Floatplane Crash Thread
phillyfan
Re: Floatplane Crash Thread
Post by phillyfan »
You are mistaken. Not that Avcanada is not full of mistaken people.
From TSB via Google Translate.......
C-GIJY, a Cessna 185F on floats in private operation was carrying out a flight according to the rules of
visual flight from the hydro-aerodrome of Ste-Anne du lac, QC (CSP9) to Constance
Lake (CNQ5), ON with 1 pilot and 3 passengers on board. As he flew over the mountainside
of the devil(Note from Pelmet: Montagne du Diable Regional Park), it was reported that the engine did not provide the power needed to avoid a
impact with trees. Three occupants suffered serious injuries and one sustained injuries
minor. The aircraft suffered significant damage.
So sad.......I have seen two crashed floatplanes this summer and picked up a shard of a prop today at the airport from another plane(owned by a pilot I have talked to several times) that stalled on takeoff recently. It is never ending.
Swampdonk wrote: Mon Sep 02, 2024 5:17 am No talk about the Otter that hit the water a few days ago in northern Ontario. No injuries I hear.
From TSB....
C-GMLB, a De Havilland DHC-3T floatplane operated by NDK Air Limited departed the Armstrong
Water Aerodrome (CJF6), ON, on a VFR flight to Kashishibog Lake, ON. While on final approach
to Kashishibog Lake, the aircraft struck a tree and subsequently landed hard onto the water. The
pilot and passengers successfully egressed the aircraft. Two of the passengers received minor
injuries. The aircraft was substantially damaged and became submerged.
From TSB...
C-IJGU, a privately registered float-equipped Zenair CH701SP, had departed the Catchacoma
Marina for a training flight, with an instructor and the student pilot/aircraft owner on board. After
conducting some airwork in the vicinity of Catchacoma Lake, the instructor planned to demonstrate
a landing on glassy water. During the approach, the aircraft unexpectedly contacted the water with
a relatively high rate of descent, and the aircraft overturned. Both occupants exited the aircraft and
were uninjured and were rescued by nearby boaters. The floats of the aircraft had become mostly
detached, and the aircraft eventually sank. It was later recovered from the lake and is substantially
damaged.
From TSB...
C-GIUR, an Air Nootka Limited Cessna A185F floatplane departed Nootka Island Lodge (49° 37'
26" N, 126° 37' 23" W), BC, for Gold River Water Aerodrome (CAU6), BC, under visual flight rules.
On approach, the pilot elected to land on Gold River due to the high wind observed in the Muchalat
Inlet. The aircraft touched down near the river mouth in a south-southwest direction. During the
landing slide, the aircraft veered towards the right riverbank and the pilot attempted to correct back
to the left. Subsequently, the right wing contacted the water. The aircraft came to a stop on the
right riverbank and was towed to the nearby company dock. The occupants were checked by
emergency health services and there were no reported injuries. The aircraft was substantially
damaged. The aircraft will be assessed.
From TSB...
C-GPMX, a privately registered float-equipped Maule M5-235C aircraft, was conducting a VFR
flight from Moosehorn Lake (58° 09' 31" N, 132° 07' 32" W), BC, to Kennicott Lake (58° 10' 26" N,
131° 33' 04" W), BC, with only the pilot on board. While en route, the aircraft conducted a low pass
over a lake and while in a left turn, the aircraft's airspeed reduced, the left wing stalled, and the
aircraft impacted terrain. The pilot was able to egress the aircraft and was uninjured. The aircraft
sustained substantial damage. The ELT signal was relayed to the Joint Rescue Coordination
Centre in Victoria, BC.
The pilot was able to walk to a nearby camp and the aircraft will be recovered from the accident
site.
Another 180. I'm amazed that any are still around...
C-GWBI, a Cessna 180 type aircraft on floats in private operation, was carrying out a flight
under visual flight rules to Lac Parent in Senneterre, Qc with only the pilot
on board. During the landing on Lake Parent, a gust moved the aircraft and the pilot lost
control. The right wing hit the water and the plane overturned. The pilot was able to evacuate the aircraft and
was rescued by local residents. The pilot was not injured and the aircraft received
significant damage.
