncontrolled airport you will report "Ident, left traffic for rwy XX" rather than "Ident, left downwind for rwy XX" Oh yeah, and rwy 0x will be simply rwy x for any runway less than 10.
Mark Twain
Mark Twain
Re: US radio call
So the correct radio call would be "XXX Center, Skyhawk C-GXYZ" or "XXX Center, Cessna 172 C-GXYZ" then?
readyou5by5
Re: US radio call
While I appreciate the debate about preparing the quintessentially perfect trans-national radio call to ATC as much as any one else, I'd spend less time worrying about that and more time worrying about flying the airplane better.
Canadian Skyhawk
Re: US radio call
+1.
And don't forget the other details, like making sure your return flight plan filed in Canada has been received by American controllers, properly completing the eApis, advising CBSA before you cross the border onyour return and making sure you land at an AOE that is open at your time of arrival. You know, just to avoid any unnecessary encounter with unhappy uniformed guys carrying guns....especially south of the border!
SuperchargedRS
Re: US radio call
Approach Cessna C-ABC 3 nm north of XYZ, the C kinda gives away the Canadian part.
Re: US radio call
SuperchargedRS wrote:Approach Cessna C-ABC 3 nm north of XYZ, the C kinda gives away the Canadian part.
You'd think, but I've had them reply November Charlie ABC.
The weird call for me was in Great Falls, which was "make left for runway 07".
Re: US radio call
Presumably you should be giving the full callsign initially, C-GABC.co-joe wrote:SuperchargedRS wrote:Approach Cessna C-ABC 3 nm north of XYZ, the C kinda gives away the Canadian part.
Re: US radio call
Canadian Skyhawk wrote:Reference: FAA Order JO7110.65W effective Dec.10, 2015, section 2-4-20 b.1.
EXAMPLE−
“C−F−L−R−B.” "
I fly a great deal in the US and I don't hear "Canadian" very much and it is not IMHO accepted practice, just bad airmanship. C=Charlie not Canadian and I cringe when I hear it, makes one thing of Gaylord/Reginald in "Smokie and the Bandit"
https://www.youtube.com/watch?v=RjR8YrNUDTs
"I need a time machine"
Re: US radio call
Co-joe, I really doubt they said 07.
Mark Twain
Mark Twain
Re: US radio call
Probably right. The day was Oct 5, 1997 according to my logbook.xls, I barely remember what I had for breakfast yesterday. Doesn't change the story though.5x5 wrote:Co-joe, I really doubt they said 07.
Cessna 180
Re: US radio call
I've had no problems saying either just the tail number (charlie golf alpha bravo xray). sometimes I added "diamondstar" or "skyhawk." They don't seem to care but they may ask aircraft type. I've also had controllers abbreviate my tail number that ends in an I or O to 1 or 0 (i.e. 0AB).
