yet the icing looks like this:
. Am I missing something here?Moderators: sky's the limit, sepia, Sulako, lilfssister, North Shore
If you look at the GFA above it also shows freezing drizzle, but there is nothing at all on the icing chart.Diadem wrote:I'd say it's probably something to do with the fact that the GFAs you posted are for 1200Z, whereas the FZDZ at YRL is from 0100-0300, at YHD it's 0400-0800, and at YXL it's 0400-0800. That's like looking at the public forecast for tomorrow and then looking at the TAF for today and wondering why they show two different things.
The icing chart only shows icing if it's moderate or severe. I don't know whether light freezing precipitation meets that requirement, but I would suspect that because it's light and local it doesn't meet the criteria to be on the icing, turbulence and freezing level charts.CpnCrunch wrote:If you look at the GFA above it also shows freezing drizzle, but there is nothing at all on the icing chart.
Anyway, I find that it useful to believe the worst forecast I can find.
The accident report does not reflect any pre-take off icing or accumulation and seems to discount it as a factor (tactile check 12 minutes prior to flight).Illya Kuryakin wrote:What "caught" Nancy in YWG, was a warm airplane brought out into precip. Also know as a cantaminated wing on departure, plus the failure to maintain corrodinated flight (evidenced at the point of impact, loss of control while in flight) an attempt to maintain altitude, while the only defence at that point would be dashboard power and a controlled descent. That would have given her some say in where she ended up. Perhaps not graceful, but not a lawn dart. Hurt your feelings? Too bad, learn from it.pdw wrote:Up til departure the YWG metar had 0C (5am), ... a north takeoff into 15-20kt blustery / light-snow ... turnout SE .. not very high and went down in 4 minutes. A W&B issue included (report / Oct 6 05 5:37). Meterological info in the report has 2C per 1000' ....StratusSmoke wrote:There is often an area a couple of hundred feet below stratiform clouds where there is some freezing precip even though there is none reaching the surface. I would imagine it becomes a real big problem when the space between the clouds and the ground gets pretty small. Difficult to forecast but I try to mention it in low stratus conditions and air temps -5 to -15. I strongly suspect that is what caught Nancy in Winnipeg.
YZF/NWT here is -10C to -11C, but what's it at 3-4000' a few minutes later ? Less ?
Illya
When I did my caravan sim at PAIFA in 2010, my instructor (Gene LaLonde) said he was contracted by the TSB to assist in the investigation. During the weeklong course we discuss virtually every caravan accident to date, around 200. He said this accident was the only one where the pilot did everything right and still got burned. She took off into unforecast severe icing, immediately requested a return when encountering same, and still crashed. I don't think Gene would make that claim lightly, and I don't think he would have missed it had she departed with airframe ice.StratusSmoke and others wrote:There is often an area a couple of hundred feet below stratiform clouds where there is some freezing precip even though there is none reaching the surface. I would imagine it becomes a real big problem when the space between the clouds and the ground gets pretty small. Difficult to forecast but I try to mention it in low stratus conditions and air temps -5 to -15. I strongly suspect that is what caught Nancy in Winnipeg.
Illya
Special wx obs taken 0531 shows temp -1C. The hourly was 0C, but no indication if that was on the minus side of 0 i.e. -0.4C.
Two minutes before ATD -2C at 1800 asl and -3C at 2400 asl.
Illya Kuryakin wrote: At best, these accidents are open to speculation.
Illya
Taxiing/backtracking for take-off (the 12 minutes between the "tactile" and the rotation) is a vulnerable time if some wet snow and the temperature is close to call. Once airborne, anything that got 'stuck on' in the pre-takeoff after the tactile would be going against you esp with the maxed load (see loading details described in the TSB report).Illya Kuryakin wrote:At best, these accidents are open to speculation. We had a company aircraft on approach to RWY 36 at the time of the accident, that reported no inflight icing.
Must have already picked up some on the way if this quick turnaround flight was only minutes on the ground; ... of course any enroute collection resorts to surface upon touchdown.Of course the best example of surface contamination was the Pelee Island accident.
(EDIT ... no ground icing in the report ... a "rudder trim" idication error is listed as the cause)If I recall, Nakina suffered a similar fate a few years back.
This is what's IMO believed to be correct. At the time a pilot at Put-in-Bay not far from CYPT noted that he decided to "pack it in by 5pm" because of freezing rain had started. A number of residents on the Island were quoted (I believe this group also included the Mayor if I recall correctly from media hype at the time) to have come out to their vehicles after work as news of the accident had spread to find evidence of freezing rain. Lets be clear though, that everyone who had boarded had done so well before this time, keeping in mind that pax-loading to go was being accomplished by 4:20pm (a 4:30pm departure), which was much earlier than the timing of those commentaries.Illya Kuryakin wrote:Pelee Island sat in freezing rain before departure.
I drove through the area as that system was approaching, as a matter fact was heading for Edmonton to take in the Cessna Caravan Icing Seminar at Niska, scheduled the evening before this accident happened; was shocked to see it on the news the very next day after that lesson. Then at the time there was the info about about an incident to do with picking up ice, just a few days before this accident ... but at the front of this same system, to do with an inbound Van from Thunder Bay (the same one ?). The report for this accident discusses some uncertainty about the W&B information, but here everyone must read it verbatum from the report, not to misconstrue anything factual that the TSB has stated about that.pdw, what was the W&B issue with the Morningstar machine?
If it is after turning enroute there at 500'agl, it's close to where the decision to land originates, about a minute to a minute-and-a-half after the 95 degree heading change into crosswind / into the strong but irregular (even slightly left-tailquartering) component for tracking the ThunderBay route ESE.I still suspect from the timing, that things started to unravel on flap retraction? I usually suck up one notch of flap at about 400 feet.
10 degrees of flap can be extended at 175 KIAS. 20 degrees at 150 and full flap at 125.pdw wrote: Speaking of flap, looking at the Behchoko accident photo, it's hard to see if they are up or down. An NTSB narrative of a Caravan landing event at Grand Island NE on the morning of Jan 20 1998 is somewhat similar, being at cruise power all the way down to make the field (the report contains the pilot's written statement) going 120-140kts, a speed obviously out of the park for extending flap.
Are you comparing the ATR42/72 incident flap,extension with that of a Caravan.....you lost me.pdw wrote:Copy that. At least an inch of ice there, in that context (Nebraska 1998).
I remember the accident. Ground ice was certainly the talk of the time. Just because the TSB a report found "no evidence" doesn't mean there was none. Perhaps it melted?pdw wrote:You're correct, no evidence of "ground icing " in there .. sorry
