WestJet To Launch ULCC
- NewCommercialPilot
Re: WestJet To Launch ULCC
Well there is that seniority elephant in the room so togetherness might be an ephemeral notion.
The Raven wrote:When is the vote?
The vote opened this morning and runs until next Friday.
All WJ pilots should dig out a pencil and a sheet of paper and lay out the following headings:
WHAT WILL I GAIN WHAT WILL I LOSE
If it's obvious that you will gain significantly more than you lose, then go for it.
However, if the loss column far exceeds the profit column....
I once worked for a company that blamed the union they had for 6 months for their bankruptcy. No contract in place, no change in working conditions other than now having CARs and the labour code enforced and no changes in their contracts yet they went under and blamed the union.Arctic84 wrote:You got me there. It's unions that manage companies into the ground. Always suspected that. Like how I never get tired of hearing how when C3 went out how the union didn't do a thing for the pilots. Was it the union that decided to buy Royal and Canjet without any due diligence? Was the union to blame for the 911 attacks?squawk wrote:Blaming the company and its management has been union mantra since time in memorable.Arctic84 wrote:Sure I will. It's always been overpriced pilots that bankrupt airlines, never incompetent management.
You just keep on giving back until it feels good. Maybe if you get right back to minimum wage, you can keep working forever at the ULCC.
Get real.
Unions do not bankrupt companies, what's the point. Unions can sometimes be inflexible BUT that is the EMPLOYEES doing not the union.
https://eresonatemedia.com/
https://bambaits.ca/
- infiniteregulus
Rudder, I was curious as to your credentials and knowledge of ALPA policy, and then I read the following article: http://www3.alpa.org/LinkClick.aspx?fil ... tabid=3345rudder wrote:You could not be more wrong in trying to apply 'policy' in the fashion that you are to try to create conflict where none exists.NewCommercialPilot wrote:
A merger down the road would be a nightmare if the ALPA President approved a non-DOH seniority list. That is why he won't approve it. That, and a lawsuit from OTS pilots against ALPA for violating it's constitutional duty to follow the DOH policy which has been in effect for 60 years.
The ULCC may eventually be populated solely by ex-Encore pilots torpedoed by ALPA policy on DOH (at mainline) and seniority.
The ALPA policy on constructing a local pilot seniority list is rooted in DOH to prevent historical instances where some companies try to generate arbitrary lists which may favour 'friends of management' or other crazy deals. It certainly is not intended to displace existing agreements in place that are supported by the pilots that have just opted for ALPA representation. Logically, such arrangements would be preserved in the CBA if supported by the majority.
And insofar as a future merger is concerned - most pilot seniority lists that are a result of an seniority integration arbitration are no longer DOH based. So DOH is a factor but just one of many. A review of the current ALPA Merger Policy will bear this out as will the arbitrated decisions generated within the last 5 years under that policy.
and realized you may have more than a passing interest in what happens in the current vote.
Seeing as you are familiar with the steps necessary to change ALPA policy, you will understand that Executive Board policy has to be followed by MECs, as per the ALPA constitution. Accordingly, the 60 year old Executive Board policy governing seniority list construction (based on DOH) must be followed. If policy was subject to the capriciousness of each pilot body, then why have a policy in the first place?
One of the ALPA OC's biggest beefs with the current representation is the implied lack of structure and the fluidity of the agreements. This of course is an incorrect assumption only discussed to further their agenda. But its ok to modify ALPA policies, procedures and administration manuals to suit the flavour of the day.
Can you say "double standard"?
Maybe they're taking a page out of the Trump playbook...say anything to get elected only to run into reality while in office and backtrack on many promises. This would be my prediction should they get in.
Right, like the current WJPA doesn't only publish the facts that suit them :
90% voted in favour of new fees !
( there was no 0% option which 70? % would have taken )
Negotiated unlimited sick days for PT pilots !!
( after unlimited being taken- Away by a middle manger who under the current lack of legal status of our agreement can make changes at will )
We can already see management wanting to offer ULCC at wages below ours... And sadly the WJPA is too cosy to stand up and say NO.
can't wait till Alpa arrives. 5 days ..
Can't come soon enough. The majority of pilots have had enough and the results the 13th will prove as much.
Just callin it like it is.
It's amusing that Rudder would give force and effect and legal validity to an "agreement" that the ALPA OC and indeed ALPA itself says is not enforceable. And exactly how could he state that when ALPA's duty is to its bargaining unit members at WestJet mainline, and not to "future" members?
Indeed, the arbitrary moves by management to give preferential seniority to friends that Rudder referred to is exactly what WJ and the WJPA agreed to with its WPDL. In this case, the "friends"
are pilots who came from a separate company called Encore. Why couldn't the membership at WJ agree to do the same thing to pilots who came from SunWing? Or Porter?
Once upon a time, ALPA had a policy of denying membership to blacks, Asians, Latinos, and women. They eventually changed that discriminatory practice. In spite of numerous opportunities to do so, ALPA has never altered its 1956 Executive Board policy requiring ALPA to use the "strongest means" to ensure first contract seniority lists are constructed by DOH.