...from TSB via Google translate.
From TSB....
C-FXUN, a privately registered De Havilland Aircraft of Canada DHC-2 Mark 1 Beaver departed
Courtenay Airpark (CAH3), BC, on a recreational flight, under visual flight rules, to a private airstrip
on Nootka Island, BC, with the pilot and 2 passengers on board. Shortly after touchdown, the
aircraft collided with vegetation along the edge of the landing area. There was damage to the
undercarriage and to the wings. There were no injuries.
Aircraft was disassembled and transported to Campbell River for assessment and repairs.
From TSB.....
C-GCRD, a privately registered Murphy SR2500 (Super Rebel) departed Powell River Airport
(CYPW), BC, on a local recreational flight under visual flight rules with only the pilot on board. After
departing CYPW, the aircraft took part in a flypast related to Remembrance Day ceremonies. In
order to increase drag during the flypast, the pilot extended the landing gear of the aircraft's
amphibious floats. After the flypast, the pilot proceeded to perform a water landing near a private
dock approximately 16.5 nautical miles north of CYPW. During landing, the extended landing gear
caused the aircraft to nose over, and the aircraft propeller struck the water. The pilot was able to
egress the aircraft and swim to shore. The aircraft sustained damage and subsequently sunk.
There was no ELT activation. The pilot was located by a search and rescue helicopter
approximately 2 hours after being reported overdue, and approximately 8 hours 45 minutes after
the occurrence.
The aircraft was subsequently recovered from the water and is undergoing repairs.
Jean-Pierre
Post by Jean-Pierre »
I can't believe insurance companies even insure amphibs anymore.
TeePeeCreeper
Post by TeePeeCreeper »
Jean-Pierre wrote: Wed Nov 27, 2024 3:12 pm I can't believe insurance companies even insure amphibs anymore.
I can’t believe that it’s still a 7 hour rating!
What’s even more mind boggling is that everyone who owns an amphibious aircraft are aware of the inherent risks.
Yet these “oupies” keep occurring and speaking of insurance sending premiums soaring.
TPC
Jean-Pierre
I don't think it's hours because experienced guy do it too. I don't think everyone is aware of the inherent risk. They wouldn't be using the landing gear as a drag device when landing on water. That's asking for it.
Jean-Pierre wrote: Fri Nov 29, 2024 8:39 am I don't think it's hours because experienced guy do it too. I don't think everyone is aware of the inherent risk. They wouldn't be using the landing gear as a drag device when landing on water. That's asking for it.
Best to just Always, Always, Always use a written landing checklist when operating on amphibs, even of you are like so many that don't use a written checklist on regular floats(high percentage of floatplane pilots).
From TSB....
C-FUCL, a privately registered Rans Coyote II S-6S was on a recreational flight from Kuskanook
Harbour, (49o 18' 08" N, 116o 39' 53" W) to Creston Aerodrome (CAJ3), BC, under visual flight
rules, with the pilot and one passenger on board. Immediately after lifting off from the water, the
right wingtip dropped and came in contact with the surface. The aircraft came to an abrupt halt and
settled upright on the water with the right float strut having collapsed. The occupants egressed
from the aircraft without injury and paddled to the nearby beach. The aircraft was substantially
damaged.
The aircraft had damage to the landing gear supports, a cracked wing tip, and a bent propeller
blade. The aircraft was towed from the beach and transported back to its hangar. It will be
assessed for damage.
Accident season has started. Here is hoping for a safer than normal one.....
"C-FYNT, a float-powered De Havilland DHC-2 MK.I (Beaver) operated by ETA Aviation & Cesar Camp du Nord Inc., was conducting a local flight from the Richelieu River in front of the St-Mathias, QC (CSV9) water aerodrome with two people on board. During the takeoff roll, the aircraft lost control in a roll. The right wing detached upon impact with the water, and the aircraft ended up inverted below the surface of the river. The pilot died and the other suffered minor injuries. The emergency locator transmitter (ELT) did not activate."