And you believe the current agreement, including the One List, is without legal validity. Unlike Rudder, an "experienced" ALPA member who believes the agreement is enforceable..80@410 wrote:Right, like the current WJPA doesn't only publish the facts that suit them :
The only news about the WestJet commitment that I can find on the Boeing site is a quote of the WestJet announcement. Strange that Boeing has not published their own announcement of a WestJet order.
Riiiigght...the company will never do anything that'll violate a CBA. It's like a force field around the bargaining unit..80@410 wrote:Right, like the current WJPA doesn't only publish the facts that suit them :
What a relief that well never have to file a grievance of any kind.
Mildly delusional to think this way.
And you know this how? You took a survey? And of course, who wouldn't take something for nothing..80@410 wrote:Right, like the current WJPA doesn't only publish the facts that suit them :
This is a bad thing??Negotiated unlimited sick days for PT pilots !!
Again, utter nonsense. Your agreement is legally binding under law. You can keep saying it isn't but that doesn't change the facts.( after unlimited being taken- Away by a middle manger who under the current lack of legal status of our agreement can make changes at will )
This always intrigues me. An Association of WestJet pilots, made up of pilots elected by the other pilots - and they're cozy with management. Sounds like more pro-ALPA raving to me.We can already see management wanting to offer ULCC at wages below ours... And sadly the WJPA is too cosy to stand up and say NO.
What you really mean is a lot of pilots have been told the same lies enough times by the pro-ALPA contingent that they are starting to believe them. Standard recruiting practice. It will be interesting indeed but from what I'm hearing it's far from a slam dunk.can't wait till Alpa arrives. 5 days ..
Either way this vote goes it sure seems to be a divided house. It would seem some soul searching is in order
Having some experience is labor relations in my previous life in the aviation industry, it is accurate to say that no union will invite itself on the premises unless invited to do so by the folks who want representation. Of course there is a vote amongst the group who are seeking representation to see if they really want an employee union. I am not an airline pilot so have no knowledge on ALPA but I will go out on a limb and suggest they are a professional organization and will respect the wishes of the WJ pilot group should they decide they are happy with the current situation with their employer and certification isn’t required. I bet APLA would be happy to hear a group of employees are content in their current work environment and there wouldn’t be any animosity towards said group. I am of the view there are many misconceptions on what certified representation means biggest one being legality.
I understand your point. It is however, a public forum with public debate with its own set of guidelines. This debate is mostly common sense versus ideology. We have a private forum for this, but AVCANADA has provided an alternative venue.hurtin'albertan wrote:Why don't you guys keep the internal sh!t internal. You make all Wj pilots on both sides of the debate look like idiots carrying on like this. Who are you trying to convince here, the kid flying a beaver in Butthole, NWT who is trying to figure out how to apply to Encore?
Seriously. grow the f-up and stfu in public.
Common Sense: We are stronger as a team. We need real representation to protect our interests against the company, whose job it is to exploit our labour to the utmost extent.squawk wrote:I understand your point. It is however, a public forum with public debate with its own set of guidelines. This debate is mostly common sense versus ideology. We have a private forum for this, but AVCANADA has provided an alternative venue.hurtin'albertan wrote:Why don't you guys keep the internal sh!t internal. You make all Wj pilots on both sides of the debate look like idiots carrying on like this. Who are you trying to convince here, the kid flying a beaver in Butthole, NWT who is trying to figure out how to apply to Encore?
Ideology: "Unions are crooked and bad, they are the reason companies fail, what's good for management is good for me. Anything ALPA tells you is a crooked sales pitch."
PROC_HDG
That's rich...an ideologue pointing a finger at an ideology.
I hear from many that nothing really will change with the new regime. If so, then why change at all.
It's implied that we will have more control, but history has shown this to be an illusion.
I'm not sure the team would be all that strong under ALPA given the current and former Encore pilots (more of whom will flow every month or two) lose their position on the WPDL due to 60 year old ALPA policy. I also don't think seniority schedule bidding is going to unite the junior pilots, many of whom will be those same former Encore pilots.
I shudder to think what will happen to the YVR base if we certify. With 87's on the way and ULCC, the smart person would chose a collaborative relationship with management in place of an adversarial one.
I guess you could unite people in anger. That should be healthy.
Rotten Apple #1 wrote:I'm not sure the team would be all that united under ALPA given the current and former Encore pilots (more of whom will flow every month or two) lose their position on the WPDL due to 60 year old ALPA policy. I also don't think seniority schedule bidding is going to unite the junior pilots, many of whom will be those same former Encore pilots.
Many ALPA pilot groups have good relationships with management... why is WJ management so threatened by certification?Rotten Apple #1 wrote:the smart person would chose a collaborative relationship with management in place of an adversarial one.
Why do you think it would be an adversarial relationship?
The adversarial nature of the current and previous drive.