....from TSB via Google translate.
From TSB.....
C-GZOP, a privately registered Cessna A185F on amphibious floats was landing at the
Edmonton/Cooking Lake Aerodrome (CEZ3), AB. The pilot was conducting a landing on Runway
10 with a prevailing southerly wind. The aircraft touched down on the north side of the runway on
the right-hand float. The aircrafts right float bounced off the runway and the right wing continued to
rise as the aircraft departed the paved surface of the runway. The left wing contracted the infield as
the pilot applied full power. The aircraft continued to veer northward, impacting a fence and tree on
the airport's perimeter, where the aircraft came to rest in a drainage ditch, facing south. There was
a post impact fire. The pilot, who was the sole occupant, was seriously injured and was extricated
from the aircraft by first responders. The pilot was subsequently medevaced by helicopter to a
nearby hospital. The aircraft was destroyed in the post impact fire.
From TSB....
C-FUEY, a privately registered Cessna C180, was conducting a VFR flight from Pistol Lake, ON to Pickerel Lake, ON with one pilot on board. During the flare, the aircraft encountered gusty conditions and touched down on the right float. The aircraft continued rolling to the right until the wingtip contacted the water; resulting in the aircraft cartwheeling on the water. The aircraft came to stop facing in opposite direction of the approach, upside down with the cockpit submerged. The pilot exited aircraft through the passenger door. There was no fire. There were no injuries. The aircraft sustained substantial damage. A retired firefighter/paramedic was first on scene with a boat followed almost immediately by a second boat. The aircraft was towed submerged to a sand beach with the bottom of the beach on a gradual incline to land. The aircraft was secured to shore and marked with buoys for visibility as only the bottom of the floats were visible from above water line. Paramedics, volunteer firefighters and OPP also attended the scene.
piperdriver
Post by piperdriver »
Bamiji Air Beaver C-FHEP had an accident near Chamberlain Narrows on July 14th, 2025. Floats were torn off and it is sunk in the lake.
FishermanIvan
Post by FishermanIvan »
piperdriver wrote: Tue Jul 15, 2025 6:21 pm Bamiji Air Beaver C-FHEP had an accident near Chamberlain Narrows on July 14th, 2025. Floats were torn off and it is sunk in the lake.
Everyone on board survived, although judging by the one picture I saw, are probably quite lucky to do so.
JasonE
Post by JasonE »
mmm...bacon
Post by mmm...bacon »
https://www.cbc.ca/news/canada/britis ... .7588152
Two people were safely rescued after a float plane crashed in False Bay on the west side of Lasqueti Island, B.C., Thursday morning, according to officials and a witness who assisted with the rescue.
Al Bajec, owner of Lasqueti Island Hotel and Pub, was making coffee just after 9 a.m. when he says he heard the float plane coming in.
The plane, which Bajec believes belongs to Telus, comes every Thursday to drop off a couple of workers on the island, which is located about 70 kilometres northwest of Vancouver. Bajec said that on Thursday, it appeared to be coming in at a lower angle, but was otherwise normal, with relatively calm waters.
Amphib. Picture looks like a gear issue…oops!
Dias
Post by Dias »
I don't understand how amphibian aircraft even get insurance.
TeePeeCreeper
**** wrote: Fri Jul 18, 2025 9:08 pm I don't understand how amphibian aircraft even get insurance.
I don’t understand how amphibian aircraft operators even forget in which state their gear configuration is in.
TPC
TeePeeCreeper wrote: Sat Jul 19, 2025 1:05 am
TPC
Checklist, checklist, checklist. When I fly regular floatplanes, it may be more mnemonic for the landing procedure. On an amphib, before the flight, remind yourself to absolutely use that checklist for every part of the flight landing and triple check the gear in more than a standard quick "gear down' or 'gear up' quick statement.(it is a pain but less pain that forgetting).
ChrisB
Post by ChrisB »
Teen boy, 16, was standing on dock when fatally struck by small plane in Lake Scugog, police say | CBC News https://share.google/3PlggecK6vCpNGX99
This season isn't going well...
Just saw Jason also shared.
